Old 07-21-2004, 06:09 PM   #8986
Registered User
ritchie's Avatar
i saw quite a few cars with those on at the nats last weekend. wish i would have had a couple on my car when it suddenly turned left and hit the wall while going around a right hand sweeper.
ritchie is offline   Reply With Quote
Old 07-21-2004, 06:39 PM   #8987
Originally posted by KilRuf
Isaac, just go to page 289 and look at my 2nd post. I have a picture attached there of my car. You'll see I have 2 of those filters on the car. I don't really glitch much. Because of the filters? I dunno. But if anything, it also adds weight to the car to make it legal at 53oz.
I saw it. I don't glitch but I will remember this if I have such a problem. I know you're coming up for TCS Sunday but Sept. 12 is our big Charity Race. I'd like to see your Yokomo this year.
wilsonproperties1.com
Isaac is offline   Reply With Quote
Old 07-21-2004, 08:16 PM   #8988
Tek Nickal's Avatar
I keep breaking my front CVDs are there dogbones I can buy? or some way that I can stop it from breaking?
Tek Nickal is offline   Reply With Quote
Old 07-21-2004, 10:19 PM   #8989
JimmyMac's Avatar
Isaac, do you have any details on it? The charity race that is? Is it the same parking lot that the TCS will be held? My SD doesn't do too well on parkling lots. At least not right now. It's mostly setup for smooth asphalt tracks. I'd have to run over to Sams club parking lot for a basic setup. It's about the same as Laurel. Keep me informed. I'll be doin the TCS this weekend. Then the NORRCA Nats next month in Atlanta. I'll more than likely use my 415 for that unless if my Evo IV comes in before hand. Not that I won't race my SD anymore. But my SD is mainly for stock class. And that's what we run at my local track. The 415 is for Mod, 19t, and TCS races.. Anyways, you can tell me all about it when I show up this weekend....
AzNDRAGster, have you tried the Yokomo hardened universal set?
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 07-22-2004, 03:12 AM   #8990
tornado
Guest
Posts: n/a
Kinwald put just one on the esc wires to the receiver. It seem to work for him. There are no one fixed solution to cure glitching. Cetain tracks a more prone to it and some don't. So.....its a process of elimination.
Bryan
Old 07-22-2004, 03:30 AM   #8991
johnbull's Avatar
I think the greatest inducer of glithing is the orientation of electrics.
Here are a few hints I have learnt from my experience.
Always use at least 2 capacitors on your motors. I also use a schottky diode.
Locate your speedo as close to the motor as possible and keep the wires as short as possible.
Locate your receiver as far from the speedo and the speedo wires as possible.
Make sure your batt and motor wires are as far from your receiver and aerial as possible.
Make sure your aerial isn't chaffed or rubbing on any carbon fibre or graphite chassis bits.
Keep everything spotless at all times.
Now I know that with today's cars space is very limited. Play around as best you can till you find the best location for all electrical components.
Here's a pic of my layout.
Good luck.
johnbull is offline   Reply With Quote
Old 07-22-2004, 06:38 AM   #8992
OHBRAD's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to OHBRAD
Default DROOP SETTING
can anyone tell me what the STD set up for droop front and rear is, i seem to have misplaced the sheet i got with the kit telling me the std set up.
regards brad
Yokomo BD818 | Sanwa | HW | Zombie | Team Yokomo | Meakin Park | Bayside | Hearns Hobbie | SpeedyRC
OHBRAD is offline   Reply With Quote
Old 07-22-2004, 06:41 AM   #8993
johnbull's Avatar
IF you start with 5 up front and 3 at the rear you won't be far wrong.
Those are measurements on the droop gauge incidentally.
Old 07-22-2004, 07:16 AM   #8994
OHBRAD's Avatar
Default DROOP
THANX JOHN, IS THIS THE STD SET UP, ALSO DO YOU MEASURE DROOP WITH THE SPINGS ON AND LOAD OR WITH OUT
REGRDS BRAD
Old 07-22-2004, 08:34 AM   #8995
I suggest you get the new larger front bumper and replace the front universals with the Yoke Hardened Universals from the MR4-TC. As said before you will need to grind down the ball on each front universal, the rear are a perfect fit. I have only seen one break, and if you do bend them you can take them out and straighten them with a hammer.
pops is offline   Reply With Quote
Old 07-22-2004, 08:55 AM   #8996
kt racing's Avatar
Send a message via AIM to kt racing
Brad,
i measure it with the springs on that way they are forcing the arms against the stop points.
keith
kt racing is offline   Reply With Quote
Old 07-22-2004, 11:39 AM   #8997
http://www.hobbyworks.com/default.cf...&hs=Home&ID=69
Old 07-22-2004, 06:47 PM   #8998
Tek Nickal's Avatar
nope, but do you have the part #?
Old 07-22-2004, 07:13 PM   #8999
ZS-010FH
Old 07-22-2004, 09:50 PM   #9000
Tek Nickal's Avatar
WOW! Those are expensive at $45.00.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
