Yokomo MR-4TC SD
Old 08-02-2004, 03:56 PM
  #9166
rc_bam226's Avatar
Hey guys, does anyone make Delrin outdrives for the Yok?
rc_bam226 is offline
Old 08-02-2004, 04:08 PM
  #9167
I think Speedtech had them not too long ago. I don't believe there is any advantage to the Delrin over the plastic. Plastic ones are light and seem to last quite a while, not to mention they are cheap as well.
pops is offline
Old 08-02-2004, 04:10 PM
  #9168
Tek Nickal's Avatar
Default Re: Re: Re: Thanks
Originally posted by lem2
Something to ponder on: If I use a lighter oil will it make my car lighter???? its a joke we say to a noob!
It will, if the oil is actually "lighter" in weight, not thickness.
Tek Nickal is offline
Old 08-02-2004, 04:11 PM
  #9169
forty6's Avatar
Excel makes them but they are quite pricey.
forty6 is offline
Old 08-02-2004, 06:11 PM
  #9170
Default front c hubs question
If you use the upper hole on the front c hubs, how does that affect the handling of the car?
thanks in advance
eklips is offline
Old 08-02-2004, 07:11 PM
  #9171
tornado
Guest
Posts: n/a
Titanim screws all around, Ti dog bones, drive shaft and input shafts front and rear, Graphite prop shaft. For electronics I use 9550, quantum comp and KO's 302 reciever. And remove some material underneath the chassis, strategically. Also lightened the battery holder to it maximum limit.
Peace guys and happy racing!
My moms kitchen scale is srewed ! I'm using almost similar stuff like you and still come out heavier.
Bryan
Old 08-02-2004, 07:14 PM
  #9172
Thanks matt... the green springs in those setups are yokomo correct?
shortygy is offline
Old 08-02-2004, 11:04 PM
  #9173
Matt Howard's Avatar
yes, If I don't specify what manufacturer the springs are they're the yokomo ones.
Matt Howard is offline
Old 08-03-2004, 12:01 AM
  #9174
Cool thanks alot man. When are u leaving for korea???
shortygy is offline
Old 08-03-2004, 12:05 AM
  #9175
tomorrow
Old 08-03-2004, 12:13 AM
  #9176
You gunna be racing over there..??? You gunna drop by on here once and a while?
shortygy is offline
Old 08-03-2004, 12:17 AM
  #9177
from what I've found out so far, the nearest track is 140 miles away and I'd have to take a bus or taxi to get there since I can't take my real car. I'll probably make the trek like once a month or so just so I don't go crazy not racing I'll have internet access over there so I'll be on here probably more than I am now.
Old 08-03-2004, 12:20 AM
  #9178
Lonestar's Avatar
Matt, Good luck then!
Later
Paul
Lonestar is offline
Old 08-03-2004, 12:58 AM
  #9179
johnbull's Avatar
Good luck in your new post Matt.
Keep in touch.
johnbull is offline
Old 08-03-2004, 01:07 AM
  #9180
thanks guys
