Old 11-15-2004, 09:54 AM   #10711
Horatio's Avatar
Default Re: CAN'T GET GEAR MESH RIGHT IN DIFFS
Originally posted by shooky
IS THERE HOPE FOR MY YOK?
Thanks,
Stephen <><
OK - it's my understanding that the product D 2.5 kit attempts to use a smaller input pinion on our regular size diffs. This alone is going to lead to obvious meshing complications as the gearboxes themselves simply aren't designed for this configuration.
Theory aside for one moment - no wonder you're finding it difficult to get the mesh right.
Regards hope for your Yok - course there's hope - go back to the original drive pinion and the problem will go away!
How many Yok SD drivers at the worlds were using the Product D 2.5 ratio kit.......?
Hope you get your car sorted soon.
Regards
Horatio
Horatio is offline   Reply With Quote
Old 11-15-2004, 09:56 AM   #10712
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
I have gone back to the original gears and I am still having th esame problem. Used every shim setup I can think of.
Thanks though,
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 11-15-2004, 10:15 AM   #10713
Horatio's Avatar
Well, as the gears are new you will have to check the teeth for any trace of flashing that may be left over from the moulding process. Use a sharp knife/scalpel to remove any surplus material. Also bear in mind that diff gear (crown) it's a good idea to replace the drive pinion at the same time.
The gears also need to bed-in and only when this has been done will you attain total silky smoothness.
Old 11-15-2004, 10:15 AM   #10714
forty6's Avatar
Hey guys I have been trying for over a week to fix a little problem in my SD Rayspeed Diffs. I had tried the Product D Bevel gear change and coundn't get the gear mesh right in the Diffs even with every possible shim configuration. I went back to the original gears and still have the same problem. The front and rear bevel gear isn't matched up like it should be. I even tried to shim the Diff it self to the side which I think creates drag and didn't want to but was desperate to get it running and after about one minute it would have the same gear grinding noice as before. I have new diffs new gears, new diff cases and new shims should I shange them also? There isn;t any real sign of wear on the current gear and diffs(they were just rebuilt).
Thanks,
Stephen <><
Maybe a long shot, but have you checked your input shafts? They can sometmes bend in a bad crash.
forty6 is offline   Reply With Quote
Old 11-15-2004, 10:17 AM   #10715
rc_bam226's Avatar
Try checking the the spacer amount on the input shafts, they are the spacers in between the input gear and the bearing.
rc_bam226 is offline   Reply With Quote
Old 11-15-2004, 10:17 AM   #10716
Default Re: Re: CAN'T GET GEAR MESH RIGHT IN DIFFS
I believe they are striat but no I didn't check them. I should order them today as to make sure they are good and new also.
thanks,
Stephen <><
Old 11-15-2004, 02:55 PM   #10717
primusblowsgoat's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to primusblowsgoat Send a message via Yahoo to primusblowsgoat
probably a dumb question that with some reasearch i could find the anwser to but hey im at work and this will bump the thread back up
whats differnt between the cgm and the ssg chassis, somewhere i saw a tub style and every other one i see is the two deck carbon fiber style. which one is which?
which ones do you guys like better for which aplications?
im about to get a bonus check and what a new touring car and not a losi or an AE, its gonna be a yoke or an hpi probably
Schumacher Racing
Schumacher Cat SX2
Schumacher Cougar SV
primusblowsgoat is offline   Reply With Quote
Old 11-15-2004, 03:02 PM   #10718
Horatio's Avatar
CGM = Tub
SSG = Double Deck
Old 11-15-2004, 03:28 PM   #10719
This Thread is titled Yokomo MR-4TC SD
So it is the SD that we are talking about here but the CGM gets a couple of blurbs every now and again. Basically the car is the same except the chassis. The SD SSG is Carbon fiber and the CGM is Grafite. I personally like the Rayspeed upgrade to the standard ssg chassis but that is my preference. The SSG is a real nice racer. My friend races his CGm and he is fast with it also so what it comes down to is do you like Carbon or Grafite?
There is your answer.
Hope this helps
Stephen <><
There are slight variations but the car is the same minus the Chassis.
Old 11-15-2004, 03:30 PM   #10720
Horatio
beat me to it,
LOL
Old 11-15-2004, 06:38 PM   #10721
Regional Moderator
daniz24's Avatar
I think the best combo is Yoke SD CGM converted to Rayspeed chassis.
You get lightweight chassis and all of the graphite parts.
daniz24 is offline   Reply With Quote
Old 11-15-2004, 07:43 PM   #10722
so you buy the car for 270, then spend another 150 on the rayspeed conversion?
Schumacher Racing
Schumacher Cat SX2
Old 11-15-2004, 08:15 PM   #10723
Registered User
ritchie's Avatar
well i guess you could if you want, just buy cgm and get a few rayspeed goodies.
ritchie is offline   Reply With Quote
Old 11-15-2004, 08:21 PM   #10724
danjoy25's Avatar
Trader Rating: 37 (100%+)
Anyone have an update on the Rayspeed version 2 conversion for Yokes?
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 11-15-2004, 09:21 PM   #10725
rc_bam226's Avatar
Nothing yet has been posted, sorry.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
