Old 10-07-2004, 12:00 PM   #9961
Trader Rating: 47 (100%+)
Does anybody know the ratings for the rayspeed springs, or were I can find that info?
And also a good starting droop setting, for carpet with say 60mm diamieter foams. on a CGM
porter is offline   Reply With Quote
Old 10-07-2004, 12:16 PM   #9962
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
Jason- I have a couple of Tosolini's carpet setups from last year on my home computer...can shoot you the info when I get home tonight.
You running at Hutch this sat? Stock or 19t choice?
Jeff
Jeff Werner is offline   Reply With Quote
Old 10-07-2004, 12:25 PM   #9963
Lonestar's Avatar
Originally posted by shooky
Another thing, I have heard that the reason my car glitches could be that I have the 93457 servo with the aluminum upgrade heatsink and that if the receiver wire is anywhere near it that the motor noice from the servo could cause the glitching. Does this sound like Hog wash to anyone else?
I just purchased a Hitec BB77 servo which is the low profile servo and I was wondering what kind of servos everyone else is running. I was also looking at the Futaba digital low profiles, but Hitec had better numbers and was alot cheeper. Any comments would be welcome.
there's so many things that can cause glitching, why not that one... Any metal vibration can be a source of trouble...
I run a KO 2113 7.2s fet servo... 0.06s for 60 deg, 130oz.in, woo-hoo! I've only had bad experiences with Hitec stuff, I quit buying their products a couple of years ago. I heard they made great improvements, but I'm still skeptical...
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 10-07-2004, 03:05 PM   #9964
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Paul
Thanks Paul,
I have just ordered a Futaba S9550 and it may be a bit slower than yours it is still fast and it is a metal gear ball bearing low profile servo with .11 s for 6 deg. and 86oz torque. that is enough I think for a TC. I will take my 93457 and make it my spare for my Inferno K3. I was still wondering were to buy those noise reducers than clip on the negative wires. Does anyone have a place to buy them and an actual product name. Thanks....
Stephen
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 10-07-2004, 03:37 PM   #9965
edseb's Avatar
Heh guys, been a while since I've touched mt SD. I have a question on gearing. I'm running 72 (all 48 pitch) tooth spur, and using a monster stock pro. What final ratio should I shoot for? I was thinking around 6.3 ish? BTW, the track is outside, decent traction and medium size and sweeping. I'll probably run a one-way, so braking will be low and not add heat.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 10-07-2004, 03:40 PM   #9966
edseb's Avatar
Actually 6.3 sounds too high, maybe around 7.0?
Carl Hyndman
Old 10-07-2004, 03:45 PM   #9967
Blakesrc's Avatar
Send a message via AIM to Blakesrc
Edseb,
I usually run as close as possible to a 7 with my monster stocks fyi.
Shooky,
I think that speedtechrc.com has the magnet clamps and i believe that yokomo was packaging them. Maybe give them a call.
Blake
Blakesrc is offline   Reply With Quote
Old 10-07-2004, 04:10 PM   #9968
edseb's Avatar
Thanks for the tip. I'll probably start with a 24 pinion and go from there. That gives me a final of 7.059.
Carl Hyndman
Old 10-07-2004, 05:19 PM   #9969
Tek Nickal's Avatar
I would start at 7.5, gear up or down from there.
Tek Nickal is offline   Reply With Quote
Old 10-07-2004, 09:31 PM   #9970
Registered User
ritchie's Avatar
don't know about droop, and on the spring rates, my chart is missing, but the ratings were posted a few pages back,
ritchie is offline   Reply With Quote
Old 10-07-2004, 10:52 PM   #9971
Blakesrc's Avatar
Porter, here ya go....
Yokomo
Spring Rating [lb/in]
Orange 18.87
Green 16.06
Pink 14.93
Yellow 14.71
White 12.94
Blue 12.12
Rayspeed
Gray 19.90
Red 18.26
White 17.17
Yellow 14.87
Blue 14.29
Green 13.20
Also, check out www.yokomo.tk for the carpet/foam tire setup, i havent had a chance to try it yet but its the only one i have been able to find.
Blake
Old 10-08-2004, 12:52 AM   #9972
Lonestar's Avatar
Thanks Paul,
Stephen
Stephen,
the 9550 is a great, bombproof product (actually it's WC in Surikarn's 414 I believe), and in the SD, when rotated, it really helps free up some space for the radio. As far as servo speed is concerned, some racers actually prefer slower ones... I know Jukka Steenari's tried some slower KO servos and he likes them better because it prevents understeer (the front tires don't slip because of too fast angle changes). I'm not Jukka and I like quicker servos better
btw... there finally are some pics of this last WE's race... last round of the Swiss Nationals... My Yoke took 2nd in the 17T class, it was on rails... The guy who took victory was an ex 12th scale national champion who did his come back in mid season after he quit for a few years... so I guess he was a worthy contender
Anyways, here are a couple of pics from a website that did a page on my car...
The car was absolutely perfect, stable but with a lot of steering. I used a funky front shock position, on a rear shock tower's body mount hole... front shock were near vertical and steering was *very* direct. The car was fantastic and gave a good run for their money to all the guys who sold their SD's when the Pro4 came out For those interested I can email a setup sheet (Orion's B-type rubber on carpet, 17T), it's too big to post here.
Later,
Paul
Old 10-08-2004, 12:57 AM   #9973
Lonestar's Avatar
Note the 5th body post, btw... just drill the shock tower and you're set. I thought it really helped removing parasitic body vibration effects...
Paul
Old 10-08-2004, 06:16 AM   #9974
mashimaro's Avatar
5th body post, hmm.. does that actually make a lot of differences?
mashimaro is offline   Reply With Quote
Old 10-08-2004, 09:01 AM   #9975
Lonestar's Avatar
yes it does... it prevents the body from flexing and rubbing on the front tires under heavy turning/breaking, it gives a tad more downforce on the front at high speeds, and best of all, it considerably lengthens you body's lifetime (no more front cracked fenders)... My paint jobs are average because I hate painting bodies... the less often the better!
Later
Paul
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
