Old 05-25-2004, 10:18 PM   #8371
Matt Howard's Avatar
foam or rubber tires? email me at [email protected] and I'll set you up
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 05-26-2004, 12:51 AM   #8372
johnbull's Avatar
Originally posted by forty6
johnbull,
Isn't there some slop too between the plastic ball and the screw that holds it?
Not if you tighten the screw home. Careful not to overtighten, remember you are working in plastic. Just screw them well home.
johnbull is offline   Reply With Quote
Old 05-26-2004, 11:38 AM   #8373
lowline's Avatar
Hey matt i sent you an email thanks.
lowline is offline   Reply With Quote
Old 05-27-2004, 12:58 PM   #8374
NVisible's Avatar
what toolset are you guys using on your SD? the one i have is mostly standard. i have a 2.5 and a 1.5, but they fit rather loose in the factory screws. can anyone reccomend a set?
NVisible is offline   Reply With Quote
Old 05-27-2004, 04:10 PM   #8375
sosidge's Avatar
You need a 2mm allen driver for almost every screw in the car.
The only exceptions I can think of are the small phillips head screws that hold the hinge pins in place (use a #1 phillips), the motor screws (ball end 2.5mm driver supplied already) and a few small grub screws (which I think are 1.5mm).
Any quality tool will do - I have RPM and Wiha metric allen drivers in my pit box.
Old 05-27-2004, 04:41 PM   #8376
NVisible's Avatar
great, thanks!
Old 05-28-2004, 11:27 AM   #8377
Trader Rating: 47 (100%+)
Hey guys I have another quick question. Is the mount that the front chassi brace screws too, the same that was used for the upper chassi brace for the SD? And if not what is the part # for that piece?
I purchased a car that I believe was converted to a CGM, and this person did a very poor job of assembling. When I mount the front brace to the tranny case there is about a 1.5 - 2 mm gap between the chassi and the brace, plus the screw holes don't line up. I know that the rear brace mount was changed, so I'm hoping that the front was too. Any help would be greatly appreciated.
porter
porter is offline   Reply With Quote
Old 05-28-2004, 11:31 AM   #8378
Registered User
you need to use CGM upper deck mount. They are different than other SD.
Aku-Man is offline   Reply With Quote
Old 05-28-2004, 11:59 AM   #8379
Do you have a part # I don't have a manual, and I can't find anything on Yokomos site.
Old 05-28-2004, 08:58 PM   #8380
Sorry everyone my site was down for a while. Its back up and working properly. Let me know if there are anymore problems. tonight I will put matt's spool setup on there.
Greg http://yokomo.tk
shortygy is offline   Reply With Quote
Old 05-29-2004, 10:40 PM   #8381
rc_bam226's Avatar
Hey shrtygy, the site still is down.
rc_bam226 is offline   Reply With Quote
Old 05-30-2004, 10:05 AM   #8382
NVisible's Avatar
an odd question for you all. my SD is my first shaft car, so im unsure of something. With no elecs in the car if i roll it back and forth im hearing a clicking sound coming from the front drivetrain. Is this normal, or is this something i should look to eliminate?
Old 05-30-2004, 10:10 AM   #8383
lem2's Avatar
2 things: either your tranny cover is loose or one of the teeth in the gears are missing,bent or wasted.
Peace and Happy Racing
PS: run the CGM in Mod and such a dream to drive!!!!
lem2 is offline   Reply With Quote
Old 05-30-2004, 11:26 AM   #8384
NVisible's Avatar
thx ill give that a look when i have some spare time.
im thinking of getting the rayspeed conversion for my SSG. We dont do a hell of alot of racing up here, so it would be mostly cosmetic. is the CGM that much of an upgrade to the ssg?
Old 05-30-2004, 07:22 PM   #8385
??? I Think that it is working fine now...... Please let me know if its down still
Greg
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
