Yokomo MR-4TC SD
Old 10-03-2004, 07:54 PM
  #9901
Mr. Shookie's Avatar
Default Glitching like MAD
Can anyone send me a picture of there setup so I can see where everyone puts there electric gear. I have tried three different setups and my RS still glitches like MAD. I have CA'd the chassis and have used fuel line to sheild the receiver wire and I want to rac3e my Yoko RS but I tried this weekend and IT GLITCHED BAD.
Thanks for the help guys.
Mr. Shookie is offline
Old 10-03-2004, 08:24 PM
  #9902
tornado
Guest
Posts: n/a
I'm running RS.....no problems with glitching so far (touch wood). Here is how "stack" up my electronics.
Bryan
Old 10-03-2004, 08:27 PM
  #9903
tornado
Guest
Posts: n/a
ooops the photo..
Old 10-03-2004, 08:46 PM
  #9904
Talking Or you might even want to do it.....
Originally posted by tornado
ooops the photo..
neatly
Mabuchi540 is offline
Old 10-03-2004, 10:08 PM
  #9905
JimmyMac's Avatar
My pic is on page 289... here is it http://www.rctech.net/forum/attachme...&postid=957763 No glitches with this car.
JimmyMac is offline
Old 10-03-2004, 10:09 PM
  #9906
Registered User
ritchie's Avatar
check the coupler pins that connect the dog bones to the axles. loose ones will cause glitching
ritchie is offline
Old 10-03-2004, 10:23 PM
  #9907
tornado
Guest
Posts: n/a
You would be able to solve it by going to blades......no rattling noise.
Bryan
Old 10-03-2004, 10:24 PM
  #9908
tornado
Guest
Posts: n/a
Default Re: Or you might even want to do it.....
Originally posted by Mabuchi540
neatly
Yeah thanks mate . I've been trying to solve that gob of wire mess for ages and thats the best I could do for now. .....too many wires.
Bryan
Old 10-03-2004, 10:37 PM
  #9909
Default Re: Re: Or you might even want to do it.....
Bryan
Nothing that a bit of "open the servo/esc and shorten the wires" wouldn't fix.
Edit: Hang on a minute, speaking of keeping things short I notice from your pic the nut that retains the top of the shock has thread from the screw sticking out beyond the nut. Is this normal?
On my CGM (I've not long finished) once the nuts are in place there isn't any thread sticking out.
Old 10-03-2004, 11:24 PM
  #9910
JimmyMac's Avatar
That's normal. The CGM shock towers are thicker than the RS or SSG/Black towers. There-fore the screw will not protrude out as far. If you notice in my pic... I use CGM shock towers on my RS chassis. The screws do not stick out past the nut.
JimmyMac is offline
Old 10-03-2004, 11:32 PM
  #9911
Thumbs up
Thanks dude, not really having spent much time (if any) looking at a SSG (to notice that) was wondering if perhaps I'd gotten shorter bolts by mistake.
Old 10-04-2004, 12:36 AM
  #9912
Lonestar's Avatar
Question for you guys.. does anyone know of any after market SD caster blocks that are 2?
Nope... only the stock 4deg parts that I know of...
Paul
Lonestar is offline
Old 10-04-2004, 01:51 AM
  #9913
tornado
Guest
Posts: n/a
Default Re: Re: Re: Or you might even want to do it.....
Oh...that part..yeah....I've no problem with that....just that the screws are longer I guess.
Bryan
Old 10-04-2004, 02:54 AM
  #9914
chambalero's Avatar
Bryan
hello! i noticed that you have rpm ballcups connected to the front rayspeed towers. did you have to put spacers behind the ballstuds connecting the ballcups? i noticed before that the turnbuckles sweep forward from the c-hub to the thin rayspeed towers. installing rpm ballcups will cause it to bind. i have considered getting longer ballstuds to install to the tower and place spacers behind the ballstuds, making the turnbuckles more horizontal when viewed from above. i gave up looking for the longer ballstuds do you know if yokomo sells longer ballstuds?
in the cgm this is not an issue because of the thicker towers. i can't recall how it looked on the ssg.
i have a cgm and a bnew ssg chassis with a rayspeed conversion set which i gave up on before i could even get running. i dismantled it and used it as a parts source for my cgm. but since the rayspeed is still much lighter than the the cgm, i'm thinking of assembling it again. i got interested with the rayspeed 2 chassis too
chambalero is offline
Old 10-04-2004, 03:06 AM
  #9915
tornado
Guest
Posts: n/a
I just use the normal black yokomo ball studs. Are these longer? I really dunno. Anyway I don't face those binding problems.
Bryan
