Old 10-11-2004, 03:30 PM   #10021
Matt Howard's Avatar
Originally posted by KoE
anyone have part no for bevel gear (to change internal ratio to 2.55)? thx
I believe that was a "Product D" part and not a Yokomo part.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-11-2004, 11:06 PM   #10022
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally posted by pops
I had a set of these (MIPs) on the rear of the CGM car and found that if I slightly overtightened them they would bind the bearings. If you do use MiPs be carefull. The Yokomo hardened ones are better in my opinion.
I'm gonna have to try those, but then again I'll just keep them as spares being that I've been fortunate in not breaking any parts.
Thanx pops...
- jaYBee
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 10-11-2004, 11:16 PM   #10023
JayBee's Avatar
Question about the servo mod... anyone know the approx. length of the turnbuckle to use?
- jaYBee
Old 10-12-2004, 12:58 AM   #10024
SpeedTech's Avatar
Hi KoE
If it is the product D item you're looking for, please give me an email, we got some in (just haven't updated them online just yet)
Thank you
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 10-12-2004, 09:03 AM   #10025
Originally posted by Sparx
I don't have either the alu motor mount or lightened chassis, i'm trying to get my hands on a motor mount though
The lightened chassis is only around 7-10 g's lighter and is mostly lightened on the electronics side which is too light in the original shape. So i did'nt get it.. Ti screws is definetly the greatest weight reducer.
If i don't remember wrong my stock CGM weighed around 1550-1560 depending on what inserts i used in tyres..
How much do u recon the ti screws reduced weight by
Chazz
Chazz is offline   Reply With Quote
Old 10-12-2004, 10:06 AM   #10026
Send a message via AIM to aoizip
hi guys...
need some help.. i just broke my turnbuclke in the
front. just wondering... where can i get the
Ti turnkbuckle? will the one from AE tc3 works??
any suggestions... thanks!
~ming
aoizip is offline   Reply With Quote
Old 10-12-2004, 12:03 PM   #10027
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Chazz
around 15 g's
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 10-12-2004, 04:54 PM   #10028
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Default Rayspeed V.2 conversion kit
Is this out yet?
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 10-12-2004, 05:25 PM   #10029
Default Re: Rayspeed V.2 conversion kit
Originally posted by danjoy25
Is this out yet?
Don't know, when I sent the pic that was posted on here to yokomo usa asking when it was going to be released, it was the first time they saw it as well. It will probably still be a little while before it's released.
RCTech #361
Old 10-12-2004, 07:43 PM   #10030
Originally posted by aoizip
hi guys...
~ming
Almost any good hobby shop or track should sell either sets of 2 or by each. I got some a couple of months back from Speedworld Raceway and Hobbies. Just measure the length of the broken one and order up a new one.
pops is offline   Reply With Quote
Old 10-13-2004, 08:23 AM   #10031
crabboy's Avatar
Trader Rating: 58 (98%+)
hey matt or pops i see there is a new bevel gear to change ratio of the sd to 2.55 what is the advantage if any
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 10-13-2004, 09:53 AM   #10032
I can't really see any difference, a final drive ratio is the final drive ratio? Some would say you can see a difference when you get to that final drive ratio with a larger or smaller spur gear / pinion gear combination. ie faster acceleration. But just changing the internal drive ratio, I don't know seems it wouldn't make much of a difference. I could be wrong though.
Old 10-13-2004, 10:36 AM   #10033
Horatio's Avatar
Pops - you're right. Final ratio is final ratio, makes no difference how you get there. Having a 2.5 internal ratio will just make the gearing more similare to a TC3. In other words you just end up using bigger pinions/smaller spurs to end up with the same gearing that you had before
Why would anyone want too?
This subject popped up before when someone made some ridiculous and un-substantiated claims about some gears he was selling. When roasted on the subject, he disappeared and took his lousy gears with him!!
Mystery solved!
Horatio is offline   Reply With Quote
Old 10-13-2004, 11:22 AM   #10034
The thing with that gear ratio change is only the bevel gears are new, it uses the same diff gear. That means the teeth on them aren't going to match up perfectly resulting in a very long break in time. If I remember correctly Mo used them when he ran for yokomo and he liked them, it just took a long time to break in.
RCTech #361
Old 10-13-2004, 11:45 AM   #10035
Matt,
Few questions hope you can help.
What is the handling differences between the upper hinge pin hole and lower pin hole on the C-hub?
Under what condition shall I use the most outer holes provided for the CGM shock tower for shock positioning? For more steering?
Knuckle position. Upper or lower. I notice Masami setup sheet used upper position most of the time but the manual used the lower position.
Thanks.
MIKA is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
