Yokomo MR-4TC SD
Old 08-24-2004, 03:58 PM
  #9511
Tek Nickal's Avatar
Originally posted by Lonestar
sometimes people read posts a little too fast... we can all misread a question!
Later
Paul
Doh'!
Tek Nickal is offline
Old 08-24-2004, 06:30 PM
  #9512
Horatio's Avatar
Originally posted by AzNDRAGster
Doh'!
We still know that you know your stuff
Horatio is offline
Old 08-25-2004, 12:20 AM
  #9513
my list of cars is alot shorter than your:
schumacher cougar 2000
tamiya mini cooper m-chassis
losi xxx
schumacher axis 2
yokomo ssg
thats in order from oldest to newest although i am stil running the xxx
agower is offline
Old 08-25-2004, 01:28 AM
  #9514
Anti roll bar question.....
So I'm up to the anti roll bar part and the kit includes two roll bars one silver and one black but the instructions don't say which one goes to the front and which to the back?
Or should I get another two and have two the same? If it helps the tires I'm starting with are G2's and the suspension is kit standard setup with the motor being a 540 stock of course.
Thanks in advance.
Mabuchi540 is offline
Old 08-25-2004, 03:37 AM
  #9515
highwayman's Avatar
hi, i have been running my CGM for about a month now, and i would just like to ask if anybody has played around with the 2 different mounting holes of the rear upright and front c-hubs? what are the effects?
thanks - jason
highwayman is offline
Old 08-25-2004, 04:04 AM
  #9516
are you talking about the outer hinge pin mounts. If so these are for roll center adjustments.
shortygy is offline
Old 08-25-2004, 04:58 AM
  #9517
Horatio's Avatar
losi xxx
schumacher axis 2
yokomo ssg
Just give it time...........
Horatio is offline
Old 08-25-2004, 07:41 AM
  #9518
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Trend???
I saw at the ROAR Nats that Billy Easton ran the SSG the entire weekend. Now when looking at the pics of the PreWorlds race from Florida this past weekend...saw where the Yoks were the SSG as well. Has Yokomo gone back to the silver car? I know the Dual deck cars have been doing well lately at big events. I liked my SSG a bit better then the CGM. Any scoop on what yokomo is going to run at the worlds?
Jeff
Jeff Werner is offline
Old 08-25-2004, 07:55 AM
  #9519
Horatio's Avatar
Maybe they've sorted out the weave problems on the SSG. Then they'll have a car that's much like the RS, only silver. Nice!!
Horatio is offline
Old 08-25-2004, 11:00 AM
  #9520
sosidge's Avatar
thanks - jason
You should never need to use the upper hole in the rear uprights.
At the front though, it's almost essential to run the car with the alternative lower hole. This raises the roll-centre, and makes the car much smoother on the steering and more balanced handling-wise.
You should raise the inner camber link position when doing this to keep the geometry sensible. I also run spacers under the inner steering arm balljoint to stop bumpsteer.
sosidge is offline
Old 08-25-2004, 11:08 AM
  #9521
forty6's Avatar
Originally posted by Jeff Werner
Trend???
Jeff
Based on the pictures, it looks like Masami ran a standard SSG. No fancy one-off YMP parts like at the 2003 RROC and Jpn nationals. Billy E. ran the same SSG chassis too but with countersunk topdeck and what looks like RS shock towers.
forty6 is offline
Old 08-25-2004, 01:05 PM
  #9522
What chassis Masami ran at the Preworld, CGM or SSG, I saw the pictures, two SSG , one from Billy Easten, the other car had some green anodise parts, but with x-ray's springs, I'm not sure who ran that car. Also that car had a different rear suspension set up. It had thick spacers under the arm mounts and upright's ball studs, use the "upper'' inner camber holes on shock tower. Anyone has any ideas?
caveman is offline
Old 08-25-2004, 01:53 PM
  #9523
Midnight's Avatar
Trader Rating: 85 (100%+)
Default Re: Anti roll bar question.....
Thanks in advance.
If you look inside the instruction manual there is an adend. page that talks about using standard servo arms instead of the servo saver, and pivot mounts. Anyway use the black on the back and silver on the front as per instructions. Personally I would try running without the sway bars.
Midnight is offline
Old 08-25-2004, 03:16 PM
  #9524
What is the biggest spur gear 48pitch that you use in SD? Today i mounted to my SD SSG 86t and like to know if it is possible to mount bigger one.
dicort is offline
Old 08-25-2004, 04:22 PM
  #9525
Default Re: Re: Anti roll bar question.....
Well yes there is an extra page that came in the box with what I assume are amendments to the manual BUt it's all in Japanese.
