Old 07-23-2004, 12:59 AM   #9001
JimmyMac's Avatar
Expensive but worth it!
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 07-23-2004, 01:05 AM   #9002
Tek Nickal's Avatar
Well, maybe thats retail price, it could be cheaper.
Tek Nickal is offline   Reply With Quote
Old 07-23-2004, 10:06 AM   #9003
Matt Howard's Avatar
Originally posted by AzNDRAGster
WOW! Those are expensive at $45.00.
They are kinda pricey but they're worth the money, I haven't heard anyone have any problems with breaking them. If you do bend them you can take a hammer or something and bend them back and their good as new, I've done that a couple of times now.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 07-23-2004, 10:38 AM   #9004
I have only seen one that has broke, and they do last a long time.
pops is offline   Reply With Quote
Old 07-23-2004, 10:39 AM   #9005
Matt, are you coming out to SpeedWorld this weekend? When are you heading out to Korea?
Old 07-23-2004, 01:09 PM   #9006
Default Re: Noise Clamps
Originally posted by Isaac
Ok where would you put these? Where would you need to reduce noise? From the Precision R/C site.
are these just magnests in a case. as i got one on thw power cable of my minidisc player and was wondering what it was,
as i only have one which is the best place to put it?
A Gower
agower is offline   Reply With Quote
Old 07-23-2004, 01:39 PM   #9007
Tek Nickal's Avatar
Default Re: Re: Noise Clamps
A Gower
They are just opposing magnets in a case. Yeah.
Old 07-24-2004, 12:49 AM   #9008
Default Re: Re: Re: Noise Clamps
i cant work out how to fit the noise clamps properly. as the wire is to narrow for the whole. and the 'noise clamp' slides up and down it.
so should i just put tape round the wire to make it wider or should i do this way:
put the wire in one end and out the other then loop the wire around the outside so it goes back in the same end and come out the same end as the first time. so the current is stil flowing the same direction inside it. (if that makes and sence)
or is there a differnt way of how i should do this?
also nothing to do with noise clamp but on my yoke sd when the stering is at full lock and i give it some power the wheels turn (steer) slightly. its not glitching, its the drivehafts cant turn properly at that angle. i have sanded the knuckle down so that it doesnt sseize up and no differnce. i even took the driveshaft out to make sure it was it. and it is, if u hold the driiveshaft at an angle as far as it wil go and turn it its fine until it tries to pass the pin and then it straightens up a bit like it cant lean as far. (hope that made sence)
any suggestions on how to fix this or anyhing i have done wrong?
Many thanks
A Gower
Old 07-24-2004, 12:54 AM   #9009
Tek Nickal's Avatar
Make the wire longer and make a loop around the outside back into it. like a circle but with the filter on it.
Old 07-24-2004, 12:58 AM   #9010
thanks, and suggestions about the dirveshafts?
Old 07-24-2004, 01:01 AM   #9011
sosidge's Avatar
Default Re: Re: Re: Re: Noise Clamps
The driveshafts will do that when you turn them by hand, it's the design.
Sanding down the knuckle? Trying to get extra lock by sanding down parts won't work, because the driveshafts have a maximum angle they can work at.
Another solution is to use less lock with your steering rate, e.g. 90%, although my car runs happily at 100% lock.
Old 07-24-2004, 01:05 AM   #9012
i HAD to sand down the knuckle, not to get extra lock, if i didnt sand them down then the driveshafts seizes up and wont bend atall (just goes rigid) and the dirvehafts dont work properly in the Car not my hand. that was just to test them.
so your saying the only way to solve this is to turn steering down, nothing mechanical. as if i turn my steering down i wont be able to get round the corners.
Old 07-24-2004, 03:35 AM   #9013
Many thanks
A Gower
here is a link to a viedo of the wheel problem: wheel problem
here on some pictures of the elctrics so you can tel me if i have done it right :close up electric
hole electrics
many thanks
A Gower
ps, the video is 1.2mb so wont take long to load, please watch.
Old 07-24-2004, 06:13 AM   #9014
does the yokomo have any problems in its "out of the box set up" i want a car that runs really smooth and quiet all the time. previous cars that i have owned only stay quiet sometimes or at top speed. what can i do to keep the car smooth and quiet (belt and shaft)? my diffs are fine and clean
myk505 is offline   Reply With Quote
Old 07-24-2004, 08:58 AM   #9015
alch's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to alch
Different spur gears make different noises.. I changed from Yokomo to Kawada and noticed a huge reduction in noise..
alch is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
