Old 06-27-2004, 08:38 PM   #8656
Tek Nickal's Avatar
Yeah, that happened to me, and the pin keeps getting loose, anyway to fix this?
Tek Nickal is offline   Reply With Quote
Old 06-27-2004, 09:22 PM   #8657
Matt Howard's Avatar
Use some locktite on the set screw that holds the pin in the cvd to prevent the pin from coming loose.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 06-27-2004, 09:31 PM   #8658
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Looks like i'll have to get the wide bumper set :
Does the wide bumper set REALLY help? Does it pretty much prevent most problems like knuckle breakage, arm breakage, etc.?
Thanx
DOMOisCOOL is offline   Reply With Quote
Old 06-27-2004, 09:34 PM   #8659
yodace's Avatar
Pops,
Thanks for the pics...
yodace is offline   Reply With Quote
Old 06-27-2004, 09:45 PM   #8660
Thanx
The wide bumper is probably the best thing you can get for the car, it helps alot. I haven't broke any front end parts since I put it on.
RCTech #361
Old 06-27-2004, 10:00 PM   #8661
JimmyMac's Avatar
Well just took home the Region 3 Stock TC title today. Car ran pretty good. Here is my setup....
As for axles, I seemed to have always sheared off the stock bones clean in half near the axle. But now I run the hardened univeral set with no problems at all. It's very nice and well worth it.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 06-27-2004, 10:01 PM   #8662
Hey guys my site has been updated. I added Matt Howards Reedy race setup and his speedworld setup. Check them out at http://www.yokomo.tk
Matt another question... Just wondering why you use such a variation of things from setup to setup. Like different springs (associated) (rayspeed) (yokomo) and pistons (yokomo) (rayspeed) also with shock oil (yokomo) (associated).
Thanks Greg
shortygy is offline   Reply With Quote
Old 06-27-2004, 10:05 PM   #8663
JimmyMac's Avatar
Here's a pic of my car...
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 06-27-2004, 10:09 PM   #8664
Tek Nickal's Avatar
Thanx
Whatever! Learn how to drive!
Old 06-27-2004, 10:14 PM   #8665
Thanks Greg
I like to try alot of different things on the car. AE springs are the ones I ran on my carpet setup since they have the weights I wanted. I like the RS springs since they are more consistent from spring to spring, the stock yokomo ones are sometimes inconsistent from spring to spring in the length of them. I change shock oils to the yokomo oil when I'm trying out a setup that calls for yokomo oil, if I like the setup I stick with the oil but I usually use AE shock oil since it's more readily available. I don't think I've run the same setup week to week since I've had the car
RCTech #361
Old 06-27-2004, 10:15 PM   #8666
DOMOisCOOL's Avatar
LOL
You learn how to drive.
You accidently crashed into a chair leg and broke your rear arm
Old 06-27-2004, 10:22 PM   #8667
tornado
Guest
Posts: n/a
Originally posted by Matt Howard
I remember all the problems you had, and although I never seized one up as you did, I did break many stock axles where the cvd pin goes through it.
I on the other hand broke the cvd pins. One hard bump on the wall both the pins on the front end snap and lost traction totally.
Old 06-27-2004, 10:23 PM   #8668
tornado
Guest
Posts: n/a
Cool ride dude.
Old 06-27-2004, 10:50 PM   #8669
JimmyMac's Avatar
Thanks..
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 06-27-2004, 10:52 PM   #8670
DOMOisCOOL's Avatar
Kilruf, first of all nice car!
Second, where did you get the 'noise filter' and can you take a closeup of the lexan air director mod? Thanks
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
