Old 06-01-2004, 10:11 PM   #8401
lowline's Avatar
hey guys i have been running tc3 for 3 years and switched to cgm are there any hop up aluminum steering blocks and if so where i could order them thanks.one other thing have you guys had any problems with diff screws breaking and if so how did you remedy the problem.
lowline is offline   Reply With Quote
Old 06-01-2004, 10:35 PM   #8402
tornado
Guest
Posts: n/a
Just tested my CGM......my only comment is ......its sooooo easy to drive!!
Here is my ride
Old 06-02-2004, 12:04 AM   #8403
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
Here is my ride
NICE ride
JayBee is offline   Reply With Quote
Old 06-02-2004, 12:05 AM   #8404
JayBee's Avatar
Post Re: Here you go
Originally posted by Yokomo Aust
Just took this now sorry if it is not clear. I have the MC800 futaba speedie and s9550 digital servo with HRS reciever. Other hop ups are Team Suzuki front and rear drive shaft cups alloy front steering knuckles and all alloy hinge pin mounts and alloy king pins.
one NICE ride
Old 06-02-2004, 01:10 AM   #8405
tornado
Guest
Posts: n/a
Thnx !
Old 06-02-2004, 01:39 AM   #8406
Lonestar's Avatar
utieh,
I'd think endbell too... check out on overrc, in Cobra's report I think there's some pics about how he did his. A fan works just fine too
Weighted my car yesterday... SD SSG with no central plate, no rollbars, Cyclone TC, Older Airtronics 94157 servo (MG), two servo savers to reduce slop, suzuki spindles, Tobee bones rear and Square Ti Front, Personal transponder, Team Orion B rubbers, Orion Revolution, 3000HV's & 3-color Mazda 6 body (not light) : 1520grms
I guess with a little massaging and some more modern electronics, I'd easily go below 1500gms...
Later,
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 06-02-2004, 02:45 AM   #8407
forty6's Avatar
Actually, you can get rid of your additional servo saver setup to save some weight. It does absolutely nothing to reduce slop. The slop is between the bearings the the blue alloy steering post. It is very cheap to try (about $4) so a couple of my buddies and I tried it. It did nothing. All it did was get in the way of the servo arm when you do the 90 deg servo mod. Just my .02.
forty6 is offline   Reply With Quote
Old 06-02-2004, 05:44 AM   #8408
johnbull's Avatar
Originally posted by Lonestar
utieh,
Later,
Paul
I'd be happy running 1520 grams. I would certainly never start a race with less than 1510 grams.
SERVO SAVERS. I was having a look at a pic of Masami's CGM. He doesn't run a servo saver at all.
Both my Yokes and my son's TC3 also run without a servo saver. So long as you have a good servo, preferably with metal gears, there shouldn't be a problem,and it's a fine way to reduce some more unnecessary weight.
johnbull is offline   Reply With Quote
Old 06-02-2004, 08:01 AM   #8409
STLNLST's Avatar
Trader Rating: 21 (100%+)
I'd like to take this time to thank a buddy that has helped and teased me over the last couple of years. Matt Howard will be leaving us soon to go to Korea (i think) for a year. No matter how much crap I threw at him he always came back with a good one liner. Thank you Matt for the great times. I will run your body colors at the speedworld cup in honor of you.....if that's okay by you.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 06-02-2004, 08:49 AM   #8410
I also want to thank Matt for all the help he has given Alex and me in the past, not to mention the competition, they don't call him the "Rocket Man" for nothing. Also thanks for the all the laughs. STNLST, you won't go any faster running Matt's colors!
pops is offline   Reply With Quote
Old 06-02-2004, 10:05 AM   #8411
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Originally posted by chappi
@ Sparx
Wah!! u have done so much modification to your CGM! so you pretty much change all the parts to light weight parts, to achive the weight of 1498..
Do you know the out-of-box weight of a CGM?
From what i know the boxstock weight is around 1530-1550 depending on who you ask
The electronics i run is: KO Propo KR302 AHSR reciever, LRP Quantum 2 esc and Futaba S9550 servo
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 06-02-2004, 11:59 AM   #8412
forty6's Avatar
I don't know Matt H. personally but he certainly helped me a bunch of times here. Goodluck to you.
Old 06-02-2004, 08:44 PM   #8413
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
Anyone get a setup from the Yokomo team guys (Tosolini, Masami, Matt) at the Reedy? ANy info on premount 27's setups would help a bunch!
Jeff
Jeff Werner is offline   Reply With Quote
Old 06-02-2004, 08:50 PM   #8414
Trader Rating: 47 (100%+)
Jeff, I'm looking forward to the Hutchfest race. I may need a little help with setup on my CGM, I won't have alot of run time on it, by that week end.
porter is offline   Reply With Quote
Old 06-03-2004, 02:48 AM   #8415
Lonestar's Avatar
Actually, I don't agree with you.
The slop in the left-side steering knuckle is indeed coming mostly from the axial play of the 2 bearings that hold the left bellcrank on the left blue post (still following me here?). On the standard left assembly, both bearings are right next to each other, which allows more slop (the bellcrank can "twist" more on the post). On the servo-saver side, bearings are split apart at both ends of the post... the slop in each bearing is the very same, but it allows for less overall "twist". So, yes, using a second servo saver on the left side DOES reduce slop. More important, it gives a very similar slop on both sides of the car, which makes a difference in the handling, believe me.
Please do not use such bold statements as "it does absolutely nothing to..." for solutions that have a valid mechanical reasoning behind them. It probably didn't help that much on your car because there was too much slop in all the other parts of the steering linkages, but it does reduce slop and make it symetric.
Joe, as far as running with no servo saver at all... I guess Masami can afford not to... but sometimes boards just jump in front of my car without notice , I don't know why, I tell them not to, but they still do it after years and years of racing... Plus I pay for my stuff... So I have to run a servo-saver I don't think weight is that much of an issue anyway... First we need to learn how todrive consistently, THEN we should care about weight!
Later yall
Paul
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
