Old 09-26-2004, 02:02 PM   #9796
Horatio's Avatar
Johnbull:
How do you rate the new GTX? I've yet to see one in action.
Regards
Horatio
Horatio is offline   Reply With Quote
Old 09-26-2004, 07:57 PM   #9797
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Originally posted by Matt Howard
I've got a couple of setups posted over at www.yokomo.tk these should work well, Speedworld is pretty much what you described your track to be, hot, 100 ft straight, and asphalt.
Matt Howard - Would those set-up work for foam tires as well> We have a similar asphalt track with long straights.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 09-26-2004, 08:31 PM   #9798
Matt Howard's Avatar
I don't know, I haven't driven with foams on asphalt in about 5 years. They should be close though from what I remember about it.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 09-26-2004, 09:40 PM   #9799
Blakesrc's Avatar
Send a message via AIM to Blakesrc
Default Spool or One-Way
Hey Guys,
I am still a bit confused about the spool vs one-way thing. Is the spool just something you choose if you are at a race that one-ways are not allowed or, is there a certain track layout situation it would help to have a spool instead of a oneway? I have only used a spool once, i almost always use a diff up front, and i really couldnt tell if there was any sort of advantage running it instead of the diff. Please let me know what sort of track condtions i should be looking for to use the spool, it seems to be a bit of a trend now so i would like to try using it some more.
Thanks,
Blake
P.S. I run mainly in stock and 19 turn if it makes a difference
Blakesrc is offline   Reply With Quote
Old 09-27-2004, 01:17 AM   #9800
johnbull's Avatar
BLAKE.
I have just this weekend been comparingone way and spool.
On my own on the track the one way may be very slightly quicker, but in traffic you need brakes so the spool definately scores.
That's unless you don't mind sweeping everyone off the track as soon as you get near them.
I'm staying with the spool. It's safer, and kinder to other drivers.
johnbull is offline   Reply With Quote
Old 09-27-2004, 01:26 AM   #9801
Blakesrc's Avatar
Joe,
would you mind emailing me your setup so i can compare mine to yours? Also, what is the surface and traction like on your track? Do you notice a lot of wheel chatter with your spool and what spool are you using? For some reason my front wheels chatter like crazy with the spool anywhere between 50%-full lock and could tell last time on the track it was causing binding in sharp turns.
Thanks,
Blake
Old 09-27-2004, 03:07 AM   #9802
Lonestar's Avatar
Default Re: CGM Steering setup on SSG CHassis?
Originally posted by Blakesrc
Hey Guys,
First of all, if sombody has a clear picture of an ssg chassis with the servo mounted 90 deg from stock i would appreciate it.
Also check that link out, it's an online review... tons of pics... rotated servo pics at the end of the page...
http://www.overrc.com/techniques/reg...omomr4tcsd.htm
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 09-27-2004, 03:09 AM   #9803
Lonestar's Avatar
Default Re: Re: Re: CGM Steering setup on SSG CHassis?
Originally posted by Sparx
I tried this with a long rod i had but the only change i noticed was that the steering went extremely sloppy...
Is it anything else i have to do to make it non-sloppy?
try two servo-saver assemblies... at least the slop becomes symmetric. some forum members and myself have conflicting views about this, but I use it and it works
Later,
Paul
Old 09-27-2004, 03:24 AM   #9804
Blakesrc's Avatar
Lonestar,
thanks for the link, i actually found some pics online that allowed me to get the 90 deg servo setup working for racing yesterday. I also saw some pictures of dual servo savers/bellcranks and assumed it was to even out the slop as you mentioned. Currently i have the stock bellcranks on the car and wow the right side has a ton of slop! I am going to mount the cgm steering bellcranks tomorrow and see what they are like.
Blake
Old 09-27-2004, 04:05 AM   #9805
asw7576's Avatar
Hi, I'm thinking to mod my brokomo with TRF 415 / TA04's suspension arms, C uprights, steering turnbuckle, hinge pins, wheels ball bearings, dog bones. Actually the whole suspension arms set will be replace with Tamiya parts.
lee82gx:
I've been to KL, Malaysia few times, nice F1 circuits u got there.
I'm impressed with the sound of F1 engines screaming super loud at 18,000+ rpm. I have to covered my ears even with ear plugs on Really awesome stuffs..... I also can hear the traction control in action after pitstop.
Last pitstop for Michael Schumacher
Michael Schumacher won 1st at Sepang F1 2004
Old 09-27-2004, 04:49 AM   #9806
lee82gx's Avatar
asw7576:
nice pic..
too bad i can't afford an F1 ticket,let alone grandstand...
lee82gx is offline   Reply With Quote
Old 09-27-2004, 05:33 AM   #9807
Lonestar's Avatar
Is it a direct fit, and does the car fit in the tech box after that? Show us the pics once you're done... this could be interesting. I doubt this will be more robust... plastics are plastics, you know... frankly, the SD doesn't break any more than other cars...
Blakesrc: yes, the dual bellcrank setup does cure the extra slop on the right due to bearings being closer to each other than on the left side. HOWEVER be sure do this mod first and THEN rotate the servo, because the extra bellcrank does eat up some space and could rub on the servo arm... Well it's too late anyway...
Later,
Paul
Old 09-27-2004, 07:46 AM   #9808
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Default Re: Re: Re: Re: CGM Steering setup on SSG CHassis?
Later,
Paul
Ehum, i had double servosavers on my SSG but not on my CGM who does'nt use any servosaver at all besides the servomounted, sorry for being too indistinct (hope it's the right word
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 09-27-2004, 07:52 AM   #9809
Regional Moderator
daniz24's Avatar
Wow, what is this?
The Yokomo Japan site last updated is July 28. It is already 2 months now. Are Yokomo stop making any development on their cars at this moment or they will come up with something new? Isn't there any news for the delayed new Yokomo 1/10 Nitro car?
daniz24 is offline   Reply With Quote
Old 09-27-2004, 08:06 AM   #9810
Originally posted by daniz24
Wow, what is this?
Last I heard about a month ago, the new nitro sedan was put on hold. They did run some prototypes but for some reason not known to myself, the project has been shelved for the time being.
RCTech #361
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
