Old 08-09-2004, 05:04 PM   #9286
Default Well what do ya know :)
I understand what people are saying that it's way to much droop but I assumed the people that wrote the book knew what they are doing when they say 2mm...BUT.....
Then you said about the droop ......"From the drive shaft angle, I think you have front droop#1 or#2 on the droop gauge,no one use that much front droop. The usual front droop is about #6".....
(by the way it's not even #1 on the gauge when I try to fit it underneath)
well that got me thinking, if.....
"that '"2mm" droop screw thing is good for the rear, and the front when you use the lower holes of the C-hub(99% of people use this). But the instruction calls for the upper hole, Yes I think that is a mistake in the instruction"
is correct I'll go look at the instruction book.....
And yes my instruction book says to use the lower hole in the rear but the upper hole in the front.
Now tell me if I'm wrong but putting the pin in the lower hole (like you said most ppl do) would have the same effect as turning in the droop screw 1mm that I have done to stop the binding?
And if this is correct what would be the better option 2mm and the lower hole or 3mm and the upper hole?
Mabuchi540 is offline   Reply With Quote
Old 08-09-2004, 05:29 PM   #9287
alch's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to alch
Default Re: Ti Hinge Pins
Originally posted by Geppetto
Are Titanium hinge pins available for the SD/CGM?
Yes! Part # - SD-414TA
http://www.teamyokomo.com/japan/newp...-414ta_450.jpg
They are a much better design than the stock ones IMO!
alch is offline   Reply With Quote
Old 08-09-2004, 08:06 PM   #9288
Registered User
ritchie's Avatar
use the upper hole, use the lower hole, just screw the droop screw in until you get around 4-6 mm of droop using the included droop guage that came in the kit.
btw, i know its to late but, i think you would have been better off buying the prebuilt cgm drift car, it is plastic, but it is lighter and should perform better using the m540 motor.
ritchie is offline   Reply With Quote
Old 08-09-2004, 08:17 PM   #9289
Default Re: Re: Ti Hinge Pins
Those are King Pins, not hinge pins, but I agree they are a huge improvemnet over the stock ones. The stock hinge pins are pretty hard and are of good quality.
pops is offline   Reply With Quote
Old 08-09-2004, 08:20 PM   #9290
Lighter is it? bugger Oh one last droop question then as a starting point should the front and rear amounts be the same or is one usually more than the other.
Old 08-09-2004, 08:28 PM   #9291
If you race on a smooth surface start with 6 in the front and 5 in the rear.
Old 08-09-2004, 09:09 PM   #9292
New blue motor mount.
Old 08-09-2004, 09:16 PM   #9293
Francis M.'s Avatar
I just got back from the KO grand prix and Billy Easton is already
at a pretty fast pace considering the short time he's had with the car.
he ran the silver, black, and cgm at the event.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 08-09-2004, 09:23 PM   #9294
Tek Nickal's Avatar
Those are Kingpins, not Hinge pins.
Tek Nickal is offline   Reply With Quote
Old 08-09-2004, 10:08 PM   #9295
alch's Avatar
Default Re: Re: Re: Ti Hinge Pins
Oops, my mistake! I know they were king pins, I misread it!
Old 08-09-2004, 10:11 PM   #9296
alch's Avatar
Can't see the whole pic..
Is the blue motor mount really $100 retail in the US? It retails for 5500yen here, which is about US$50.
Old 08-09-2004, 10:40 PM   #9297
Sorry
Old 08-09-2004, 10:43 PM   #9298
Yes, it sells for $99.50
Old 08-09-2004, 11:37 PM   #9299
STLNLST's Avatar
Trader Rating: 21 (100%+)
Geeeeeez
pops- are you guys racing this weekend if it's not 105 degrees like it's going to be on Wednesday.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 08-09-2004, 11:45 PM   #9300
Originally posted by STLNLST
Geeeeeez
Some of us like it hot! As long as I've got shade it's cool.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
