Old 05-16-2004, 11:59 PM   #8296
Hi guys:
I am pretty new to here, got my used MR-4TC SD a month ago, it was like new with bunch of hop-up, and i realize i am well too new, this thread has 277pages now, i am too busy to sit and read. I dont know if anyone asked or mentioned my question already, so i wonder if there is a part for Tamiya bodies? i mean all my bodies r Tamiya, i dont wanna measure and drill a new hole on it, it will look kinda weird with bunch of holes....
Thanks!
BBSGS4 is offline   Reply With Quote
Old 05-17-2004, 03:22 AM   #8297
sosidge's Avatar
Sorry, you're going to have to re-drill!
Old 05-17-2004, 08:44 AM   #8298
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
What's the advantage of using the top-mounted sway bar as opposed to the standard sway. I noticed that Masami and other Yokomo drivers seem to prefer using the top-mounted one. Are there specific situations (i.e. track conditions, surface, type of tires, etc) where one type works better than the other? Thanks.
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 05-17-2004, 12:33 PM   #8299
Trader Rating: 35 (100%+)
Default Spool
Can anyone describe the feel/characteristics of using a Spool compared to using ball diff or oneway?
I've used ball diffs and one ways.
Geppetto is offline   Reply With Quote
Old 05-17-2004, 04:20 PM   #8300
Matt Howard's Avatar
Default Re: Spool
a spool will have less steering than both the diff and oneway coming into a corner but it will have the same pull out of the corner as the oneway. It will also be easier to drive than a oneway and you'll be able to use the brakes to pass someone if you need it.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 05-17-2004, 04:26 PM   #8301
such a pain in the butt to measure it....
is there any easy way???
or i realy have to measure it???
Old 05-17-2004, 05:20 PM   #8302
The easy way is to place the body over the chassis and line up the wheel wells over the wheels. Take a flash light and shine it up from the bottom. Mark where the body posts are and drill away. This should work unless you have a real thick coat of paint.
Headbanger is offline   Reply With Quote
Old 05-18-2004, 02:10 PM   #8303
NVisible's Avatar
Default pics
wow 2nd page, thats no good.
Just got my car in the mail today, and of course. heres teh pix!
56k beware
1
2
3
Oh, just a question. What can i do about that battery strap? do they make a nicer looking (ano blue) one for it?
NVisible is offline   Reply With Quote
Old 05-18-2004, 03:23 PM   #8304
utieh's Avatar
NVisible,
Shooter's is making a blue anoed battery strap, some shops in HK and Japan are selling it.
Does someone have some news about the new arms?
are the mounting holes different, did some yokomo drivers tried to put front or rear arms everywhere?
utieh is offline   Reply With Quote
Old 05-18-2004, 06:19 PM   #8305
You can also use the battery strap from the MR4tc - special car. It is blue andoised and it says YOKOMO on it. Cnc'ed in.
shortygy is offline   Reply With Quote
Old 05-18-2004, 06:26 PM   #8306
NVisible's Avatar
cool, thanks guys
Old 05-18-2004, 11:05 PM   #8307
jas
jas's Avatar
The CGM Conversion Kit doesn't come with the graphite parts (arms, hubs, steering blocks, C-hubs, gear box) as the full CGM kit does. Is that right?
Thanks in advance!
jas is offline   Reply With Quote
Old 05-18-2004, 11:33 PM   #8308
Trader Rating: 21 (100%+)
The conversion kit only comes with the parts to convert a regular plate chassis to the tub: chassis, shock towers, steering bellcranks, motor mount, chassis braces, and suspension mounts.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 05-19-2004, 03:04 AM   #8309
asimo's Avatar
Does anyone have pics of the SSS/SS shock bodies. I want to see the difference.
I'm running a Rayspeed conversion on my Black. It recommends to run the SS shock bodies which are the longer ones right? The kit ones are the short ones?
Also, for those who are running the rayspeed chassis. Can you guys manage to run the Upper sway bars at the front? without having the shocks mounted to close to the middle?
asimo is offline   Reply With Quote
Old 05-19-2004, 04:39 AM   #8310
c.callcott's Avatar
Send a message via ICQ to c.callcott
do you guys race rubber tyres in the US?
as i've only run my sd on foam, and i have the aussie winter champs coming up soon and they are going to be running a control rubber tyre and they will more then likely be sorex 28 or maybe even 24's...
If you guys dont mind, you wouldnt have any setup tips or starting points etc that work good over there?
c.callcott is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
