Old 10-31-2004, 10:30 PM   #10471
I'm thinking of getting the Stratus type E....
body for my CGM. What I'd like to know is, if I cut the body exactly as scribed will it be a perfect fit or will I still have to do a little work on it?
I ask because the last time I followed the lines (on my current Hpi Astra body) the fit was way off (not a good start for my first on-road body lol).
The other question is I've read that the type-e has a lot of downforce, could this in fact be too much and slow my 540 stock down?
Thanks in advance.
Mabuchi540 is offline   Reply With Quote
Old 10-31-2004, 10:42 PM   #10472
Blakesrc's Avatar
Send a message via AIM to Blakesrc
Mabuchi540,
I think that the bottom cut line is just fine on most bodies. The only thing i have run into an issue with is the wheel scribe lines on some bodies. It depends on what wheelbase you are running on the car(where your spacers are, in front and or behind the arms). I always mount the body before i paint it and also mark out where the wheel cut outs should be at the same time with a felt tip pen.
Good luck,
Blake
Blakesrc is offline   Reply With Quote
Old 10-31-2004, 10:44 PM   #10473
Default My bad my bad :(......
Originally posted by Blakesrc
Mabuchi540,
Good luck,
Blake
That's the part I ment, the wheel arch scribe lines, I'm running the CGM box stock as far as the wheel base goes. so just wondering if cut as marked will it fit like a glove so to speak?
And no naughty if the glove does not fit you must aquit comments either.
Additional: While I think about it, what type of body is on the car on the home page of www.rctech.net?
Old 11-01-2004, 06:26 AM   #10474
Default Re: My bad my bad :(......
Looks like a Stratus 2.0
pops is offline   Reply With Quote
Old 11-02-2004, 09:49 AM   #10475
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
Matt and other Yok fans..... I got a Yokomo 12 WC (SSG) car to run this season on the carpet. I use to run a CGM and got some great info from here. Are there any setups for the yokomo 12th on the carpet? I have a few tosolini sedan setups and was looking for some 12th scale carpet ones...thanks for the help.
Jeff
Jeff Werner is online now   Reply With Quote
Old 11-02-2004, 10:15 AM   #10476
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
I know that this isn't the tread for it but I have a SSG and now I got my Yokomo TC Mini and it has to be the funnest car I have ever owned. Man it is almost as fast as a regular TC but it uses 4 cells. WOW is not even enough, I raced it against my normal 10th scale guys this poast weekend and the only one who could turn more laps was anouther 12th scale mini TC. I have to say if you have an extra $200 I would highly recommend one, or two if you wan tto start your own class. That is what we are trying to do here. We need only two more to get the class going.
ALSO I STILL LOVE MY SSG JUST WANT TO GIVE YOU GUYS SOME OTHER FUN OPTIONS>
C YA
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 11-02-2004, 10:46 AM   #10477
vtl1180ny's Avatar
Eventually the 1/12th TC class will start up.... Gives a lot of shops that don't have the room for a 1/10th track another option....
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 11-02-2004, 03:34 PM   #10478
sosidge's Avatar
Not this time... it had it's chance 12 months ago when the Yokomo and Xray cars first came out... people just didn't go for it.
Maybe they'll try again in a few years time... MR4-TC SD Mini SSG Special anyone?
Old 11-02-2004, 03:49 PM   #10479
Matt Howard's Avatar
Jeff
This is for a high traction carpet setup that I ran on the Yok 1/12 last year
.20 front springs
Purple front tires
Pink or Grey rear tires
thick .075 Tbar
reactive mounts in the front with one spacer front and rear on the arm
Olive spring with 30wt oil in shock
batteries to the rear
I ran mod with this setup but I'm clueless as to what rollout I ran. I ran AE Tbars on the car, you'll need to get the AE plastice pivot ball mounts and balls to make it work on the yokomo car though. The stock Yokomo Tbar is the thin .063 type. I found the car actually works pretty good but you need to come up with a different type of brace for the front end, those thin graphite strips that come with the car break REALLY easy and without any bracing you can feel the car slow down in the turns as the front end flexes. I took an aluminum tube I had from another car and made it fit inbetween the upper arm mounts.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 11-02-2004, 04:03 PM   #10480
JimmyMac's Avatar
Shooters makes a blue aluminium brace to replace the weak Yok carbon brace. I think I got mine from Precision RC...
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 11-02-2004, 05:15 PM   #10481
Got a Picture?
Email me
Thanks,
Stephen <><
Old 11-02-2004, 07:56 PM   #10482
JimmyMac's Avatar
Actually they don't sell it anymore at Precision. I just checked. But here is a pic from there website. You can see the brace on there. I'd take a pic of mine, but it's not on the car. Right now I have the IRS front end on the car = no brace.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 11-04-2004, 02:39 AM   #10483
fai
Regional Moderator
fai's Avatar
Dear all, just a simple question:
Does using the lower hole (hinge pin hole) of C-block mean raising roll center and implies reduced steering?
Thanks!
fai is offline   Reply With Quote
Old 11-04-2004, 02:46 AM   #10484
Thanks!
Yes. I've tried running in the upper hole in the castor block and the steering felt very inconsistent for me. It seemed to want to push bad on power and as soon as I let off the throttle it turned too hard. I always use the lower hole now.
RCTech #361
Old 11-04-2004, 04:02 AM   #10485
I've just printed out a gear ratio chart...
and I notice there are 5 combinations of spur and pinion that give exactly the same gear ratio (this applies to other ratios as well) so I'm wondering does it really make any difference which combo I use to get any given ratio?
Any advantage to using the smallest combo or the largest etc, some ppl I've talked to say yes others no.
If it helps the track has a 137 foot long straight.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
