Old 09-21-2004, 01:57 PM   #9751
Default Re: CGM Steering setup on SSG CHassis?
Originally posted by Blakesrc
Hey Guys,
First of all, if sombody has a clear picture of an ssg chassis with the servo mounted 90 deg from stock i would appreciate it. Now, i have been looking at my ssg and cgm steering bellcrank systems and it looks like they have the same geometry and are interchangable, anyone know if the cgm bellcranks will work properly on the ssg chassis setup?
Thanks,
Blake
I not sure about this one but you could try to bolt the cgm chassis on top of the ssg chassis if you find any hols that are in the same positions on the two chassis. My guess would be the screwholes that holds the gearcases (Note these holes are 4mm) would be the same but I'm not sure.
Then you could see if it would be possible to drill new holes for the CGM steeringposts in the SSG chassis by using the
holes in the CGM chassis as a guide.
moonman is offline   Reply With Quote
Old 09-21-2004, 04:25 PM   #9752
JimmyMac's Avatar
I thought I read several pages back that if you use the CGM steering on the SSG, it will give better steering ackerman. I think Masami was using this setup for a warmup race for the Worlds.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 09-21-2004, 04:51 PM   #9753
forty6's Avatar
Hey Guys,
Thanks,
Blake
forty6 is offline   Reply With Quote
Old 09-21-2004, 05:21 PM   #9754
JayBee's Avatar
Trader Rating: 31 (100%+)
Post Re: Re: CGM Steering setup on SSG CHassis?
Originally posted by forty6
Awesome pic... just what the doctor ordered, I've been looking to do this, THANX ALOT MAN. By the way... where did you get the lil' blue thingies under your top deck screws?
- jaYBee
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 09-21-2004, 08:45 PM   #9755
tornado
Guest
Posts: n/a
Default Re: Re: Re: CGM Steering setup on SSG CHassis?
- jaYBee
You could use the ones made for the Cudas. I'm using it.
Bryan
Old 09-21-2004, 09:52 PM   #9756
Registered User
ritchie's Avatar
jaybee, i believe they have those downtown, racers edge product. also in red
ritchie is offline   Reply With Quote
Old 09-21-2004, 10:32 PM   #9757
JayBee's Avatar
SWEET... Thanx ritchie & tornado
By the way ritchie, how have you been... haven't seen you in awhile.
- jayBEE
Old 09-22-2004, 01:50 AM   #9758
johnbull's Avatar
Hey Guys,
Thanks,
Blake
Blake.
Here are a couple of pics of how I did it.
I now run a CGM chassis and have mounted the servo rod straight to the rear of the left steering lever. Masami does the same with his. Sorry I haven't any pics yet.
I have to say, this CGM is the best car I have ever had. It gets better every day.
johnbull is offline   Reply With Quote
Old 09-22-2004, 01:51 AM   #9759
johnbull's Avatar
Here's a front end close up.
Old 09-22-2004, 01:54 AM   #9760
johnbull's Avatar
A better one of the way I linked the steering rod.
Old 09-22-2004, 01:58 AM   #9761
johnbull's Avatar
Originally posted by Horatio
I'm liking the sound of this. Performance and less maintenance - sounds too good to be true.
HORATIO.
I can confirm what others have said.
I run between 10 and 15 runs with an 8 turn mod before changing brushes and skimming. That's using a V2 endbell on a conventional motor.
Old 09-22-2004, 02:37 AM   #9762
ali_g's Avatar
does it reduce the slop? or better ackerman
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 09-22-2004, 07:29 AM   #9763
Horatio's Avatar
Originally posted by johnbull
HORATIO.
Johnbull:
Cheers for your input - much appreciated. I think the decision to use 19t spec control motors for our local winter champs is a really good move. It nearly happened last year, but now these new 'wonder' motors are on the shelves, there's absolutely no reason to stick to 27t. I can't wait.
Horatio is offline   Reply With Quote
Old 09-22-2004, 08:12 AM   #9764
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Default Re: Re: CGM Steering setup on SSG CHassis?
I tried this with a long rod i had but the only change i noticed was that the steering went extremely sloppy...
Is it anything else i have to do to make it non-sloppy?
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 09-22-2004, 11:21 AM   #9765
Blakesrc's Avatar
Send a message via AIM to Blakesrc
Thanks everyone for the pictures and help with the 90 deg servo steering mod. I havent tried putting the cgm steering bellcranks in the ssg car yet but when putting one bellcrank on top of the other they look identical as far as hole placement etc. I think that maybe if using the cgm steering the front end might have a little less slop, only thing you would have to do is make some sort of spacer to put on top of each bellcrank inbetween the bellcrank and top plate.
Blake
Blakesrc is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
