Old 10-13-2004, 11:52 AM   #10036
Matt Howard's Avatar
when I played around with using the upper hole in the front castor block and spacing the steering knuckle up I didn't like it, For me the car felt very inconsistent. If you move your front shocks out on the tower you will get a more direct steering feel and more off power steering.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-13-2004, 02:05 PM   #10037
utieh's Avatar
Originally posted by Horatio
Pops - you're right. Final ratio is final ratio, makes no difference how you get there. Having a 2.5 internal ratio will just make the gearing more similare to a TC3. In other words you just end up using bigger pinions/smaller spurs to end up with the same gearing that you had before
Why would anyone want too?
This subject popped up before when someone made some ridiculous and un-substantiated claims about some gears he was selling. When roasted on the subject, he disappeared and took his lousy gears with him!!
Mystery solved!
The only reason I see is if the internal gear ratio is higher you will be able to use smaller pinion gears so the motor will be more centered (or perhaps it is the opposite ...i'm a little bit ill right now so Ican't think too much! )
utieh is offline   Reply With Quote
Old 10-13-2004, 02:45 PM   #10038
Horatio's Avatar
It's actually the opposite
Say you need to run 1:7.4 overall ratio. On the stock internal gearing (1:2.353) that's a 22 tooth pinion and a 70 tooth spur
70 divided by 22 = 3.18
multiplied by the internal ratio 2.353 = 1:7.4
Now to achieve the same ratio with an internal ratio of 2.5
25 tooth pinion on a 74 tooth spur = 1:7.4
This will place the motor considerably further outward (using a considerably bigger spur and pinion).
So all things considered, even taking into account motor position/weight distribution - you're still no better off getting a 2.5 ratio kit. Best stick with stock 2.353 gearing!!
Hope you feel better soon mate!
Horatio is offline   Reply With Quote
Old 10-13-2004, 02:58 PM   #10039
Default difference?
I know this may be an old topic but is there any difference between the Sd1 and the Sd3 other than one is silver and one is Black graphite?
Thanx
Mike
Keeebler28 is offline   Reply With Quote
Old 10-13-2004, 04:20 PM   #10040
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Default Re: difference?
Thanx
Mike
No difference except I heard the silver is more flexible than the black.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 10-13-2004, 09:21 PM   #10041
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
putting in this new motor and running tonight, my comm got pretty thrashed. i'm running 78t/48p spur - 23t pinion. i can't remember for the life of me if gearing higher means running a lower tooth pinion or a higher tooth pinion? at this point all i want to do is deal with different pinions and see whichone keeps the comm looking the best while still maintaining speed. i do know that springs and brushes can help in this dept. too.
now off to clean up this comm....
- jaYBee
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 10-13-2004, 09:23 PM   #10042
JayBee's Avatar
Post
here's the motor i'm speak'n of...
- jaYBee
Old 10-13-2004, 09:41 PM   #10043
Registered User
ritchie's Avatar
jaybee, you do have a gearing, problem, your way undergeared. your motor is running wide open for to long and thats why it burned. i'll pm you my phone number, call me and i'll tell you what gearing i used at FW and nats. also some tuning stuff for that motor.
ritchie is offline   Reply With Quote
Old 10-13-2004, 09:45 PM   #10044
- jaYBee
Its been a while since we ran an MVP motor, but for starts you should be running an MVP of somewhere between 6.8 to 7.2 and look at the comm and speed on the track. The final drive you have right now is 7.98. A 78t/26t will put you at 7.059 final drive ratio. So I would go up 3 teeth. If you go to gearchart.com you can make a printout of spur and pinion combinations.
pops is offline   Reply With Quote
Old 10-13-2004, 10:04 PM   #10045
JayBee's Avatar
Post
thanx pops
- jayBee
Old 10-14-2004, 12:56 AM   #10046
utieh's Avatar
so you can actually use smaller spur gears (not pinion gears) and have your motor more centered).
the guy (Leo Chan?) who posted about this Product D part never explained the benefits.
I'm better this morning (went ill because my boss is British and he forced me to drink tea with milk...I'm more a coffee guy)
Old 10-14-2004, 02:58 AM   #10047
sosidge's Avatar
Utieh, that is the WORST excuse ever for taking a sickie!
Old 10-14-2004, 03:10 AM   #10048
utieh's Avatar
my explanation lacks of details, it was a strange exotic tea and I added TONS of sugar and milk (I believe milk was the problem)
Old 10-14-2004, 05:49 AM   #10049
asw7576's Avatar
Guys.... do you know the effects of mounting suspension more vertical versus more incline / flat position ?
I'm thinking to set the rear suspension more incline / flatter than the front.
Old 10-14-2004, 06:07 AM   #10050
Horatio's Avatar
In theory, yep! But in reality you need the motor to help balance the weight of the heavy GP cells on the other side of the chassis.
As I remember he claimed 15 percent better performance, warding off of evil spirits, cooler running and higher libido!!
How else would you drink tea? You don't drink black tea do you? Urrrrrgh!
Personally I prefer coffee too.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
