Old 05-01-2003, 01:44 AM   #1036
CSF0623's Avatar
BurRITOH: are you there? If you read this...when do u need the rest of the bodies by?
CSF0623 is offline   Reply With Quote
Old 05-01-2003, 01:56 AM   #1037
asap!
burritoh is offline   Reply With Quote
Old 05-01-2003, 02:23 AM   #1038
utieh's Avatar
how are those Suzuki arms ??? do they fit ?
utieh is offline   Reply With Quote
Old 05-01-2003, 05:38 AM   #1039
since i don't have one, can someone who does answer the question. are the shock moounts on the sd much wider than the bd (belt drive).
cos from the pics the whole car looks way wider
sanj
schumacher is offline   Reply With Quote
Old 05-01-2003, 05:52 AM   #1040
birdy233's Avatar
Trader Rating: 78 (100%+)
How the heck did you guys get the battery packes to fit, I filed my battery slots but the battery pack still won't fit under the strap?? More filing I guess???
birdy233 is offline   Reply With Quote
Old 05-01-2003, 06:55 AM   #1041
Default chassis prep
Received our kit yesterday. Questions for you guys on chassis prep:
- Do you CA all of the SSG plate edges, including the shock towers and top plate?
- How much beveling of the battery slot corners do you do? How deep and at what angle?
Thanks. I haven't worked on a plate chassis in a while.
coolrcdad is offline   Reply With Quote
Old 05-01-2003, 08:38 AM   #1042
Regional Moderator
Darkseid's Avatar
Birdy: I'll assume that your using Sanyo cells of one type or another 3000..3300.... because those are the only cells I had trouble getting in. Sanyo's cells are just SO large that it takes extra work to get them in. And if you have Sanyo cells WITH an extra layer of shrink one them....then your in trouble. Back when I had my Mission, I had to shim up the battery post just to get my 3000HV cells to fit, and that was after I had to remove the extra layer of shrink wrap that came one them.
Now I know what your thinking. "Why don't the companies just make more space for the the things.....well, thats where GP and Panasonic come in. THeir cells are very, VERY small compared to Sanyo's. Infact, my new SMC GP3300 are about the size of my really, really, old Sanyo 1400 pack! And thats SMALL!
So the companies are left with a delima, make their slots big enough for the largest cell, or make them perfect for the smaller cells. Most companies are picking the second option and just letting those with larger cells figure a way to make them fit.
TLR 22...Tamiya F104...
Old 05-01-2003, 08:47 AM   #1043
Regional Moderator
Darkseid's Avatar
coolrcdad:
-I sanded and CA'd the lower chassis, but I just sanded the other pieces.
- I went at about(and I'm guessing here) a 45 degree angle when I sanded the slots. Maybe a little less of an angle than that really....maybe 40 degrees is more like it. I didn't sand them too deep. Just deep enough that my Sanyo 3000HV cells fit in, but not so much that my GP3300 fit losely. Its tricky to get it just right, so file a little at a time until you get it where you want it.
Old 05-01-2003, 09:31 AM   #1044
utieh's Avatar
spring set-up
which spring set-up are you starting with for outdoor asphalt tracks ?
Old 05-01-2003, 09:36 AM   #1045
rc-zombies's Avatar
Default Re: spring set-up
Try Mo's setup..
Old 05-01-2003, 02:17 PM   #1046
Dark - Thanks for the info.
Old 05-01-2003, 03:55 PM   #1047
racer's Avatar
are there any setups for carpet, other than the LRP tournament?
Thanks in advance!
racer is offline   Reply With Quote
Old 05-01-2003, 10:39 PM   #1048
SpeedTech's Avatar
Hi Guys,
We got more MR-4TCSD parts in stock, including lower chassis deck, front and rear shock towers. Also, we received the Yokomo MMS (Motor Management System) and the HMM (Hyper Motor Mate) as well. I will get it up on the website tomorrow.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 05-02-2003, 03:09 AM   #1049
Originally posted by CSF0623
Chris: the blue cvd's are from the old MR4-TC car! Just use the the rear blue aluminum bones for the front and rear and ur set. The dog bones are kind of pricey @ $14.00 for one bone so that times 4 plus tax...ouch!
where did you get them from i need 2 more since i took 2 off my old yok.
SUZUKI ARMS
they will fit but i do not recomend them because it look like i would need to do alot of trimming.
im 98% done with the asymbly and i should have a pic up tomorow night.
Chris@WeaponR is offline   Reply With Quote
Old 05-02-2003, 07:00 AM   #1050
sosidge's Avatar
Just to say that I am now a member of the SD owners club, picked up my UK car today.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
