Old 06-06-2004, 11:45 AM   #8446
Those kits sold in Asia and Europe come with one-way as standard, while the US version has a front diff. I think 1 ounce is about 28.4g, so 53 ounce is 1505g.
caveman is offline   Reply With Quote
Old 06-06-2004, 01:49 PM   #8447
Lonestar's Avatar
Default Re: Re: Re: A couple of quick Yokomo questions....
Originally posted by JayBee
true, no tires are included in the kit only dish wheels, which is actually a very good set. they have two different compounds that i'm aware of. one's stiff and the other is slightly softer.
and the front one-way is a 'HOP-UP'. it is a good hop-up to have in your arsenal
WARNING TO BEGINNER DRIVERS: Do not use yokomo dish wheels unless you can stay away from boards... They're rigid and nicely designed (read light), but as with every stiff component with reduced rotating mass, they're fragile and brittle... Don't tell us we didn't warn you
No tires in the kit.
Mabuchi540: Don't bother about oneways for now, i recommend a 2-diff setup.
Later,
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 06-06-2004, 10:47 PM   #8448
Post Another quick one....
Apart from the chassis what's the difference between the CGM and the SSG visually I can't spot it from the pictures I've seen? If anyone knows of a good side by side comparison that would be appreciated.
Mabuchi540 is offline   Reply With Quote
Old 06-07-2004, 01:51 AM   #8449
Lonestar's Avatar
Default Re: Another quick one....
apart from the chassis?
The CGM is all graphite-loaded plastic, the SSG has more flexible parts. Transmission and suspension are similar. The CGM also uses a different steering, shock tower, and then there's a few extra parts due to the architecture change, like the hingepin holders and chassis braces... But the chassis is a hell of a change by itself...
Btw, I still drive the SSG and I'm perfectly happy with it... at least it doesn't look like a TC3 To me it's still the sexiest-looking car on the market, and it drives well. It's also a little more forgiving on low-to-medium grip conditions, due to the extra flex.
Later,
Paul
Old 06-07-2004, 04:08 AM   #8450
asimo's Avatar
Attn: Rayspeed Owners
I'm having problems trying to adjust my chassis ride height.
I race on foams so the diameter of the wheel changes. If i run new set of foams. I can't get my ride height lower than 7mm.
It is recommended that you run the SS shock bodies for the Rayspeed chassis. Can someone tell me the difference between the SSS vs SS shock body. Is it completly different?
I originally had problems trying to get the length of the standard shocks to fit properly but then used the spare plastic shock ends included in the SD kit to convert it to make the shock length longer.
asimo is offline   Reply With Quote
Old 06-07-2004, 06:18 AM   #8451
johnbull's Avatar
The SS shock bodies recommended by Rayspeed are slightly longer.
Use long shock ends all round and you will have no problems.
johnbull is offline   Reply With Quote
Old 06-07-2004, 06:20 AM   #8452
Lonestar's Avatar
Asimo
the difference between SS and SSS shocks body is their length indeed. Playing with shock ends to compensate is a common trick. You can also try to unscrew them a bit in order to get a few extra millimeters.
Another trick is using the most appropriate hole on the front C-hub...
Hope this helps,
Later,
Paul
Old 06-07-2004, 07:43 AM   #8453
chappi's Avatar
Trader Rating: 17 (95%+)
Default Just a Question.....
Since Yokomo CGM is so similar to TC3...
I just wondering, when they both out of the box, is it the weights are same?
or CGM still heavier then TC3 ?
chappi is offline   Reply With Quote
Old 06-07-2004, 09:04 AM   #8454
sigmund's Avatar
@ asimo
I run the Rayspeed shock towers, with the original shock bodies and yokomo springs. To get the the proper ride height you need the long shock ends combined with the rayspeed aluminum spring holder thingy (don't remember what it's called, I usually speak norwegian...) These make the spring sit "lower" on the shock end.
I usually run rubber tires, with my shocks at 64mm and have no problems setting the ride height between 4 and 6 mm. This also depends on which holes you use between the arms and hubs.
Sigmund
sigmund is offline   Reply With Quote
Old 06-07-2004, 09:22 AM   #8455
lem2's Avatar
Default Re: Just a Question.....
CGM is heavier.
lem2 is offline   Reply With Quote
Old 06-07-2004, 01:14 PM   #8456
utieh's Avatar
Default Front diff to Spool set-up
I've just ordered a spool from SpeedTechRC.
It seems that can't find any good set-up with the oneway on my track (the surface is a little bit odd, abrasive but no grip)
The diff works fine but the car is "slow"
I would like to know in which way should I change my set-up if I am switching to a spool.
Gilles
utieh is offline   Reply With Quote
Old 06-07-2004, 08:56 PM   #8457
RamFit's Avatar
I also Having the same prob with u Utieh..!!! my track is Tarmac but damn slippery and we all play at Midnight can u imagine the track conditioins and how much tracksion we have ...?? i only can push the car to med speed only if u pull to full trottle the car will spin i'm now trying an error to find the right setup of my car and i think with a little bit of settings changes its would be Okay
RamFit is offline   Reply With Quote
Old 06-07-2004, 09:40 PM   #8458
Tek Nickal's Avatar
Does anyone have a picture of the Speedtech spool? Haven't seen one yet.
Tek Nickal is offline   Reply With Quote
Old 06-07-2004, 09:53 PM   #8459
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
DITTO
JayBee is offline   Reply With Quote
Old 06-07-2004, 09:55 PM   #8460
tornado
Guest
Posts: n/a
Try cutting the foam to match the size of rubber.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
