Yokomo MR-4TC SD
#8821
Hey Guys,
Anyone still using an ssg with foam tires on carpet? My ssg has always worked so well for me on assphalt that i havent wanted to change to the cgm. I might be racing on carpet next week so if anyone has a good mod/foam ssg setup they could email me i would appreciate it.
Thanks,
Blake
Thanks,
Blake
#8822
Guest
Originally posted by Tim Stamper
the MX4 is Yok's 4wd buggy that was pretty darn good a while ago. I still have 2 of them.
Tim
Tim
Thnx
#8823
Registered User
Ackerman setting...
Originally posted by johnbull
THE NOI.
Hope it's a bit clearer now.
Regards
Joe from sunny Malta.
THE NOI.
Regards
Thanks Joe...
SD_CGM :
#8824
swaybar kit open ball ends: What is the part number for these?
Also what is the part number Schumacher Ball Grippas?
#8825
Originally posted by ritchie
oh ok. i remember now, actually korey told me once but i forgot. not sure what ryan is runnng, sounds like portland is similar to eslsroc surface, i've never had so much traction from a parking lot, even more then stans home depot races. i'll be down on thursday with most of the old farts from FW to run masters class. i've been running the cgm for a couple of weeks now and love it.
#8827
Ok, I figured out how to word this question after looking at the car.
Are u supposted to line up the center link with center of the chassis?
Got everything installed looks good. But my servo makes a stretching sound when I link it to the steering rack? Please help???
But when it is not connected to the steering rack it is fine.....
#8828
I know yokomo makes a aluminum upper pilliow ball for the the shocks, I have 1 set and want to get some more but I can't find a part number. Does anyone have the part number?
#8829
If you are looking for a ssg foam carpet setup you can get lots off of my site go check it out at www.yokomo.tk
#8830
Originally posted by 2Tenths
Cool. It seemed like a weird surface. On a high-bite track I would think a one-way would work, but I had a lot of trouble trying to use the one-way and had to switch to the spool (which was much faster) So I'm not sure whether it was really a high-bite track, I just know it beat up our tires. What have you guys been running, 1ways, diffs, or spools?
#8832
Yeah they are horrible.... either use the stock shaft or else get another aftermarket one....
#8834
crab boy,
try the after market shaft from tobee craft. I have been running it for almost a year now and I haven't had any problems with it. You can get it from www.speedtechrc.com
#8835
Tobbee
I just bent my new light weight tobee craft shaft and have put the standard one back in.
