Old 10-01-2004, 12:56 PM   #9886
Default Re: I've just noticed that the.....
Originally posted by Mabuchi540
main drive shaft isn't running true (puzzled look) as it was rolling fine (rolled it over a flat surface to make sure it was straight) before I put it in place.
i think its the input shafts arent straight, wel the ones that come with the kit arent if you look at it from the side and spin the wheels slowly you wil notice that the drive cup itself goes up and down
The drive cups at either end perhaps? Anyone else notice this? Or is it a normal CGM/SSG thing that straightens out under speed?
agower is offline   Reply With Quote
Old 10-01-2004, 07:58 PM   #9887
tornado
Guest
Posts: n/a
You can be sure that those shafts are straight. Its the drive cups. There is bound to have some play as you fit it to the shaft.....so it'll' wobble on yah. Unless you could find an UJ joint to install else you'll just have to live with it. I did.
Bryan
Old 10-01-2004, 08:07 PM   #9888
Default Re: Re: I've just noticed that the.....
Bryan
So unless the cup and shaft were machined as one unit live with it huh? Just thought it might effect the efficiency of the drive train.
Mabuchi540 is offline   Reply With Quote
Old 10-01-2004, 08:10 PM   #9889
tornado
Guest
Posts: n/a
Default Re: Re: Re: I've just noticed that the.....
I've no problem with the efficiency issue...only the rattling noise.
Bryan
Old 10-01-2004, 08:54 PM   #9890
Matt Howard's Avatar
if the cup and the shaft were one unit then it would be like the tamiya evo III and you would break gears whenever you touched anything since there's no play back and forth.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-02-2004, 06:32 AM   #9891
Horatio's Avatar
Why not try some DIY pin cushions?
Horatio is offline   Reply With Quote
Old 10-02-2004, 01:06 PM   #9892
Tek Nickal's Avatar
Default Re: Re: Interesting CVDs
Yep! they're X-ray T1 cvd and one-way outdrives. If you're interested 'bout this conversion...just take note that T1's cvd's don't come in equal length...the front (pt no.305200) is slightly longer than the rears (pt no. 305300). I'm using the front cvds and they fit very nicely. You must also replace the yoks one-way outdrives to the X-ray ones too as the yoke on the x-ray cvds is larger and won't fit the yoks out-drive. Have fun!
Bryan
The CVDs fit? Wow, never knew that, gotta try that one. And the oneway out drives fit perfectly?
Thats good, since I have a lot of play from my CVD to my one way outdrives. Also my CVD pins are constantly coming loose.
Tek Nickal is offline   Reply With Quote
Old 10-03-2004, 09:34 AM   #9893
JJ187RC's Avatar
Default HInge Pins
Does anyone know where I can get some stronger hinge pins for the car? I am running the CGM car on graphite and the car is really handling good. I have a few minor adjustments to make, but I think the car is great. I am just looking for a little stronger hinge pin kit for the car.
JJ187RC is offline   Reply With Quote
Old 10-03-2004, 10:17 AM   #9894
Default Re: HInge Pins
As of now there is only one set available for the SD from Yokomo, and I don't know of any other aftermarket hinge pins available. I too believe they could be a little stronger.
pops is offline   Reply With Quote
Old 10-03-2004, 10:38 AM   #9895
JJ187RC's Avatar
Thanks Pops. If I find something or come up with something I will let you know as well.
Old 10-03-2004, 10:45 AM   #9896
I think yokomo sold some lunsford Ti hingepins for the old belt car. I'm not sure what sized would carry over but it's worth a shot. Pops, I think Billy had some at one time, they might be in the "bargain" bin now since they're older parts.
RCTech #361
Old 10-03-2004, 10:58 AM   #9897
kentech's Avatar
Arrow MR-4TC SD Rayspeed Ver. 2
Seems there's a Rayspeed version 2 SD in development...
source: RC Magazine
http://www.yaesu-net.co.jp/rcm/
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 10-03-2004, 11:06 AM   #9898
looks like there's an adjustable battery tray on it, nice. It's hard to tell what else is different on it though.
RCTech #361
Old 10-03-2004, 12:02 PM   #9899
If I remember right the ones for the arms are not long enough for the SD. The last set for the SD I got were marked HD, but seem the same as the orginals.
Old 10-03-2004, 06:07 PM   #9900
JimmyMac's Avatar
I like my RS chassis. It's what I use outdoors. I just hope the newer chassis allows the battery to be placed even more forward.
Question for you guys.. does anyone know of any after market SD caster blocks that are 2?
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
