Yokomo MR-4TC SD
#916
R/C Tech Founder
I haven't built my car yet, but I'd go out on a limb and say that the wheel hubs are probably the same. In most cases, cars with metric axles can share them between each other, and cars with standard (American? SI? not sure on the term here) axles can share them between each other.
Also, the universals/axles between the TC and SD are the same, so yea, they should work.
#917
futureal : I believe the word you are looking for is "Imperial", as in inches and yards
Cheers
Cheers
#918
Re: Re: Yoke SD and Special/PRO/Worlds Compatibility
Originally posted by rc-zombies
Compared with the MR4TC SP
Rear universals & bones are the same.
front uses the same bones as the rear.
Nitride shocks shafts the same...
Springs the same...
Diff assembly are different..
As with the front one-way also...
Springs the same...
#919
R/C Tech Founder
But I got the point across, which is good enough for me.
#920
Originally posted by Kenshin
Kilruf,
What did you use to countersink the new holes on the chassis?
Kilruf,
When you don't have the exact tool for doing this (don't know the name in english), you can usually get the job done with a drill bit that is much bigger than the hole.
It's what I use to do and it works like a charm.
Maybe someone else has a better tip ?
#921
Originally posted by MarNaDaKi
Hi Kenshin.
Hi Kenshin.
I don't want to ruin the pretty silver chassis.
#922
has anyone raced there car yet ?? i dont know much about the yoks i had a GT-4 nitro car. cool thing was that it came with alot of hopups that other cars kits dont.
#923
Re: Re: Re: Yoke SD and Special/PRO/Worlds Compatibility
Hi zombie, last I checked on the differential parts, the diff screw, balls and thrust bearings are shared with the MR4 belt cars. Only the bevel gear (pulley) and outdrives are different, last I checked the part numbers are the same.
If its not too much trouble, are parts like the wheel hub (EZ hubs), ball bearing on the the diff and wheel side shared with the belt MR4 too?
Cheers
Cheers
Yes EZ wheel hubs will fit and come standard on the SD... I'm going to replace the stock EZ hubs and replace it with the Clamping type. since there is no internal bearing spacers in the hubs.
Originally posted by futureal
....Also, the universals/axles between the TC and SD are the same, so yea, they should work.
....Do you happen to have the part # for the bones of the MR4TC that will fit the SD? Thanks.
#924
I'm impressed that you managed to get one arm mount in. That should anchor the servo alot better.
As for counter sink, they sell bits just for counter sinking. But I use a dremel and one of the coned stone bits. Does the job good for me. Just takes time and patience to get it done right and clean.
I had plenty of room for my electronics if I mounted my servo the normal way. But to accomidate the larger Novak Brushless ESC (which I got from SpeedtechRC.) ...... I had to mount the servo the way I did. Or else I'd be looking to mount my receiver up high somewhere. And I didn't want to do that.
Blah blah blah......
Hey Steve... am I on first batch or second? Just curious.... I might have to change my card info before you send it out.
Well let me go. L8Rz all
Jimmy Mac
#925
2 servo mounts it is....
I also did not see the other servo mount under the stiffener....thats a relief!!
Jedi, you have any spare Evo 3 low servo mounts?
#926
Kilruf,
No, you're good. You're on the pre-order for the first batch
Steve Wang
Steve Wang
#928
SpeedTech
thanks for the anwser, i really dont check my Pm's all.
#929
THeGame,
No problem.
Jeff T.,
It'll go Monday, I'm sorry about the delay. By the way, I received your email as well.
Steve Wang
No problem.
Jeff T.,
Steve Wang
