Old 04-29-2003, 08:29 PM   #991
THeGame's Avatar
Send a message via AIM to THeGame
how close are the batts to the drive shaft, closer then the TC3s ?
how about setting the tweak, is the tweak off on the car bad ?
thanks
you got Aol or Aim ?
THeGame is offline   Reply With Quote
Old 04-29-2003, 08:36 PM   #992
JimmyMac's Avatar
Alot closer than the TC3. And much narrower. I think the Evo3 is a tad narrower or the batteries closer to center than the SD. Tweak, not that bad for mine at least. No AIM right now. Forgot to reload it in the puter. Only use Yahoo right now. Same name...
JimmyMac is offline   Reply With Quote
Old 04-29-2003, 08:37 PM   #993
Kenshin's Avatar
Originally posted by KilRuf
Damn is that a brand new G10?! Sweet! haha. I have one but it was in my Evo3. It might fit in there. You may have to mount the receiver on it's side. You can gain more room if you feel lucky and mount the servo like I did. Even with a standard sized servo you may gain alittle more room this way. But don't tempt it if you aren't comfortable with drilling and counter sinking 2 new holes in your chassis.
Yep it is. I got it at my lhs hanging behind some old stock servos. I don't think I am brave enough to drill new holes on the chassis. Everytime I do it, I end up taking out a couple grams off the chassis due to the big holes I end up making . I will try your tip on mounting the receiver on its side. Thanks.
Kenshin is offline   Reply With Quote
Old 04-29-2003, 09:02 PM   #994
Regional Moderator
Darkseid's Avatar
Those of you that have built your cars, I have a problem that I need help with.
I'm almost done with the car, but I've noticed that theres a notchy spot in the drive train. Its something with the front diff case. It only happens when I put the front diff case on. I've checked the gears and theres no debree in either gear. But every time I put the front case on the notch in one spot is there.
So, what should I do? Remove one of the shims behind the gear connected to the shaft? I know Mo and Matt said to build it just like the instructions, but I'm sure the instructions didn't intend for there to be a notchy spot in the drive train.
TLR 22...Tamiya F104...
Old 04-29-2003, 09:18 PM   #995
RBLove's Avatar
Trader Rating: 72 (100%+)
DARKSEID,
I know with the TC3 you had to play around with shimming the drivetrain to get the car free. Often times the diff cases fit too tightly. A little exacto and dremel action and that was solved. I would try different things or just leave it the way it is and run it in on your car stand. Put a motor in it and hook up a motor run. Might solve the problem and also break the gears in some.
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 04-29-2003, 09:21 PM   #996
mo
mo's Avatar
Make sure there isn't some flashing in the diff cases. Does it just happen when you tighten the screws down or as soon as you press the cover on? If there is nothing rubbing the gear, then I would remove 1 shim. Just make sure there is not too much slop in the gear mesh.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 04-29-2003, 09:29 PM   #997
Regional Moderator
Darkseid's Avatar
Well, heres what I got right now. I've found that if I lightly tighten the front diff cover, instead of tightening it good, then the nothchy spot is gone. Its on securely though, so I'll stick with it as it is.
mo: I checked the gears very well. No flashing. So I'll chalk it up to needing to not overtighten the front diff cover.
Old 04-29-2003, 11:37 PM   #998
I had the same problem but after the first day of racing it was smoth as silk. It should fix its self.
mugenracer is offline   Reply With Quote
Old 04-30-2003, 01:21 AM   #999
Blakesrc's Avatar
Send a message via AIM to Blakesrc
Default Rear Arms Binding
Hey guys, almost finished up assembly today and everything looks great except for some serious binding on the rear arms/inner hinge pin, anyone else had this problem? The stock setup calls for the 3 degree block and that one is really bad, if i try the 1 degree block the arms still dont drop under their own weight. Do i need to get a reamer or am i missing something?
Blake
Blakesrc is offline   Reply With Quote
Old 04-30-2003, 01:21 AM   #1000
johnbull's Avatar
Hi guys. Greetings from Malta.
You guys make me so jealous - all discussing the building and i haven't as much as seen mine yet, and won't for another week.
YOKOMO MMS.
I have one of these and use it frequently. In fact I have just about ditched the dyno and just rely on this for setting up my motors these days. It gives me more reliable and consistant figures than the dyno ever did, and it's so much easier to set up.
I definately recommend it.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 04-30-2003, 05:48 AM   #1001
SD Now officially in the UK-at last
The only place thats got them at the moment that I know of is dc racing.
Andrew
wizardmr4 is offline   Reply With Quote
Old 04-30-2003, 10:28 AM   #1002
rc-zombies's Avatar
Default HD blue aluminum dog bones from Tobee Craft
Tobee Craft just released HD blue aluminum dog bones for the SD. Part no. 42400 SD-04 price 800yen = $6.71USD.each.
Don't know if these will be available in the US...but I'm going to order some from Japan.
Old 04-30-2003, 11:07 AM   #1003
mo
mo's Avatar
Those look pretty nice. I wonder how they'll hold up. At least they are cheap. Where are you ordering them from?
Old 04-30-2003, 11:26 AM   #1004
rc-zombies's Avatar
Looks like they will hold up better than the YOK version.
Don't know if it's in stock yet or not...I've put in a request for it with RainbowTen in Japan...
I've got some Rayspeed o-rings and Bladders coming..hopefully next week from them also... they don't have the pistons or shock springs yet..hopefully soon.
Old 04-30-2003, 12:40 PM   #1005
mo
mo's Avatar
The word on the Rayspeed O-rings is "butter". I haven't run them yet but that is what I have been told by my sources..
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
