Old 07-29-2004, 12:17 PM   #9091
Send a message via AIM to micros_rock
Ok, dumb question: what's the final drive ratio of the SD? It doesn't say in the manual.
Thanks.
micros_rock is offline   Reply With Quote
Old 07-29-2004, 12:24 PM   #9092
Default Final Gear Ratio for SD
2.353, you can find it at the setup sheet also.
Anthony Yuen is offline   Reply With Quote
Old 07-29-2004, 12:31 PM   #9093
Originally posted by AzNDRAGster
The quality of the Rayspeed carbon fiber is better. So it flexes less.
But ssg has one plate more. So it has 3 plates and RS has only two. So it is still stiffer?
dicort is offline   Reply With Quote
Old 07-29-2004, 12:40 PM   #9094
Originally posted by agower
hi,
i went to down to my LHS today for a change as they never normaly have anything decent, but i did see one yokomo packet all by itself but it was part number zs501s or zs502s which is the front or rear steel outdrives for the mr4tc and was wonderign if they are the same bits as the sd ones?
many thanks
A Gower
anyone?
agower is offline   Reply With Quote
Old 07-29-2004, 01:31 PM   #9095
sosidge's Avatar
agower - Not the same parts, no.
Everyone - Graphite = What's in your pencil; Carbon Fibre = Industrially produced fibres. Carbon is an abundant element, found in many forms.
Doesn't matter anyway, as long as people get the difference between a carbon composite plastic, and carbon parts that are laid up with carbon fibres and resin.
Old 07-29-2004, 01:32 PM   #9096
sosidge's Avatar
SD centre stiffener is more trouble than it's worth. Very little increase in stiffness, large increase in likelihood of tweak.
Old 07-29-2004, 01:33 PM   #9097
I dont think those will fit on the sd....
shortygy is offline   Reply With Quote
Old 07-29-2004, 01:41 PM   #9098
LeoChan's Avatar
Send a message via ICQ to LeoChan
Default SD lightweight product
like YMP lightweight
LeoChan is offline   Reply With Quote
Old 07-29-2004, 01:43 PM   #9099
LeoChan's Avatar
have 6 holes 3 times to use
Old 07-29-2004, 01:48 PM   #9100
So can i throw out centre stiffener from my car?
Old 07-29-2004, 01:53 PM   #9101
Tek Nickal's Avatar
Wow, thats a neat feature. That would be really useful and its light too.
Tek Nickal is offline   Reply With Quote
Old 07-29-2004, 02:28 PM   #9102
what
Old 07-29-2004, 02:30 PM   #9103
Tek Nickal's Avatar
Usually the pin breaks out of the holes, so if you break, there are another set of holes to use, just move the pin. I can just drill my own holes but it wouldn't be precise.
Old 07-29-2004, 05:00 PM   #9104
Matt Howard's Avatar
Yes you can, most people do when running the double deck cars
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 07-30-2004, 01:11 AM   #9105
Originally posted by pheyhoe
yeah the carbon fibre tub chassis are probably the ultimate stiff chassis, you can get them for around 80 in th UK
worth geting this instead of cgm? and hoe easy would it be to tweak?
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
