Old 10-19-2004, 10:47 AM   #10156
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Originally posted by Horatio
Your post came in while I was writing mine - sorry if it appears to repeat what you just said.
Also thanks for pointing out that lateral balancing is actually to do with the polar moment of inertia - not roll centres.
As I understand it, roll centres are determined by the Angle of the camber links, the angle of the suspension arms at ride height and the lines that intersect with the contact patch of the tyres.
The lower the roll centre is from the CoG, the more the car will roll and therefore produce more grip - the higher the roll centre/closer it is to the CoG, the car will roll less and produce less grip.
Front and rear roll centres are not normally the same and the line that passes through both these theoretical points produce what is known as the roll axis.
If a car isn't laterally balanced, it will obviously effect the CoG but what about the the roll centres? Surely these theoretical points won't be central to the car - so presumably neither will the roll axis? Even if the suspension geometry is symetrical?
Sounds like I need to learn more. JEES I have only been in this hobby since Febuary and I thought I had most of this down...Guess I need to learn some theroritic sceince and Physiscs just to drive competively.....WOW you guys thanks for the leason may I ask what should I be doing with the 2.5 ratio for stock motor and 19T I.E. pinion/spur combos? I am a fairly competent study. Not fully realized but getting there...the R/C knowledge is still pouring in....Feed me oh wise Racers.
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 10-19-2004, 11:34 AM   #10157
lee82gx's Avatar
shooky
humility is a good quality to have..
I'm sure you will learn lots in due time
lee82gx is offline   Reply With Quote
Old 10-19-2004, 01:03 PM   #10158
Blakesrc's Avatar
Send a message via AIM to Blakesrc
Matt,
any idea when those cvd's are suppose to be released?
Thanks,
Blake
Blakesrc is online now   Reply With Quote
Old 10-19-2004, 01:19 PM   #10159
vtl1180ny's Avatar
Has anyone done a 5th body post on the CGM??? If yes, pics please....
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 10-19-2004, 01:48 PM   #10160
H.Nilsson's Avatar
I have a 5 th pin on my cgm i mounted it on the top skrew to the diff case in front, no pics yet
H.Nilsson is offline   Reply With Quote
Old 10-19-2004, 02:18 PM   #10161
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Nilsson, You have any pic?
I can't really figure out how you have mounted it
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 10-19-2004, 05:04 PM   #10162
Matt Howard's Avatar
Originally posted by Blakesrc
Matt,
Thanks,
Blake
No idea yet
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-19-2004, 07:51 PM   #10163
Registered User
ritchie's Avatar
so then, when i put spacers under the hinge pin mounts am i raising or lowering my roll center, if i change nothing else.
ritchie is offline   Reply With Quote
Old 10-19-2004, 09:15 PM   #10164
it's more commonly refered to as raising your roll center but I think some people argue that it's technically the opposite.
RCTech #361
Old 10-19-2004, 09:19 PM   #10165
DickemDown's Avatar
Default roll center
http://www.mytsn.com/publ/publ.asp?pid=9986
DickemDown is offline   Reply With Quote
Old 10-19-2004, 10:34 PM   #10166
Originally posted by Matt Howard
To be honest with you I don't think there is any time that I haven't run swaybars front and rear on my SD. Give the swaybars a try and I think you'll be happy.
I just installed the new Rayspeed swaybar on the car. It fits much better than either the older upper or older lower swaybars kits of the past.
pops is offline   Reply With Quote
Old 10-19-2004, 10:52 PM   #10167
JayBee's Avatar
Trader Rating: 31 (100%+)
Default Re: roll center
Nice article
- jaybee
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 10-19-2004, 11:15 PM   #10168
danjoy25's Avatar
Trader Rating: 37 (100%+)
get the XXXmain booklet and explains the lot.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 10-20-2004, 12:06 AM   #10169
SMcpot's Avatar
Trader Rating: 22 (100%+)
Smile
Sorry if this question's been beaten to death, but can any of you that have owned TC3's and the SD offer any comparisons between the two?
SMcpot is offline   Reply With Quote
Old 10-20-2004, 12:58 AM   #10170
Handling and acceleration wise they're pretty even but the SD is tons easier to work on and it has more suspension adjustments.
RCTech #361
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
