Old 06-07-2004, 10:20 PM   #8461
JimmyMac's Avatar
Have yall tried the Masami 2003 Reedy Race setup for the Spools? I think it works great on my CGM. I've had problems before with my CGM being too loose in the rear end and haven't had time to work it out due to my other car (TRF415). So I opted to try a "pro" setup and work from there. It worked out pretty good. So I'd suggest that as a starting point and tune from there.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 06-07-2004, 11:32 PM   #8462
utieh's Avatar
Default Spool set-up
where is it possible to find it?
utieh is offline   Reply With Quote
Old 06-07-2004, 11:54 PM   #8463
JimmyMac's Avatar
Try here, if you can not access it, you'll need to become a member... which is easy...
http://www.rczone.net/files/yokomo/m...edy_250503.pdf
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 06-08-2004, 12:39 AM   #8464
johnbull's Avatar
Hi friends. Greetings from Malta.
GILLES - UTIEH.
I have run a spool forover 6 months now, and just would not be without it.
If you run Rayspeed towers or CGM then run everything the same front and rear.
Shocks (front and rear) 35 oil, AE green springs and retainers. 2nd outermost hole on towers and wishbones. No front kick up. No rear anti squat. 7 deg. alloy caster blocks (C hubs). 1 deg. neg. front and 2 deg. neg. rear. Take off 22 tyres. Thicker roll bar in front.
I have been running the car this weekend with an 8 turn single and have been impressed with my lap times when compared to what the other good guys are doing, and my son's lap record.
If I can lap within around a second of his time then I know it's going well.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 06-08-2004, 12:56 AM   #8465
tornado
Guest
Posts: n/a
Sorry guys.....please forgive my ignorance....but what is spool ? Can anyone please tell my ?
Thanks.
Old 06-08-2004, 12:59 AM   #8466
Thanks.
Was going to ask the same thing, glad you did it first lol. It just sounds like locking the diff?
Mabuchi540 is offline   Reply With Quote
Old 06-08-2004, 01:02 AM   #8467
Tek Nickal's Avatar
Yes, a spool is a locked diff.
Tek Nickal is offline   Reply With Quote
Old 06-08-2004, 01:45 AM   #8468
Registered User
Hi-LowBrow's Avatar
Send a message via Yahoo to Hi-LowBrow
Originally posted by asimo
Attn: Rayspeed Owners
It is recommended that you run the SS shock bodies for the Rayspeed chassis. Can someone tell me the difference between the SSS vs SS shock body. Is it completly different?
SS shock bodies are good for low traction surface,SSS shock bodies are good for high traction surface. if you like the quick steering car, go for the SSS shock bodies, if you like the mild steering car or dont have enough traction go for the SS shock bodies.besides Shinnosuke Adachi (who developed RS chassis) told me the same thing, when I asked him about it .
Hi-LowBrow is offline   Reply With Quote
Old 06-08-2004, 02:38 AM   #8469
tornado
Guest
Posts: n/a
Aso! Wah karimaseteh (I got it !)
Old 06-08-2004, 02:50 AM   #8470
alch's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to alch
Wakarimashita!
alch is offline   Reply With Quote
Old 06-08-2004, 05:45 AM   #8471
asimo's Avatar
Thanks for responding guys!
I did that trick by using the rayspeed spring retainers with the yokomo springs to adjust the height i wanted. But the car felt funny. I'll try and play around with the shock positions but i'll probably get the SS shock bodies because I race on medium grip tracks.
Thanks!
asimo is offline   Reply With Quote
Old 06-08-2004, 07:31 AM   #8472
Lonestar's Avatar
when adjusting ride, make sure you still have the same REAL amount of downtravel... else the car handling changes
Later,
Paul
Thanks!
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 06-08-2004, 07:53 AM   #8473
what are goods ratio for 23T and 12T motors? how many teeth for pinion and spur gear that i have to use? please help.. tx
hamba is offline   Reply With Quote
Old 06-08-2004, 11:18 AM   #8474
Sleighty's Avatar
Talking carpet setup adjustment
hey guys,
I ran on carpet at the weekend on foams and despite winning i have 2 problems. I run 35shore front tyres and 37Shore rears and my rears are wearing miles faster than my fronts, my fronts look nearly new were as my rears are degrading much too fast. Also i have alot of power oversteer or at least the car gets very loose on the power, meaning i have to be very soft on the throttle.
Any suggestions on how to fix these problems? Harder springs,softer? I have a good turn in and corner stability but the car just doesnt like coming out of corners properly
Oh and btw the tyres are Team Orion Fresh Kicks
thanks in advance
A1-RC.com
Team Scream
Xray
Sleighty is offline   Reply With Quote
Old 06-08-2004, 12:21 PM   #8475
utieh's Avatar
Kilruf, Joe,
thank you very much.
I will have a look at RCZone.
I'm using the Yok springs, the Asso Green is close to which yok spring???
Thanks again.
Gilles
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
