Old 06-10-2004, 01:16 PM   #8521
utieh's Avatar
Default Spool set-up
Joe,
I've noticed that you were using AE green springs(spring rate is 11.43lb/in), the closest yokomo spring I've found is the blue one (12,12 lb/in).
Is it normal to use very soft spring and oil while running a spool?
Which rear arm mount did you use? 2, 3???
thanks
Gilles
utieh is offline   Reply With Quote
Old 06-11-2004, 01:58 AM   #8522
johnbull's Avatar
Hi friends. Greetings from Malta.
ROBORAT.
Front hubs. Just to distinguish, there are 2 components we are talking about - the C hub - in my case I run a 7 degree one, and the hub or knuckle - what retains the bearings.
The knuckle with trail will give much more straight line stability, will straighten the car out quicker as you apply the power out of a corner, but will give you less steering response entering a corner.
The reason I don't use the trailing ones is because I prefer to sacrifice some on power steering for the bigger bearings. The only hubs available with the bigger bearings are the MR4 special ones and they don't have any trail.
GILLES. UTIEH.
I think it is a generally accepted fact that the TC3 suspension geometry is about the best there is. Everybody has tried to copy it. In fact if you look through set ups for winning cars of all brands, most people end up using TC3 springs, and fairly soft ones at that.
Most of the quick guys running TC3's out here run AE green springs and yes, I run them on the Yoke too, with a 35 or 40 oil, and very upright - 2nd outermost hole on both towers and bottom arms.
I ran the car yesterday again. It never ceases to impress me. Remember I am nearly 58 years old so my eyesight, reflexes, etc are on the way down. Yet the car is so good that despite using old tyres and a motor with a dozen runs on brushes and comm - I use V2 endbells - I can still run with the best. It's not my driving that does it, but the fact that the car is so good.
I should have a stock of professionally made spools next week. The one I run on my car I made myself.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 06-11-2004, 11:32 AM   #8523
utieh's Avatar
Joe,
thanks.
I didn't receive the spool yet, but I prepared the SD using this geometry and shock set-up
the front diff is very tight (almost a spool), but I'm very afraid to break the diff halves tomorrow while practicing.
I will use the yellow Yokomo springs, which are heavier than the AE green but it already feels very soft.
Old 06-11-2004, 02:23 PM   #8524
Registered User
ZeroCooL's Avatar
Default Spool.
I hate to be a bother but,..... Where are you guys getting the "SPOOL" from, i've almost looked every where for it. I've checked with speedtech, yokomousa, square, Suzuki and tobee. I can't seem to find it. Can some please point to the right direction.
ZeroCooL is offline   Reply With Quote
Old 06-11-2004, 02:53 PM   #8525
Default Re: Spool.
Speedtech has them in stock look up under speedtech hop-ups
teamgreen is offline   Reply With Quote
Old 06-12-2004, 02:54 PM   #8526
Wicked's Avatar
Default Hey fellow Yok owners
eh
Baja 5B Flux, Baja 5T, HPI Savage Flux XL, Brushless Erevo, Summit, X Maxx, Arrma Big Rock, Tamiya Bruiser, & Hi lux, Slash, Skully,
Blade 200qx, Inductrix 200, Nano qx2 fpv, Cx, Proto X SLT
Wicked is offline   Reply With Quote
Old 06-12-2004, 03:15 PM   #8527
NVisible's Avatar
ew. dusty rims
NVisible is offline   Reply With Quote
Old 06-12-2004, 07:11 PM   #8528
dawgmeat's Avatar
Default Spare parts
bash a A-arm due to bad driving, Does anybody know who sell the new heavy duty A-arms # SD-008HD
dawgmeat is offline   Reply With Quote
Old 06-12-2004, 08:24 PM   #8529
Tek Nickal's Avatar
Originally posted by utieh
Joe,
thanks.
I learned my lesson by tightening my diffs too much, the diff screw breaks very easily.
Tek Nickal is offline   Reply With Quote
Old 06-12-2004, 08:44 PM   #8530
Matt Howard's Avatar
Default Re: Spare parts
I asked about them two weeks ago at the Reedy race and they weren't in the states then. I don't know if Yokomo received them in since then, I'll call on monday to see.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 06-12-2004, 10:29 PM   #8531
Tek Nickal's Avatar
Where would you guys start with springs on an small asphalt parking lot? I was thinking Rayspeed Green front, Rayspeed Blue rear.
Old 06-13-2004, 09:35 AM   #8532
dawgmeat's Avatar
Default New CGM part
Can someone convert 5500 yen for me, I saw this at Yokomo Japan website.
Old 06-13-2004, 09:42 AM   #8533
NVisible's Avatar
50.73USD
Old 06-13-2004, 09:42 AM   #8534
AdR|aN's Avatar
Send a message via ICQ to AdR|aN
5500 yen = USD 49.96
If you need any conversion, you can try www.xe.com
AdR|aN is offline   Reply With Quote
Old 06-13-2004, 10:10 AM   #8535
JayBee's Avatar
Trader Rating: 31 (100%+)
Post Re: New CGM part
what is this?
JayBee is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
