Old 07-13-2004, 08:14 PM   #8926
alch's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to alch
Originally posted by Matt Howard
I just use regular ball studs. They fit really tight on them, I pinched the ball ends with pliers to free them up a little, they're still really snug though. No play at all, but they're still free.
Thanks Matt and Shortygy!
alch is offline   Reply With Quote
Old 07-14-2004, 07:28 PM   #8927
Default Urgent set up help needed for CGM
My son's racing his CGM at the Nats this week and during practice the car has developed a bad off power looseness in the rear. He's tried different set up changes but it's not responding.
I don't have all of his set up info but he is using a spool made with sandpaper between the diff rings. The car has been fine at our local asphalt track with this arrangement.
Appreciate any help. Thanks.
coolrcdad is offline   Reply With Quote
Old 07-14-2004, 08:06 PM   #8928
JimmyMac's Avatar
What is his arm spacing? He may have too much weight in the rear of the car. Try moving the arms to the rear. Also try droop. Raise up the rear arms. And/or stand up the front shocks to the outter most holes on the tower. Anyways, kinda hard to guess without seeing his setup first....
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 07-14-2004, 08:23 PM   #8929
Registered User
ritchie's Avatar
i'll be down in the morning first thing, maybe sam can tell me how to get a spool to work without all the push, as far as the rear being loose, it might be something as simple as adding a shim or two for anti squat.
ritchie is offline   Reply With Quote
Old 07-14-2004, 08:47 PM   #8930
Thanks guys.
Kilruf -- sure enough he found out from a fellow club member that he didn't have droop or suspension travel for the surface. Dialed some more in and it was much better.
ritchie -- he'll be happy to help
Old 07-15-2004, 01:38 AM   #8931
johnbull's Avatar
CoolRCDad,
Droop setting is usually the simplest way to cure that.
Also check that none of the rear pivot pins are bent and the car has equal toe in on both rear wheels. Then play witrh the usual things.
One more possibility is the rear diff. Just make sure it's OK.
I find the Yoke really works well with a front spool.
Can you move the weight further forward ? That should help too.
Good luck,
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 07-15-2004, 10:05 AM   #8932
NEWS:
Mr Masaaki, father of Mr Masami, has called it a day and retired from RC.
I think he also said that they have stop development of the Yok GP car.
MIKA is offline   Reply With Quote
Old 07-15-2004, 09:52 PM   #8933
you mean there won't be rumored GT-6?
dragoneuh is offline   Reply With Quote
Old 07-16-2004, 12:21 AM   #8934
Matt Howard's Avatar
the new gas car has been postponed while yokomo works on other projects
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 07-16-2004, 07:15 PM   #8935
Easton is 8th after 2 rounds of qualifying at the ROAR nats, right ahead of Tosolini It will be interesting to find out what version car he is running, I was told he prefered the SSG car over the RS and CGM in practice leading up to the nats.
RCTech #361
Old 07-16-2004, 10:43 PM   #8936
forty6's Avatar
edit
forty6 is offline   Reply With Quote
Old 07-16-2004, 11:35 PM   #8937
Tek Nickal's Avatar
Wow, he's running the SSG? No "pro" usually runs that anymore.
Tek Nickal is offline   Reply With Quote
Old 07-16-2004, 11:39 PM   #8938
Thumbs down Part No SD 304M.....
what a piece of crap this kit is turning out to be now the friggin hole in the motor mount for the 5x10 bearing isn't even drilled in straight. So much for quality control improving over the years.
Mabuchi540 is offline   Reply With Quote
Old 07-16-2004, 11:41 PM   #8939
Tek Nickal's Avatar
Are you sure your not sticking in the bearing sideways or something so its not going in smoothly? Maybe its such a precicely drilled hole that its hard to get in unless the bearing is going in straight.
Old 07-16-2004, 11:43 PM   #8940
Oh it goes in smoothly what I mean is that it's not inline as in when you put the shaft through it it's at an angle.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
