Yokomo MR-4TC SD
Old 08-09-2004, 11:00 PM
  #9301
STLNLST's Avatar
Trader Rating: 22 (100%+)
Originally posted by pops
Some of us like it hot! As long as I've got shade it's cool.
Mo and I will be there. It should be a fun weekend. I think that Javier might even be able to come out and play. I'm going to win this weekend for Matt..
STLNLST is offline
Old 08-10-2004, 01:21 AM
  #9302
Lonestar's Avatar
Default Re: Well what do ya know :)
Originally posted by Mabuchi540
Now tell me if I'm wrong but putting the pin in the lower hole (like you said most ppl do) would have the same effect as turning in the droop screw 1mm that I have done to stop the binding?
No. This just lowers the ride height. Don't mistake the real droop (how far your chassis can go up without the wheels lifting from the ground) with what your read on the droop gauge (which is just probing the lowest point your A-arm can go to without the droop screw hitting the chassis). Depending on where you measure, the gauge gives different readings, while physically the droop remains the same.
What I suggest : Throw the droop gauge off the window, build the shocks with around 63mm length overall in front, mount them on the car, set up camber symmetrically at 1degree (pops suggested that asymetrical camber could be the reason for your "problem"), set ride height to 5mm (with the shock collars), recheck camber, and tell us if your "problem" is still here.
And if this is correct what would be the better option 2mm and the lower hole or 3mm and the upper hole?
Don't bother about this stuff at this point.... this is way too early to wonder about this kind of stuff handling-wise... Build the car and we'll see later. Setups are made to be modified all the time anyway. The good thing about running the lower hole is that it prevents hitting the inside spokes of some rims. Use the lower hole (front).
May I add that you never gave any replies to the extensive fix suggestions that were made by the various users who tried to help you. As far as I'm concerned, this was my last post about your issues...
Good luck,
Paul
Lonestar is offline
Old 08-10-2004, 01:40 AM
  #9303
Well seeing how as most of the comments more or less suggested an inattention to following kit instructions (see various axel comments for example) I thought it best not to reply to them.
I've been building and rechecking this thing for weeks only at a couple of hours a night if there are mistakes it's because I followed the instructions.
Mabuchi540 is offline
Old 08-10-2004, 04:20 AM
  #9304
Registered User
ritchie's Avatar
i probably should have asked or stated earlier, to use the droop gauge, you hold it against the bottom of the chassis with the "steps" on the top side and measure at the edge of the arm below the outter hinge pin and screw. hope this helps, and it sounds like the problem is solved. alot of times, kit instructions will give you a setting point "2mm below arm" but thats not actually the running set up point. in the back of the manual it may have come with a couple of setups. those are the ones you should be setting the car to. good luck and kit butt
ritchie is offline
Old 08-10-2004, 09:04 AM
  #9305
Sleighty's Avatar
I'll know where to take my help in the future
Sleighty is offline
Old 08-10-2004, 09:45 AM
  #9306
hi.
what is the best shop in the us that sells the cgm will post to england?
agower is offline
Old 08-10-2004, 12:07 PM
  #9307
dawgmeat's Avatar
Default PIc
CCGM
dawgmeat is offline
Old 08-10-2004, 12:08 PM
  #9308
dawgmeat's Avatar
Default pic
cgm
dawgmeat is offline
Old 08-10-2004, 12:13 PM
  #9309
Originally posted by agower
hi.
It is not in US but it is better than shops in US.
http://shopping.rcmodel.hk/product_i...18df1c0d7ba104
They ship to UK and everywhere. You can ask them to mark the package as a gift or with value up to 40 and you will not pay any duties. I always do it.
dicort is offline
Old 08-10-2004, 12:14 PM
  #9310
dawgmeat's Avatar
Default pic
cgm
dawgmeat is offline
Old 08-10-2004, 12:25 PM
  #9311
how do you ask them to do that?
agower is offline
Old 08-10-2004, 12:38 PM
  #9312
When you are in CHECKOUT there will be window "add comments about your order".
dicort is offline
Old 08-10-2004, 01:22 PM
  #9313
A couple of quick question...
-Do you have to remove the "outdrive" retaining rings in order to remove the diff/bones? (mine where a nightmare to put on and off)?
-What is a good rolling weight (roughly)?
-Where to find a basic carpet foam stock CGM setup?
-I run the folloing...FRONT: stock outdrives w/Yoke ti bones, REAR: Delrin outdrives w/Yoke Aluminum bones. Any possible problems or suggestion? (Seen allot of different drive-line variations discussed).
Thanks!
Shrub is offline
Old 08-10-2004, 02:30 PM
  #9314
mymax's Avatar
Yes, it sells for $99.50
look at this one...........
http://integy.automated-shops.com/cg...32104542978.e6
mymax is offline
Old 08-10-2004, 03:04 PM
  #9315
rc_bam226's Avatar
Wow, integy has defintely showed up Yokomo on the aftermarket motor mount. I would pay that price anyday for that kind of upgrade.
rc_bam226 is offline
