Old 09-01-2004, 11:56 PM   #9601
utieh's Avatar
From the CGM to the RS or SSG/Black you will need half of the A-arms mounts (on the CGM they are the separate ones), if you don't have them already from a previous SD you owned...
utieh is offline   Reply With Quote
Old 09-02-2004, 01:01 AM   #9602
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
I think I know what you mean, might get the alloy ones then.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 09-02-2004, 02:46 AM   #9603
danjoy25's Avatar
Default Another ?
Does anyone know how many degrees a stock front steering hub from a CGM kit has?
Old 09-02-2004, 02:50 AM   #9604
Lonestar's Avatar
I'm assuming 4 deg, like the SSG...
later,
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 09-02-2004, 09:08 PM   #9605
Matt Howard's Avatar
Default Re: Another ?
all the castor blocks are 4 degrees, that's the only one for the car right now
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 09-02-2004, 09:18 PM   #9606
danjoy25's Avatar
Recent got the option below and is different from the stock hub carrier of my CGM:
SD-4134G MR-4TC SD 4 DEGREE GRAPHITE FRONT STEERING HUB CARRIER
Caster looks the same but the holes for the kingpins are different location. Did anyone notice this?
Old 09-02-2004, 09:52 PM   #9607
You might of got the inline steering blocks, there should be a # on the arm part, either a 1 or 0. 1mm offset is the stock one and the 0 is an inline hub that will give you a little more steering.
RCTech #361
Old 09-02-2004, 09:56 PM   #9608
danjoy25's Avatar
Default hub carriers?
I will check when I get home and will post pics of both?
Old 09-02-2004, 10:02 PM   #9609
If you're talking about the part where the front bearings go in (steering blocks, front knuckles, front hubs, whatever else their called worldwide), there are different ones. If your talking about the castor blocks then I have no idea.
RCTech #361
Old 09-02-2004, 10:29 PM   #9610
danjoy25's Avatar
Default C-Hubs
I am talking about the C-Hubs ,the one the holds the steering knuckles. I will post pics later and show you the difference.
Regards,
Old 09-03-2004, 01:04 AM   #9611
johnbull's Avatar
The only different C hub I know of is the original belt drive MR4 version. You can get those in almost any degree of caster, and YES you can fit them on the SD.
I tried 5 and 7 but went back to the original 4 degrees with the 0 offset hubs and like it best that way.
MATT. How are you getting on in Korea. Found any RC hot spots yet ?
johnbull is offline   Reply With Quote
Old 09-03-2004, 05:36 AM   #9612
Lonestar's Avatar
Default Part number?
Hey Guys,
I kinda need some help here... I'm looking for the part number of the plastic pillow ball that the shock cap (on top, then) moves on... basically a plastic ball, flanged, with a 3mm hole in it... the part number is not on the exploded view (at least I can't find it...
Anybody?
Thanks!
Paul
Old 09-03-2004, 05:51 AM   #9613
johnbull's Avatar
Paul.
I think that pillow ball comes with the pack of plastic shock parts.
Yoke make some smart alloy ones you may be interested in.
How's RC racing in Switzerland.
Old 09-03-2004, 06:17 AM   #9614
Korea is fine, but the nearest track is 140 miles away and the bus schedule will make it a two day event if I do go.
RCTech #361
Old 09-03-2004, 07:14 AM   #9615
lem2's Avatar
Default Re: Part number?
Originally posted by Lonestar
Hey Guys,
Anybody?
Thanks!
Paul
Yes the manual does not indicate a part number, you can use the ones in the TC3, or in the Tamiya Adjustable Balll Connector for Damper made of Delrin Item# 53488 Part#OP488
If still not avialable you could order the ones from RC-Square.com at RT.
lem2 is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
