Old 05-23-2004, 10:04 PM   #8356
Default tie rod ends
John Bull, what are you using for the tie rod ends on your cars. Seems like they would have less slop and be easier to work on than normal ball cups.
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
Old 05-23-2004, 10:06 PM   #8357
Registered User
http://www.team-orion.ch/global/global_news.asp?id=2413
Anybody know where can I get this part?
Aku-Man is offline   Reply With Quote
Old 05-23-2004, 11:21 PM   #8358
Tek Nickal's Avatar
Looks like its from the UK. http://www.cmldistribution.co.uk/
Its 22.99. Or $38.23.
Tek Nickal is offline   Reply With Quote
Old 05-23-2004, 11:33 PM   #8359
alch's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to alch
Unfortunately you can buy directly from them.. You would have to look through the store list to find a distributor..
alch is offline   Reply With Quote
Old 05-23-2004, 11:47 PM   #8360
forty6's Avatar
Speedtech's spool for the SD is nice too.
forty6 is offline   Reply With Quote
Old 05-24-2004, 01:13 AM   #8361
johnbull's Avatar
Default Re: tie rod ends
MERF,
All tie rod ends used on both my SD and my son's TC3 are Associated shock ends.
They have outlasted everything else I have tried in terms of play. The best bit is that if they are starting to loosen all I do is tighten up the screw a bit and that expands the ball and takes up the play.
AKU MAN.
I have just ordered a stock of spools today - from the manufacturer.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 05-25-2004, 01:03 AM   #8362
alch's Avatar
Johnbull,
What are you using in place of the ball studs for the associated shock ends?
Cheers
Old 05-25-2004, 02:29 AM   #8363
johnbull's Avatar
Originally posted by alch
Johnbull,
Cheers
I use the Associated shock ends, complete with their own plastic balls, everywhere.
Old 05-25-2004, 06:44 AM   #8364
alch's Avatar
Thanks. I thought as much! Just thought i would check since it is quite an expensive option, but hopefully well worrth it from the sounds of it.
Old 05-25-2004, 08:46 AM   #8365
forty6's Avatar
johnbull,
Isn't there some slop too between the plastic ball and the screw that holds it?
Old 05-25-2004, 08:34 PM   #8366
Trader Rating: 47 (100%+)
Hi guys just have a quick question. Is the main shaft on the CGM the same length as the one on the SD?
porter is offline   Reply With Quote
Old 05-25-2004, 08:36 PM   #8367
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
Yes- I used the conversion kit and am running the one out of my SSG.
Jeff
Jeff Werner is offline   Reply With Quote
Old 05-25-2004, 10:11 PM   #8368
lowline's Avatar
Looking for a little advice i just changed from tc3 to cgm are there any weak points or parts i need to be aware of?
lowline is offline   Reply With Quote
Old 05-25-2004, 10:13 PM   #8369
Matt Howard's Avatar
Just get the wide front bumper or make a buds TC3 one fit and you'll be fine.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 05-25-2004, 10:16 PM   #8370
lowline's Avatar
Good i already put on the large bumper thanks if any of you guys have a carpet set i would appreciate it.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
