Old 06-21-2004, 04:49 PM   #8611
Matt Howard's Avatar
and here's my Reedy race setup
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 06-23-2004, 04:07 PM   #8612
Hi Matt
Which shock towers do you prefer to use the CGM or rayspeed ones ? I see you have used both does one type work better in certain condtions?
Mark
mark turner is offline   Reply With Quote
Old 06-23-2004, 04:12 PM   #8613
actually I like to use the stock CGM tower in the front since it has extra camber link holes and I like the RS tower in the rear for the extra shock mounting holes.
RCTech #361
Old 06-23-2004, 07:56 PM   #8614
rc_square24's Avatar
will round associated diff rings fit in an SD outdrive with the 2 flat spots?
rc_square24 is offline   Reply With Quote
Old 06-24-2004, 01:02 AM   #8615
johnbull's Avatar
Associated also do diff rings with flats, so if the I.D. is the same, they could be used.
I hadn't thought about that one, but it's one worth investigating when I next rebuild the diffs. AE diff rings have a far lower wear rate than Yoke ones so it could be a good idea.
johnbull is offline   Reply With Quote
Old 06-24-2004, 02:02 AM   #8616
SpeedTech's Avatar
Matt Howard,
Excellent run over the weekend at SpeedWorld cup. Your car looked really good Congratulations to you
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 06-24-2004, 04:32 AM   #8617
Default Should I?
I currently run a HPI Pro4 but also have a mint xxx-s G+ sitting on the shelf unused, I have the opperunity to swap the Losi for a
2 meeting old SD-CGM.
Should I go for it? Whats the CGM really like, is it easy to find a good set up etc?
Rich_p is offline   Reply With Quote
Old 06-24-2004, 06:32 AM   #8618
Default SOLD !!!
For sale: Yokomo SD-CGM with Novak GT7 & Novak XXTRA receiver....LOTS & LOTS of new extra parts...Check it out at the link below..
http://www.rctech.net/forum/showthre...threadid=43543
ClubRacer is offline   Reply With Quote
Old 06-24-2004, 07:34 AM   #8619
Horatio's Avatar
Default Re: Should I?
Bearing in mind the difference in retail price between the CGM and the xxx-s G+, personally I WOULDN'T SWAP.
Keep the losi for a rainy day. Enjoy your current car/s, and save up the modest amount of money you'll need to buy a CGM. Even less if you choose to buy a 2nd hand one.
It's nice to have a collection of cars - one day you'll treasure them
The CGM is very good by all accounts and is exceptional value for money. Regards set-up, you could pick any car and find the set-up you need on this site.
Horatio is offline   Reply With Quote
Old 06-24-2004, 09:03 AM   #8620
Thanks for you opinion.
To answer the thing on retail price over here (UK) the Losi retails for around $540 and I got it for around $185 when it was 4 meetings old so the price difference isnt to much of an issue
Old 06-24-2004, 10:56 AM   #8621
Originally posted by SpeedTech
Matt Howard,
Steve Wang
Thanks, the car felt absolutely dialed in stock, very good corner speed. It was good in mod too but I didn't have very good luck in the 2nd and 3rd mains. Glad you and the rest of the crew made the trip
RCTech #361
Old 06-24-2004, 01:07 PM   #8622
WOW! The molded lightweight graphite chassis is pretty flexible, am I crazy? This is not going to work for foam carpet. Any suggestions?
Shrub is offline   Reply With Quote
Old 06-24-2004, 04:02 PM   #8623
Yes, you are crazy The lightweight chassis works fine for Tosolini and myself for foam carpet racing. If you think you need to stiffen it up you can mount a topdeck off of one of the double deck cars. You'll need to space it up alittle so you can get the motor in and out but it works, I tested with it but took it off since I couldn't feel the difference with it on.
RCTech #361
Old 06-24-2004, 04:59 PM   #8624
Trader Rating: 21 (100%+)
Like Matt said, the leightweight chassis is fine for carpet. I have been running one since the carpet Nats. I have tried a top deck with and really didn't care for it. It felt stiffer on the bench but no real difference on the track. I did notice that if you hit something, the car would tweak with it on. I did not feel the weight of putting it on was justifiable. Grab a milled out TC3 and see how much one flexes. Give the chassis a try, I believe you will find no difference between a stock one on the track other than the weight savings.
Matt-Good job bro!
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 06-24-2004, 05:28 PM   #8625
and honestly, the weight savings isn't even that much
brian- thanks
RCTech #361
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
