Old 10-20-2004, 01:18 AM   #10171
Lonestar's Avatar
Shooky,
I agree with what you wrote about the gears changing the motor position and hence the balance of the car... my skepticism was indeed coming from a polar moment / roll center confusion. Thanks for this adult answer anyway, you don't see that often people trying to explain things cold-headedly when they're contradicted.
today is ... track day (or shall I say afternoon)... I will experiment with RC and swaybars this afternoon, and pops' setup (thanks btw).
Later,
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 10-20-2004, 03:40 AM   #10172
johnbull's Avatar
Originally posted by Matt Howard
Handling and acceleration wise they're pretty even but the SD is tons easier to work on and it has more suspension adjustments.
I think I'd sum it up exactly the same way.
Of course we'll have to see what the TC4 is like.
johnbull is offline   Reply With Quote
Old 10-20-2004, 05:32 AM   #10173
Horatio's Avatar
SD - TC3 comparison.
Out of the box, my TC3 seemed more competitive for carpet racing. It was also far more durable. I'm not one for breaking cars but my SD was undeniably more fragile compared to the TC3.
The SD's design makes it much nicer to work on, easier to maintain AND you can change the spur really quickly too - unusual on most other shaft driven cars. I prefer the SD's metric screws also.
Once the setup is sorted, I reckon the SD produces slightly more grip and is easier to drive fast - but others may disagree. I suppose that depends on many variable factors, including personal preferance.
Both are great cars - but the SD wins hands down on style!
Horatio is offline   Reply With Quote
Old 10-20-2004, 07:24 AM   #10174
Midnight's Avatar
Trader Rating: 85 (100%+)
One thing I hated about the TC3 was the steering rack. It always seemed to bind up. I have been driving the SD for about 8 months and as far a been fragile I have yet to have a problem. The diff is the only weak part on this car. Once you learn how to build those, its nothing but a walk in the park.
RC8T; Losi 2.0B; FT T4; AKA & RB
Hoffman Photography, www.carolinasrc.com
Midnight is offline   Reply With Quote
Old 10-20-2004, 07:28 AM   #10175
vtl1180ny's Avatar
R/C Tech Charter Subscriber
There are 2 things about the TC3 that annoy me... For one, the diffs are a pain to get apart and the biggers one is... They use the C Hub camber link ballstud as a kingpin... It constantly strips out the steering knuckle....
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 10-20-2004, 07:39 AM   #10176
Send a message via ICQ to Cobra81li200
Originally posted by shooky
Well here is how it works for ME. By changing the gear ratio, you can use smaller spur gears by which you can move the motor in towards the center line of the car, by which it make the roll center better, by which makes MY car handles better for ME. These assesments are what is working for me. I actually bought it, tried it, enjoy it and will keep it. I am a person who will only give advise or my opinion on things I have either seen or have tried myself. I am not bashing anyone, but tired of people always bashing things that they haven't tried themselves. I happen to like the Product D gears, not only does it help roll center but the gears are aluminum which last longer than the plastic ones. Also you will have to shim the diffs inward so as not to have a binding issue. Hope this helps you make a informed judgement.
Stephen<><
Err, Roll Centre has nothing to do with that, it only depends on the suspension geometry, which you haven't changed by moving the motor closer to the shaft.
By the way, i suggest you have a look at the L/R weight balance of your car, it is not without reason that Masami uses a very big spur gear, it's to counter balance the weight of the pack.
Cobra81li200 is offline   Reply With Quote
Old 10-20-2004, 07:42 AM   #10177
Originally posted by ritchie
so then, when i put spacers under the hinge pin mounts am i raising or lowering my roll center, if i change nothing else.
It will definately raise your roll centre because by doing so, you just change the angle that the wishbones makes with the ground (you also change the bump steer so be careful with that).
Old 10-20-2004, 07:43 AM   #10178
Horatio's Avatar
Heheheh, it's funny how we're all different and experience different issues. I've never had a diff problem with my SD.
Regards the TC3, my steering was always silky smooth, but it required cleaning after every run. I never broke/stripped a single knuckle, even after 2 seasons. Infact the only part that broke in that time was a rear shock tower - but not from a crash - from a Marshall treading on my car
Taking the TC3 apart was a pain, but generally required little maintenance anyway.
The SD is a real pleasure to maintain and I'm pleased to say that since the start of the winter season, I have attended 5 race meetings and the SD hasn't broken once - mainly due to the upgraded/revised parts and materials. As it is now, my SD is quicker than my TC3. But so it should be - I spent enough money on it!!
Old 10-20-2004, 08:10 AM   #10179
vtl1180ny's Avatar
I don't know if I'm faster with the TC3 vs the SD yet... The Tc3 has a current advantage, I'm running a known setup.... I just recently switched the SD from SSG to CGM.... Every weekend I'm out just working on setup's.... I'm not even going to race until I'm entirely happy with the handling....
I still lurk....
Old 10-20-2004, 08:32 AM   #10180
Horatio's Avatar
Most of my 'practice' when I first had the SD was done entering the district and regional races. I was basically throwing my car in at the deepend racing against better drivers who already had cars they were familiar with. Considering the teething problems, I still achieved reasonable results and the car kept getting better.
If I'd been sensible like you and ironed out the problems first, I would have ended up running the TC3 for another season instead. But I just couldn't make myself do it....
Now the car is good - results so far have proved that it's in with a much better chance this year!
I just need to beat that darned Losi XXXs........
Old 10-20-2004, 08:36 AM   #10181
vtl1180ny's Avatar
Please don't ever accuse me of being sensable again... Hehehehe....
I feel faster with the Yok but others are telling me I Look faster with the TC3.... I haven't yet run any real timed laps so I really have no clue... There's only 1 other person besides me running the SD, it's hard to share setup secrets...
I still lurk....
Old 10-20-2004, 08:56 AM   #10182
Mr. Shookie's Avatar
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
I would completly recommend the Orion Pro LCS it has made the difference in how I set my car up. I can go to un used section of parking lot, make out some chalk lines, set up my LCS and perceed to doing laps. That way I can see actual results do to adjustments by checking if my lap times are being consistant. Also I recommend if you are going to do this to have three batteries that are the same.....It does make that much difference.
I have and use the opion system and it has helped me shave those valuable seconds off my lap times. Check ebay they sell them cheap there.
Hope this helps.
Oh yea my local track doesn't have a transponder system yet.
If your does ask to use it. Same prinicapals.
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 10-20-2004, 09:01 AM   #10183
vtl1180ny's Avatar
Our new system is whacky.... There's only 1 person who knows how to use it.... I haven't gone down for races yet this season, only practice... Going to drag the wife and a stopwatch this weekend....
I still lurk....
Old 10-20-2004, 09:22 AM   #10184
Horatio's Avatar
That Orion system sounds good for making the most out of un-timed practice sessions.
I'm lucky that the places I race use AMB systems. Improvements of course can be guaged by simply seeing if the lap times are improving. Most times I guage whether my car is actually any good or not by seeing how it stacks up against the opposition. If I get my laptimes within .3 of a second of this certain driver, I know I'm on the pace. One day, he'll be chasing my times!!
BTW - I'll promise never to call anyone here sensible again!
Old 10-20-2004, 11:48 AM   #10185
LOL
I am sensible to ....well Me.
Stephen <><
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
