Old 07-07-2004, 01:59 AM   #8881
johnbull's Avatar
Hi friends. Greetings from Malta.
Thanks for the compliments to all, first of all.
RC - BAM. Cut the rough shape with a fret saw. You'll break a few blades in the process but they're cheap enough. For the battery and motor holes drill a series of holes close to each other to slightly less than the hole size you require, then play with a square file.
PORTER. The dog bones are the normal Yokomo alloy ones. Since I fitted those rubber boots on the CV joint ends, front and rear, which keep the joints well greased, wear has become minimal and I haven't replaced a drive shaft in 6 months, even using 7 and 8 turn motors on a track with lots of grip.
HORATIO. You seem to have been in this game as long as I have. Yes those wide touring cars were fun indeed. I still have both mine. My son's car was based on the Schumacher CAT, and mine was based on the Yokomo YZ10. I look back at them every now and again and wonder at all the work I had put into them. But it's great fun. Pity we don't use them any more.
If you log onto the TC3 thread here in rctech you can see a couple of pics of son Josh's championship winning TC3s. I posted them yesterday. I've done a bit of work on those too.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 07-07-2004, 02:57 AM   #8882
alch's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to alch
Originally posted by tornado
Any link to FibreLyte ? .....Pleeeeze
http://www.fibre-lyte.co.uk/cf/index.html.
I just did a google and found this..
alch is offline   Reply With Quote
Old 07-07-2004, 03:22 AM   #8883
tornado
Guest
Posts: n/a
Thnx Alch !
Old 07-07-2004, 08:21 AM   #8884
rc_bam226's Avatar
Here you go:
rc_bam226 is offline   Reply With Quote
Old 07-07-2004, 04:58 PM   #8885
yodace's Avatar
I running on asphalt...
I can't seem to get 4mm of droop in the rear of my car. I have tried screwing out the shock end some that didn't seem to work. So I tried unscrewing the rear a arms alittle bit that didn't seem to work...
Any help would be nice...
yodace is offline   Reply With Quote
Old 07-07-2004, 05:09 PM   #8886
Use long shock ends...
pops is offline   Reply With Quote
Old 07-07-2004, 05:12 PM   #8887
Originally posted by ritchie
pops, be there done that, out of stock
Try it again, most stuff is back in stock
Old 07-07-2004, 05:17 PM   #8888
yodace's Avatar
Pops
Which brand?
Are the rear stock shock ends longer? I know the front shock ends are longer?
Which shock ends are u using on your car?
Old 07-07-2004, 07:19 PM   #8889
Matt Howard's Avatar
Pops
Which brand?
Yokomo gives you two shock ends, one long and one short. Run the long ones in the rear if your having problems getting the right droop setting.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 07-07-2004, 08:13 PM   #8890
Pops
Which brand?
As Matt said, there are short and long ends that come with the car. We run the short shock ends both front and rear.
We have 6mm of droop in front and 5mm of droop in rear.
Old 07-07-2004, 08:22 PM   #8891
whoa, do you know if they charge alot or not?
if not i can also CF my car
BBSGS4 is offline   Reply With Quote
Old 07-07-2004, 09:38 PM   #8892
yodace's Avatar
Matt, Pops,
I saw the yours guys track on your website. Do both primarly run asphalt...Do u both race carpet at your home track?
Which servo horn u using?
What a good digital servo onroad racing? I had a JR 4750 motor go out or something opened up everything looks good. Could find the problem.
Thanks for a help the last few posts..
Old 07-08-2004, 06:57 AM   #8893
Matt, Pops,
We both run carpet during the winter months at stockton r/c raceway in the stockton california fairgrounds. I ran both mod foam and 19T rubber with my CGM and lil'Alex (pops' kid) ran 19T rubber and stock. I've been using the stock CGM servo saver with no problems, it seems stiff enough but still give alittle if you hit something. I run all KO stuff and I run their digital servo but I don't remember what the # was. I would look at my car but it's on it's way overseas
RCTech #361
Old 07-08-2004, 07:42 AM   #8894
STLNLST's Avatar
Trader Rating: 21 (100%+)
Where are you guys racing at this weekend.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 07-08-2004, 07:47 AM   #8895
Matt, Pops,
KO 2143 digital servo, very fast and bulletproof. Stock springloaded servo horn, is as, Matt said.
Did you look at the end point adjustment on your radio? That could be making the sound you hear when you turn the wheel hard left or right. If your not sure, have someone else look at it.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
