Old 11-04-2004, 04:13 AM   #10486
Matt Howard's Avatar
Default Re: I've just printed out a gear ratio chart...
Originally posted by Mabuchi540
and I notice there are 5 combinations of spur and pinion that give exactly the same gear ratio (this applies to other ratios as well) so I'm wondering does it really make any difference which combo I use to get any given ratio?
Any advantage to using the smallest combo or the largest etc, some ppl I've talked to say yes others no.
IMO as long as you get the same ratio the car should run the same. The advantage of using a bigger spur though is that you can have the motor further to the outside helping balance the car out better, the battery side is heavier if you're using GP3300's.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 11-04-2004, 04:38 AM   #10487
Send a message via ICQ to Cobra81li200
Originally posted by fai
Dear all, just a simple question:
Does using the lower hole (hinge pin hole) of C-block mean raising roll center and implies reduced steering?
Thanks!
Edit : It actually raises it a lot compared to the upper hole.
Matt : when you tried the upper hole, did you re-set the droop in order to have the same values when you measure them from the C-Hub (very important). Because, when you use that upper hinge pin hole and not re-set the droop, you will have a lot of front droop, meaning that indeed you will not have any on power steering.
If you did re-set the droop, then i am not surprised either , this hole lowers the RC a lot and it might be too much for the tyres (they may work too much). I tried to use the upper hinge pin hole on the rear, and it didn't work well for me.
Cobra81li200 is offline   Reply With Quote
Old 11-04-2004, 04:59 AM   #10488
asw7576's Avatar
I use upper hole hinge pin front and rear for strength reason ( I still use standard suspension arm which prone to break after big hit ). The car will oversteer after you use the rear upper hole hinge pin, but you could compensate it with thicker oil and harder springs at front.
Old 11-04-2004, 05:06 AM   #10489
Originally posted by Cobra81li200
It actually lowers it a lot.
Matt : when you tried it, did you re-set the droop in order to have the same values when you measure them from the C-Hub (very important). Because, when you use that upper hinge pin hole and not re-set the droop, you will have a lot of front droop, meaning that indeed you will not have any on power steering.
Yes, I reset everything in the front when I tried it, it was actually one of Masami's setups, didn't fit my driving style at all. So you're saying when you use the lower hole in the castor block the roll center is lowered? That was the question.
RCTech #361
Old 11-04-2004, 05:13 AM   #10490
The question was concerning the upper hole if I am not mistaken, which lowers the RC a lot (more angled wishbones usually have this effect, but it also depends on the angle of the upper link (to a lower extent though).
If you want to raise the RC, try swapping the spacers of the front hubs (have the spacer that is placed between the C-Hub and the hub on the lower hinge pin). Again, the droop will need re-setting, as always when you change the RC (apart from when you move the upper link).
Old 11-04-2004, 05:17 AM   #10491
Thanks!
Here's the initial question, you had me thinking I was going crazy
RCTech #361
Old 11-04-2004, 05:35 AM   #10492
woooooops
Having seen that, I always use the lower hole and the car works fine for me...
Old 11-04-2004, 05:38 AM   #10493
woooooops
same here
RCTech #361
Old 11-04-2004, 05:43 AM   #10494
I know why, you got me confused, as you answered the question by saying you tried to use the upper hole...
Anyway, I leave what I posted earlier, it might be helpful for smoe people...
Old 11-04-2004, 06:34 AM   #10495
j06
anyone using yokomo aluminum hinge pin mounts? are they durable?
j06 is offline   Reply With Quote
Old 11-04-2004, 06:52 AM   #10496
I use them, they're fine, no problems at all.
RCTech #361
Old 11-04-2004, 07:05 AM   #10497
vtl1180ny's Avatar
R/C Tech Charter Subscriber
No hinge pins trying to sneak out the back of the car when you use the rear ones....
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 11-04-2004, 07:54 AM   #10498
Never, there is no hole all the way through
pops is offline   Reply With Quote
Old 11-04-2004, 08:03 AM   #10499
Err, if you're having that problem, maybe you should consider using the grub screws that are supposed to go in the rear hinge pin holder
Old 11-04-2004, 08:15 AM   #10500
Horatio's Avatar
Default Re: Re: I've just printed out a gear ratio chart...
Finally - Ahmen!!
Horatio is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
