Old 07-16-2004, 11:46 PM   #8941
Tek Nickal's Avatar
How can you be so sure? Of course the tolerance will be a LITTLE off, but yeah. When you run the car for a while take out the bearing and check the hole, if there is wear around it, then its off a bit.
Tek Nickal is offline   Reply With Quote
Old 07-17-2004, 12:13 AM   #8942
Default How about if I said....
the hole in and of itself is straight but not drilled perpendicular to the motor plate so the shaft does not run in line.
Mabuchi540 is offline   Reply With Quote
Old 07-17-2004, 12:32 AM   #8943
Tek Nickal's Avatar
I see what your saying, but exactly how much? Enough to effect drivetrain drag?
Old 07-17-2004, 01:15 AM   #8944
Unkown under power but the rear gear box with spur attached spins freely until the shaft is put through the mount when it then loses all hand spin (if that makes sense).
Old 07-17-2004, 03:09 AM   #8945
Mine was doing that but it was the light weight input shaft that I had... it was bent... do you have a light weight shaft???
shortygy is offline   Reply With Quote
Old 07-17-2004, 03:36 AM   #8946
johnbull's Avatar
I removed my Tobbee input shaft for the same reason.
johnbull is offline   Reply With Quote
Old 07-17-2004, 03:37 AM   #8947
No just the standard one.
Just checked the other motor mount (I got two kits) and it's the bloody same too.
Old 07-17-2004, 04:57 AM   #8948
That sounds weird. I wouldn't think two kits would have that same problem - any pictures you could show us?
Trevor is offline   Reply With Quote
Old 07-17-2004, 05:03 AM   #8949
Sorry I don't think the digital camera could get that close or if it would even show up if it could (with nothing to compare it side by side with).
Trust me they both have holes that are about 1/2 to 3/4 of a mm out of line. By that I mean the hole is at such an angle that the bottom of the bearing sticks out that much further than the top from the face of the motor mount due to the angle the hole was drilled at.
Old 07-17-2004, 05:09 AM   #8950
Well, I guess you will just have to take them to the guy you bought them from and show him the problem and if he agrees ask for new motor mounts. And if that doesnt solve it ask yokomo whats going on.
Old 07-17-2004, 10:12 AM   #8951
hey guys need some help here...the tyres on my cgm seems to be wearing on the inside alot...been trying different setups with different tyre compounds and inserts but i still end up with torn tyres....tried different camber angles too...same results during the day and at night...i run green springs wth 450wt in front and pink springs with 350wt at the back..droop is set to 6 in front and 5 at the back..roll bars is silver in frnt and black at the back..i run with a one way infrnt with all the other stock setup... thx..
razi is offline   Reply With Quote
Old 07-17-2004, 11:13 AM   #8952
forty6's Avatar
Originally posted by Matt Howard
Easton is 8th after 2 rounds of qualifying at the ROAR nats, right ahead of Tosolini It will be interesting to find out what version car he is running, I was told he prefered the SSG car over the RS and CGM in practice leading up to the nats.
That would be cool if he really is using the SSG.
forty6 is offline   Reply With Quote
Old 07-17-2004, 01:16 PM   #8953
Tek Nickal's Avatar
Maybe its your camber link, when you turn, that side of the suspension compresses and pushes the top of the wheel outward? Just a thought.
Old 07-17-2004, 01:40 PM   #8954
Matt Howard's Avatar
Try running less camber in the front or a thicker insert
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 07-17-2004, 04:31 PM   #8955
johnbull's Avatar
Matt.
Have you found out yet what chassis Billy E is running. He seems to be on the pace.
Who else in the top 20 is running Yokes ?
Did a couple of runs with mine today with a 9 turn single. It's quick and gives the duration. With a very second hand set of tyres it was still on the pace. I really do like this car. Tweek is just a thing of the past. You just put it on the track and it's always right.
Still waiting for some more results from Oregon before hitting the sack. It's half past midnight out here.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
