Old 09-14-2004, 10:02 PM   #9721
Tek Nickal's Avatar
Originally posted by KilRuf
I prefer CGM towers. On my RaySpeed Chassis...
Do a trade.
Tek Nickal is offline   Reply With Quote
Old 09-14-2004, 10:06 PM   #9722
with all the talk of shock towers I wanted to show you the ones that I made, I believe that they offer the best options for both shock mounting and camber link adjustment.
Fantom, BL Racing, Retired
jimnew is offline   Reply With Quote
Old 09-14-2004, 10:07 PM   #9723
Tek Nickal's Avatar
Wow, if I paid you would you make a pair for me?
Old 09-14-2004, 10:11 PM   #9724
That might be a possability
The one on my car is 3 mil thick and I only use it on the front because I feel that the stock rear CGM tower is better
Old 09-14-2004, 11:14 PM   #9725
Registered User
ritchie's Avatar
Default Re: pops!!!!
Originally posted by lem2
Thanks!!! I guess that is an expensive option to take since I have to buy additional stuff!
If I go for the Old RS Towers do I still need to change to sss(short). Maybe ti further lighten up my CGM I will just go with the Yokomo CF Towers from the Black special so that no ned to by additional shock parts.
or you could just use the long shock ends
ritchie is offline   Reply With Quote
Old 09-15-2004, 01:38 AM   #9726
johnbull's Avatar
Hi friends. Greetings from Malta.
The old style Rayspeed towers are pretty versatile. You can run virtually any shock with them. All you need to do is vary the lower ends. I run mine with the long ends front and rear and have plenty of travel and droop adjustment.
As for tyres, our track is very hard on tyres. Sorex 28s grip well but wear terribly and are very noisy. ING we have tried too. They last but don't give as much grip as Sorex.
The best all rounder we have found is the TakeOff in either 22 or 27.
We have just introduced a new class to our championships here. This is for pre 2000 non shaft drive cars, so I am resurecting one of my old YR4s. It's designed to be a cheap class - cheap control motor, cheap speedos and servos only, and 10 minute races.
Should be fun. Good thing I've still got plenty of YR4 parts.
johnbull is offline   Reply With Quote
Old 09-15-2004, 03:23 AM   #9727
Lonestar's Avatar
Awsome... too bad I sold my Schum Axis, that car rocked... and I don't live in Malta either
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 09-15-2004, 10:12 AM   #9728
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Post My new CGM
Hey all,
Iím a first time poster to this group, but reading this group convinced me to buy Yokomo...
I just bought a CGM and it is going together well. But during the build I noticed that the stock input shafts are HEAVY. Are the aluminum shafts significantly lighter?
Also, I shimmed the drive shaft per the manual but the drive train seems to stick at points. I tried different combos but nothing is as smooth as I'd like. Does anyone have any tips for shimming the input shafts/diffs? The problem seems to be with the rear gear box.
Thanks!!
PitNamedGordie is offline   Reply With Quote
Old 09-15-2004, 11:10 AM   #9729
Horatio's Avatar
Welcome to the thread!
The SD is a great car and nice to work with. The CGM Variant is no exception. Your transmission will feel a little tight when first built. However, from what you've said it's worth checking to make sure all the bearings are properly seated and that the bevel input bevelled pinion are pushed all the way onto the input shaft.
Once you've established everything is as it should be, turn the transmission over by hand. It may feel less than perfect at this stage, but it shouldn't take any undue amount of effort to turn the gears.
Just like any shaft driven car, the gears really benefit from being bedded in before racing. Some do this on the bench, others just do a couple of laps with a modified motor bolted in
The result should be a much more free transmission.
Hope this helps!
Horatio is offline   Reply With Quote
Old 09-16-2004, 02:57 AM   #9730
Lonestar's Avatar
Hi PNG
welcome to yokoworld! This thread might not move as quick as some others on this forum, but the signal/noise ratio is also higher (although in some cases.... ahem)
Anyways... The SD is a very satisfying car, and once you get its tranny setup right it's a dream for efficiency and maintenance.
Tranny shimming: First check that the bearing are fully seated on the input gear, and I mean FULLY. it's a TIGHT fit and very easy not tu push them in 100%, we've all done this mistake, and then wondered why the heck the transmission was binding!!! Check that first. Stock shimming is a bit tight, but doesn't bind if assembled right.
Shim as per instructions, don't use any lube, unhook the dogbones (pop out camber link balls) and run it on the stand with an older motor for a few hours under 3 or 4 Volts (or a 4 cell pack). I do this on a T30 for 4hrs. The tranny feels very different after that, and the motor pulls considerably less current, which means it's "freeer".
If needed, once finished you can also remove shims, but only if you know what you're doing... I shim in order to get minimal play, both on the diffs and the input shafts. The trick is to find the correct shimming that guarantees minimal play and no binding. Since all parts are a little different from kit to kit, you have to experiment. I usually end up with both shims on the diff, but one less shim on the input gear. You also need to check gears more often fro stripped teeth if not running the "full" shimming.
I also recently switched to the graphite gears (which are only slightly more expensive) and they also make a big difference in noise (which means saved energy). Plus they're way stronger, which allows a little more play without stripping teeth.
Stock steel input shafts: yes they are a bit on the bulky side, but as long as your tranny isn't 99% perfect it's not worth changing them... If you feel the need to go ahead, Tobee Craft's lightened Al shafts are perfect for the job, and reasonably cheap (around 10-12 bucks). Plus the bling factor's always cool! When I put them on, I *think* I felt stronger accelerations, but it might just have been my brain playing tricks on me... nothing spectacular.
Enjoy the car,
Paul
Old 09-16-2004, 11:52 AM   #9731
Thumbs up
Thanks Lonestar and Horatio...
Your input was a great help. I will be breaking in the drive train tonight. The car is very solid; it's built like a tank...no flexing.
Can't wait to run it this weekend!
Thanks again...
Old 09-16-2004, 10:15 PM   #9732
Registered User
ritchie's Avatar
Default Re: My new CGM
Originally posted by PitNamedGordie
Hey all,
Thanks!!
what i think it is is the outdrive cups on the diff rings, i assume the when you rotate the tires you get one full turn and then a little "stick" and then one turn and another one, what this is the the little bit of flashing you didn't tirm on the outdrive cup where it came apart from the parts tree. it is almost impossible to see with the diff together and even harder to trim assembled. take the diff apart, run your finger around the edge you will feel the flashing, trim it with the razor and you should be good to go,,, hope this helps
don't ask how i know this, but it took me about a hour to figure out,
Johnbull, thanks for the info on the tires. most guys are using the sorex 32 with the thin yok firm insert, and it works well, the ing tire new to this area, but from what i have seen its works very well on our track, its sealed pavement with poor traction until we spray grape soda down,
Old 09-17-2004, 04:43 AM   #9733
Lonestar's Avatar
Default Re: Re: My new CGM
interesting... I had never thought about that one... will have to check it out...
Paul
Old 09-20-2004, 10:56 AM   #9734
IH
IH's Avatar
Hi guys!
Does anyone have a good setup for Sorex28 on carpet ( for CGM)?
Thanks for your input
IH is offline   Reply With Quote
Old 09-20-2004, 11:18 AM   #9735
Yeah, I have the same question as IH, Sorex 28 on high grip carpet. Especially what insert? I try HPI green, but the car wants to traction roll in hairpin corner. Please help!
caveman is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
