Old 10-05-2004, 07:15 PM   #9946
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Default Re: TC-SD VGS MAIN CHASSIS
Originally posted by danjoy25
Check this chassis for the Yoke.
another view.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 10-05-2004, 11:16 PM   #9947
Matt Howard's Avatar
Thats the Team Hybrid chassis if I'm not mistaken
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-06-2004, 02:16 AM   #9948
chambalero's Avatar
Originally posted by pops
Well, I don't drive, I just wrench for my son Alex. He ran it last year in 19T and Stock on carpet. He liked it on carpet with rubber tires alot better than the SSG. He said he couldn't tell much of a difference between the RS and the CGM on carpet. But I think the CGM was a little better on carpet than both. He is going to run it again at the ROAR Region 12 Championships next weekend in 19T and run the CGM in Mod. This is race is on asphalt. It should be a blast.
Hey your son and I have the same name I hope you do well on the championships. We currently don't have a carpet track here in Manila Philippines, but there are 4 very nice asphalt tracks within an hour's drive from my home. Nobody uses the Rayspeed here anymore but there are a lot using the CGM. I'd appreciate it if you can give input with regards to the two cars on asphalt after the race. Again, good luck to both of you
chambalero is offline   Reply With Quote
Old 10-06-2004, 08:05 AM   #9949
Mr. Shookie's Avatar
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Originally posted by ritchie
check the coupler pins that connect the dog bones to the axles. loose ones will cause glitching
are you refering to the CVD's connection?
If so I have made sure they are built well and there is no loose pins around.
If you are refering to the center drive shaft I have installed the pins and have put the rubber bands around them also.
I do have the grafite drive shaft and I have tried so many other configurations and have still found there is glitching.
Is there a paint that eleminates radio interferance?
LOL
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 10-06-2004, 09:53 AM   #9950
Originally posted by tornado
You would be able to solve it by going to blades......no rattling noise.
Bryan
Blades????
Picture please.
I know CVD's I know Dogbones
the only blades was for anti roll.
I thought I have seen it all....
Old 10-06-2004, 07:46 PM   #9951
Registered User
ritchie's Avatar
LOL
the first one, cvd connection, i had a loose pin and it was driving me crazy until one day i changed to light weight axles and dogbones, and poof, my glitching was gone, if you search around on the yokomo site you will find (i can't remember the name right now) some type of tape and stuff to eleminate radio noise. they also have some little magnet deallys that go on the motor wires that are suppose to help also, good luck.
ritchie is offline   Reply With Quote
Old 10-06-2004, 08:37 PM   #9952
tornado
Guest
Posts: n/a
Blades????
Picture please.
Here is one more photo up close :
http://www.rctech.net/forum/attachme...postid=1124639
Bryan
Old 10-06-2004, 08:42 PM   #9953
tornado
Guest
Posts: n/a
LOL
Try using back the original aluminium center shaft and see whether that help to reduce glitch. A friend of mine who is a radio engineer or something told me that sometimes graphite shaft is the culprit. Its a process of elimination.
Bryan
Old 10-06-2004, 09:44 PM   #9954
A battery question from the.....
it's been years since I've done that in RC department.
Ok first of all you gotta remember I haven't had anthing to do with RC batteries since back in the day when a 1700mah pack was massive.
Anyway......
As I will be racing in 540 stock class I'm limited to 1500mah unmatched packs so to this end I purchased 7 Duratrak "shark" battery packs and even though cheap I think it's still a good idea to treat them right so have started to cycle them.
So the question is, is the following battery "behaviour" normal for the first one I've done....
Trickle charged for 17 hours resulting in a voltage reading of 8.46
Then pushed fast charge (4 amp setting) and the voltage shot up to 11 volts for a few seconds and then dropped to 10.5v
22 minutes later the fast charge switched off when the reading had dropped to 9.46v
At which time the reading then went back to the original 8.46 that it had been on when the battery had only been trickled for 17 hours.
The only thing any of this has in common from what I can remember of 1200 mah packs back in the day was that the battery got warm. But having never had a battery of even 1500mah I don't know whats normal for this size nowadays.
Mabuchi540 is offline   Reply With Quote
Old 10-06-2004, 11:28 PM   #9955
The voltage of the pack not hooked up to the charger will not give you any good information and I would not recommend trickle charging any battery. Charge at 4-5 amps and if you don't have a peak charger, monitor the pack, when the voltage starts dropping then it's reached it's "peak" and should be done.
RCTech #361
Old 10-06-2004, 11:40 PM   #9956
Unhappy My bad....
I should have said these readings were while the battery was still plugged into the charger (with the approriate led's flashing depending on charge mode)...if that makes any difference? Yes it is an automatic charger (a duratrax model).
Thanks for the advice...but may I ask why not trickle charging. I know it was a long time ago but back then it was always recommended to make the first one a trickle?
Old 10-07-2004, 12:20 AM   #9957
You want to charge your packs, even while cycling, like you'll charge them at a race. Same goes for discharging, try to match the amperage you think you're pulling during a race then discharge them at that rate. This will "train" your packs so they perform their best.
RCTech #361
Old 10-07-2004, 12:31 AM   #9958
Thumbs up Thanks :) saves me a lot of time watching the charger that's for sure....
Understood...so just try and find enough light bulbs/wattage to drain them in like 5-6 minutes?
Old 10-07-2004, 12:42 AM   #9959
yep, if your running a 540 class a 15-20 amp discharger will be plenty. Good luck!
RCTech #361
Old 10-07-2004, 08:05 AM   #9960
LOL
Another thing, I have heard that the reason my car glitches could be that I have the 93457 servo with the aluminum upgrade heatsink and that if the receiver wire is anywhere near it that the motor noice from the servo could cause the glitching. Does this sound like Hog wash to anyone else?
I just purchased a Hitec BB77 servo which is the low profile servo and I was wondering what kind of servos everyone else is running. I was also looking at the Futaba digital low profiles, but Hitec had better numbers and was alot cheeper. Any comments would be welcome.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
