Old 08-15-2004, 01:36 AM   #9391
OHBRAD's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to OHBRAD
Default Question
Hi guys,
On the setting sheet for cleveland indoor championships, chris tosoloni used 4mm plastic shims on shock shafts as bumpstops.
I am currently racing on a concrete track that is bumpy, and i seem to struggle with cornering etc and loss of speed.
Can anyone suggest what Chris was meaning about the 4mm plastic shims and where would they go. or does anyone have suggestions for bumpy tracks that works on the SD
Rgards brad
Yokomo BD818 | Sanwa | HW | Zombie | Team Yokomo | Meakin Park | Bayside | Hearns Hobbie | SpeedyRC
OHBRAD is offline   Reply With Quote
Old 08-15-2004, 05:04 AM   #9392
The bump stops just go on the shaft outside of the shock. Take off the shock end and slide them on. This I believe is to limit downtravel ..... maybe so the car leans less... not to sure maybe somone else could elaborate.
Greg
shortygy is offline   Reply With Quote
Old 08-15-2004, 05:09 AM   #9393
chambalero's Avatar
HI GUYS!
I have a new Rayspeed SD and I can't test it yet cos it's raining daily. Anyway, just wanna ask if the Rayspeed has any tweak issues. I'll be using mod motors for it. Thanks!
chambalero is offline   Reply With Quote
Old 08-15-2004, 09:29 AM   #9394
Originally posted by chambalero
HI GUYS!
There is some tweaking with the Rayspeed, more on carpet than on asphalt. The Rayspeed didn't tweak half as much as the SSG. CGM no real problems at all.
pops is offline   Reply With Quote
Old 08-15-2004, 11:43 AM   #9395
Default rayspeed
with the rayspeed whats the need of having two servo savers?
and can you take one off them of so its like ths original ssg with the plastic tube bit?
agower is offline   Reply With Quote
Old 08-15-2004, 12:50 PM   #9396
Sleighty's Avatar
I think it reduces play in the steering
A1-RC.com
Team Scream
Xray
Sleighty is offline   Reply With Quote
Old 08-15-2004, 01:09 PM   #9397
johnbull's Avatar
I really can't get over just how good this car really is.
I ran another 3 packs yesterday and it seems to get better with every run. It's so much more consistant and so much more easy to drive.
It has improved my lap times slightly but my race average lap times greatly, which is what it's all about.
I don't know why it took me so long to go CGM.
johnbull is offline   Reply With Quote
Old 08-15-2004, 05:13 PM   #9398
You are so right Johnbull.. I don't think the extra weight hurts the car at all. Maybe that extra mass helps!
Old 08-15-2004, 06:35 PM   #9399
I built my gearboxes per instructions and the drivetrain seems so tight. It has gotten better with each run though. I took of one of the shims on the input shafts so it doesnt bind the bearings up but where are you guys seeing the best results on getting the baby to roll?
JimMcClure is offline   Reply With Quote
Old 08-15-2004, 09:04 PM   #9400
Yokomo Ceramic bearings.....
Just wondering how these compare to other brands, how are they sheilded/sealed and what if any maintenance do they need?
Mabuchi540 is offline   Reply With Quote
Old 08-15-2004, 11:04 PM   #9401
Default Re: Yokomo Ceramic bearings.....
Very high quality, and they have metal sheilds. They should be cleaned and lubed just like any other bearing.
Old 08-15-2004, 11:13 PM   #9402
You will see that the more runs you put on the car, the drivetrain will become looser. Every car is a little different, so you can either add or remove more shims to find the best fit. Yokomo also sells shims that have different thicknesses to fine tune the gearboxes. The ceramic bearings really make the car free as well.
Old 08-15-2004, 11:57 PM   #9403
Default Re: Re: Yokomo Ceramic bearings.....
Bugger, I thought ceramics didn't need lubing, if they need lubing and cleaning like any other bearing what's the advantage then?
Old 08-16-2004, 12:37 AM   #9404
Default Re: Re: Re: Yokomo Ceramic bearings.....
Just freer bearings and they should last longer. One time I bought some sealed bearings from Boca that were maintence free, they didn't last at all and were more expensive than regular bearings.
Old 08-16-2004, 01:02 AM   #9405
Default Re: Re: Re: Re: Yokomo Ceramic bearings.....
So they don't actually save you any work then in that you still have to take off the sheilds and flush them with motor cleaner and put a drop of oil on them?
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
