Old 09-05-2004, 07:49 PM   #9646
Default Re: Re: Mmmmmm........
i took a old motor mount from a ofna car, screwed a motor to it, and cut it down to a round shape same as the motor, now i have a motor spacer to move the motor forward a few mm's. it also helps keep the motor cool . [/B]
Cool thanks, will look into something along those lines.
Mabuchi540 is offline   Reply With Quote
Old 09-06-2004, 02:00 AM   #9647
Lonestar's Avatar
raving monkey, the car is fine box-stock.
Just throw away the center deck, and use countersunk screws on the top deck and shock towers in order to minimize tweak intake on hard hits. No need to countersink the SSG parts, it works even better without doing it, just use countersunk heads, the centering is even stronger.
The stock battery bar is fine, no need to use tape, plus it's still relatively light. Two nice but not indispensable hop-ups are Tobee's adjustable battery post ($10) and battery retainers ($5) to secure the battery as well as possible. But the battery very seldom flies off the car.
A useful and inexpensive option ($10) is the widened front bumper. But even with the stock bumper, the car is just as robust as anything else on the market.
Other than that... break-in the transmission with no load (ie unhook the UJ's) at 4V during a few hours... and the car is super smooth! There's tons of options for it, but they're not really needed, besides a spring set of course!
Later,
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 09-06-2004, 03:56 AM   #9648
Matt Howard's Avatar
Originally posted by ritchie
matt, did you ever get in contact with sprout.
nope, I sent him a PM awhile ago and he's hasn't read it yet and he has his email addy hidden on here.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 09-07-2004, 02:35 AM   #9649
Lonestar's Avatar
bump... come on guys, have yall forgotten the SD?
Paul
Old 09-07-2004, 03:41 AM   #9650
johnbull's Avatar
Paul.
It's probably because our cars go so well out of the box that we don't need to be asking this and that all the time.
johnbull is offline   Reply With Quote
Old 09-07-2004, 03:58 AM   #9651
Lonestar's Avatar
Originally posted by johnbull
Paul.
Joe... how true, how true... Mine still kicks some booty, but I haven't run it for a little more than a week. I'm spending all the afternoon at the track tomorrow though, I need my fix!
It's just sad that I'm only of the last competitors running one here. Because of the local importer, most racers have switched to the Pro4 in our area... From what I see, the Pro4 *might* be marginally faster for the top 0.01%guys... however most aren't any faster, they just have more trouble with the car, which is a PITA to set up and maintain!
Later,
Paul
Old 09-07-2004, 05:17 AM   #9652
Horatio's Avatar
The SD is really nice and easy to work on.
If it wasn't, alot of us would have given up on the car long ago
Horatio is offline   Reply With Quote
Old 09-07-2004, 05:27 AM   #9653
Quick question for anyone running a CGM with two diffs.....
It's been a while since I've been in RC and unfortunately even longer since I've had a 4wd (even then it was off-road lol) so just wondering if.....
and based on the assumption that the diffs (both at the front and rear) should be just tight enough to not slip under acceleration....
is it normal for the rear diff to end up tighter than the front on a CGM to get this effect?
I seem to recall from those 4wd I have had that both front and rear usually ended up feeling the same.
Thanks in advance?
Old 09-07-2004, 06:34 AM   #9654
Horatio's Avatar
I suppose that varies depending on how you drive. My diffs are set up not to slip under normal acceleration on carpet. It is possible to run diffs slightly tighter or looser to alter the diffs action, but the margin to do this is quite small. Too loose and the diff will slip. Too tight and you'll break diff bolts on a regular basis.
So long as your diffs are nice and smooth and does not slip - it's right!
Old 09-07-2004, 09:36 AM   #9655
Midnight's Avatar
Trader Rating: 85 (100%+)
I usually run my front diff tighter than the rear to have more on power corner speed.
RC8T; Losi 2.0B; FT T4; AKA & RB
Hoffman Photography, www.carolinasrc.com
Midnight is offline   Reply With Quote
Old 09-07-2004, 08:56 PM   #9656
Registered User
ritchie's Avatar
me too.
ritchie is offline   Reply With Quote
Old 09-08-2004, 03:46 AM   #9657
TYPE_ONE's Avatar
Default yokomo wide bumper
just a quick question.....do you guys trim the yokomo wide bumper to fit ur bodies???
TYPE_ONE is offline   Reply With Quote
Old 09-08-2004, 08:29 AM   #9658
Default Re: yokomo wide bumper
Yup, it's really wide and will stick out the side of your body if you don't.
RCTech #361
Old 09-08-2004, 09:48 AM   #9659
mo
mo's Avatar
Matt is a doodie head.
Got Chipotle in Korea?
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 09-08-2004, 09:54 AM   #9660
uhhh, no chipotle in korea, I'll have to talk to Tom about that
RCTech #361
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
