Old 06-16-2004, 01:22 AM   #8566
Mercury Racer's Avatar
im in the process of building my cgm right now and was wondering, how can make the drive train spin smoother? i have built it according to the manual already, but im not too happy with how it spins.
Mercury Racer is offline   Reply With Quote
Old 06-16-2004, 01:38 AM   #8567
Lonestar's Avatar
Originally posted by MR JOLLY
When you guys build your shocks(sd), how much rebound do you have is it
A)NO REBOUND
B)EXTENDS FULLY BUT SLOWLY
C)EXTENDS FULLY BUT A LITTLE FASTER THEN SLOWLY
D)DON`T KNOW
E)COULD`NT GIVE A MONKEYS
close to B... I always hated playing with rebound... that's what springs are for, not bladders.
I try to have the slowest possible rebound without having any bubbles in the shock. I find yokomo shocks being a pain to bleed properly.
If anybody's ever built Mugen onroad shocks, they should know what I'm talking about!
Later
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 06-16-2004, 01:47 AM   #8568
sosidge's Avatar
A)NO REBOUND
D)DON`T KNOW
None of the above - I have them so they rebound slowly about half way.
I don't use the foam chunks above the bladder - I think they make the rebound artificially fast.
Old 06-16-2004, 01:51 AM   #8569
sosidge's Avatar
Make sure the input gears are firmly seated on the input shafts (they may need a little tap with a hammer to go fully home).
Don't tighten the spur gear holder so it's right against the bearings - make sure the assembly spins freely.
Run the car with the suggested shimming for a few runs, to bed the gears in. Then play with the shims to get a free spinning drivetrain, with a little backlash in the bevel gears. Personally, I'm running 2 shims on the input gear, and both the diff shims on the opposite side to the gear.
Old 06-16-2004, 02:20 AM   #8570
alch's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to alch
You should clean the bearings out, they usually come with a very thick grease... Clean this out and put something thinner in (Check out this forum for some good bearing oils.)
alch is offline   Reply With Quote
Old 06-16-2004, 02:25 AM   #8571
Lonestar's Avatar
Same here... my shocks only rebound halfway too... The bladders are still pushing them a bit.
Paul
Old 06-16-2004, 02:35 AM   #8572
alch's Avatar
Originally posted by yodace
Are those blue motor mounts out yet? and who is selling them?
I haven't seen the whole motor mount here in Japan yet, just the part that screws onto the motor (540 and normal)..
Old 06-16-2004, 03:59 AM   #8573
ernestf's Avatar
Send a message via ICQ to ernestf
I did that on mine - silk smooth
i also use the light weight input shaft F and R to reduce the rotational mass.
ernestf is offline   Reply With Quote
Old 06-16-2004, 04:03 AM   #8574
tornado
Guest
Posts: n/a
Heyo dude....hows da car feel after installing da light weight input shafts ?
Old 06-16-2004, 04:32 AM   #8575
ernestf's Avatar
LIGHTER !
Old 06-16-2004, 04:47 AM   #8576
Unhappy
More importantly what's the part number because I can't find it.
Mabuchi540 is offline   Reply With Quote
Old 06-16-2004, 05:38 AM   #8577
alch's Avatar
For the Alumi input shafts?
Part# SD-303AF - Hard Coated Aluminum Front Input Shaft
Part# SD-303AR - Hard Coated Aluminum Rear Input Shaft
Old 06-16-2004, 05:45 AM   #8578
Thumbs up
Thanks for the info.
Old 06-16-2004, 05:56 AM   #8579
alch's Avatar
No problem..
Old 06-16-2004, 08:31 AM   #8580
lem2's Avatar
when I installed the Ti input shafts, Dog bones and drive shafts!! The car accelrates much faster!!
Square_RC makes Ti parts for the drivetrain and is available at Speedtech!
lem2 is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
