Old 07-25-2004, 03:22 PM   #9031
Matt Howard's Avatar
Originally posted by agower
what new wishbones?
I don't know if they're even out yet. They are beefed up models but the downside is they're not interchangeable front to rear like the old kind.
Johnbull- even if Masami doesn't win the worlds they might be able to do a "everything included" kit. we'll see
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 07-25-2004, 05:35 PM   #9032
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Hey everyone, I'm back....
Anyway... I shelved my SSG back in january and used the TC3 fulltime on carpet because I was unable to get the SSG set up....
Now that the CGM chassis is out is it worth it for me to convert the SSG to CGM are give to Yok another shot at life???
Is that new wide bumper worth it?
Myself and the only other guy running the Yok's had major issues with breaking front suspension parts... We were racing on an extremely narrow and tight track and it was nearly impossible to not be making constant contact with others... Will this bumper protect the front?
vtl1180ny is offline   Reply With Quote
Old 07-25-2004, 07:04 PM   #9033
The CGM chassis is much better on carpet and the wide front bumper protects the front end much better than the stock one.
RCTech #361
Old 07-25-2004, 07:44 PM   #9034
lem2's Avatar
Default YOKOMO CGM SPECIAL - Factory Edition
How i wish....
Standard CGM Chassis
Ti Screws
An option of Having a 1way,Spool and diff up front!
Wide front bumper
The new Aluminum Mtr Mount
Alum knuckles? sonomore wories of the Kingpin fallilg off.
Different hardness of sway bars
Alum/Flourine Coated or Ti Ball STuds
HArdened Hinge Pins (like the one they sell for the TC3)
Extra Spur / Bevel Gears?
OPTION PARTS:
Aluminum or Steel Diff Outdrives????
Would not mind paying extra for those. BUyig them separately will be more expensive!!
I use my CGM more than my WarpTC3, and I love it! Toobad its Rainy Season here and no INDOOR onroad Tracks! Most off us here are doing Off-Road o remove the ITCH!!!! INcedentally, TRACKSIDE is here Racing with us!!!! He is a hard act to follow!! Very Fast!
The CGM's here are with front one way, And there is no Diff Set offered by YOKOMO, you have to buy it seperately to complete it and that will amount to about U.S.$60.00!!!!
That's about it!!
Peace Guys and Happy Racing!!
lem2 is offline   Reply With Quote
Old 07-25-2004, 08:38 PM   #9035
OHBRAD's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to OHBRAD
Default weights
does anyone know wha the weights are of the graphite gear case and the std gear cases.
and the std screw set to the titamium.
regards brad
Yokomo BD818 | Sanwa | HW | Zombie | Team Yokomo | Meakin Park | Bayside | Hearns Hobbie | SpeedyRC
OHBRAD is offline   Reply With Quote
Old 07-26-2004, 02:01 PM   #9036
vtl1180ny's Avatar
Thanks Matt.... I miss the adjustability of the Yok and the better design of the suspension... The yok was just flexing way too much and frustrating the crap out of me...
Old 07-26-2004, 07:51 PM   #9037
I agree, I tried running the SSG chassis on carpet with foams and it was not good. The CGM on carpet with foams is much better.
RCTech #361
Old 07-26-2004, 08:02 PM   #9038
Registered User
ritchie's Avatar
Default Re: weights
regards brad
i think its like .06 oz for the graphite and .07 or .08oz for the plastic. its been awhile since i did the weight comparison
edit: i just went and weighed a plastic one, it was 1.0oz so i think the graphite one was .08
ritchie is offline   Reply With Quote
Old 07-26-2004, 09:57 PM   #9039
Registered User
ritchie's Avatar
question: what exactly are the little foam do da's in the shock cap under the shock bladder suppose to do?
Old 07-26-2004, 09:59 PM   #9040
A couple of CGM manuel questions.....
Unused part "F" on page 17 I'm assuming that's the same as part "F1" but more or less toe in?
And the keyed shims for "skid angle"...firstly is that an american term that refers to some adjustment that goes by another name as I've never heard it before?
And secondly what other part exactly are they supposed to "key" too.....
all details sadly lacking in the CGM manuel.
Mabuchi540 is offline   Reply With Quote
Old 07-26-2004, 11:23 PM   #9041
Default Re: A couple of CGM manuel questions.....
The keyed shim is equal to one degree when placed under a suspension mount and the unkeyed shim is equal to 1mm when placed under a suspension mount. It's in the manual somewhere, I don't have one in front of me or I would tell you what your extra part is for as well. The shims don't "key" into anything, they're just made differently so you can tell which one is which.
RCTech #361
Old 07-27-2004, 01:46 AM   #9042
Default Re: Re: A couple of CGM manuel questions.....
Thanks dude.
So one lot of shims can alter the front or rear ride height in mm and the other keyed ones do a similar thing but in degrees (back when I raced off road that was called anti squat not anti skid) what are those degree/heights to start with?
Old 07-27-2004, 01:52 AM   #9043
The kit mount for kickup in the front is 1 deg and the rear has zero antisquat
RCTech #361
Old 07-27-2004, 02:02 AM   #9044
Thumbs up
Thanks again dude it's good to know where I'm starting from in the first place.
Old 07-27-2004, 03:56 AM   #9045
Lonestar's Avatar
Howdy yall
Matt: since you're talking about a hopped-up CGM kit... do you know if such a thing is to come out in the next few weeks/months? I'm willing to give the CGM a chance, but not if an optioned version is released soon...
Next question, one that hurts everyone: what's so wrong with the SD that so few people are racing it now (let alone win with it)? The TC3 still wins races, and the SD was up to par with the top cars last year, including the TC3... so why not anymore?
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
