Old 05-12-2004, 07:09 PM   #8251
Originally posted by magerz24
Is there anything I can do to increase the durability of the steering knuckles except not hitting anything. I tried shoegoo but that did nothing. And Suzuki doesnt seam to want people to buy their product.
I would highly recomend the graphite steering knuckles as well as the graphite caster blocks. Also replace the kingpins with the new lightweight ones. IMHO they are stronger than the plastic ones.
pops is offline   Reply With Quote
Old 05-12-2004, 07:57 PM   #8252
Trader Rating: 47 (100%+)
Yodace, I thought your car looked fine Saturday, you were running just as fast lap times if not faster than Gary, and Greg. You just had trouble with lap traffic. Also wanted to let you know that I found pretty much a comlpete setup that I am purchasing, wich includes a CGM kit, so I will be back racing sooner than I thought. Also just to let you know, when I had my SD I also removed shims from the tranny, and had no trouble. you might try it if your still wanting to get the thing freed up.
Have you fellas noticed a big difference between the original SD and the CGM, or is it mostly the fact that the tweak issue is pretty much gone?
porter is offline   Reply With Quote
Old 05-12-2004, 08:00 PM   #8253
Tek Nickal's Avatar
Flex is also gone. Suspension geometry is different, a bunch of stuff, the list goes on . . . .
Tek Nickal is offline   Reply With Quote
Old 05-12-2004, 08:04 PM   #8254
so its pretty much a different car, suspension wise. But, for the better I presume.
Old 05-12-2004, 08:05 PM   #8255
Trader Rating: 21 (100%+)
Phil-Try the graphite stuff like pops suggested. They are way stronger than the standards.I would also run the new wide bumper. It really lessens the parts breakage in the front and not bending hinge pins. Also seems to let the bearings last longer before they go. I should be down to Trackside in the next 2 weeks. I'll see if I can locate some knuckles for you.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 05-12-2004, 09:27 PM   #8256
Default Advantages of the CGM?
I am trying to figure out which shaft drive car to buy. I was wondering if anyone had any comments on what they think the advantage of the CGM is over the HPI Pro 4 and the TC3? My list is down to those I believe, so any help would be appreciated.
FR
FL_Racer is offline   Reply With Quote
Old 05-12-2004, 09:32 PM   #8257
yodace's Avatar
R/C Tech Charter Subscriber
Thumbs up
Porter,
I took out shim yesterday.. I haven't touched the set-up at all..
Just looking my car over and tighting screws that came lose...Cleaning bearings..
Droop looked alittle funny. Thats why I was asking the droop questions.. I thought you order something from Mike last week...
EveryBody,
So do u guy's suggest the CG chassis over the SD for all surface?
yodace is offline   Reply With Quote
Old 05-12-2004, 09:34 PM   #8258
yodace's Avatar
What is the part number for the shock oil that comes in the kits?
450 I think...
Old 05-12-2004, 10:28 PM   #8259
Matt Howard's Avatar
The suspension geometry is the same, it's just a better chassis
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 05-13-2004, 12:06 AM   #8260
I used to always run the car with less shims in the tranny. I ran at low-med grip carpet track. I went down to the states for a big race where they had a high grip track and a friend of mine down there said watch the tranny gears they blow. I said I had never blown one then sure enough i blew one up. I believe it has something to do with the amount of grip you have on the track because of the extra load it puts on the tranny.
Looks like Yokomo made another improvement on the CGM Theres yokomo's customer response for ya.
BTW.. Matt weren't you going to korea... or sumthing just wondering...
Greg
shortygy is offline   Reply With Quote
Old 05-13-2004, 12:18 AM   #8261
Tek Nickal's Avatar
Aren't the shock towers different?
Old 05-13-2004, 03:40 AM   #8262
sosidge's Avatar
Shock towers are different - but I wouldn't call that "suspension geometry" per se. A change of roll centre or caster angles or link mountings, that would be new geometry.
Old 05-13-2004, 04:57 AM   #8263
Horatio's Avatar
Shock *angles* are very much part of suspension *geometry*.
Since when hasn't it been? Or am I missing something?
Horatio is offline   Reply With Quote
Old 05-13-2004, 04:58 AM   #8264
Lonestar's Avatar
1) don't hit anything
2) Speed racing makes a similar product... you can find it at Dinball I think
Later
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 05-13-2004, 05:01 AM   #8265
Lonestar's Avatar
Originally posted by yodace
DROOP
I use AE shocks with AE shock ends.I run on asphalt. What is a good droop setting... I had a friend set the droop, he said he set it at 6 and 5... But when I went to check the front droop it looks like he set it at 8...Do u set the droop with the shocks on or off...
He also told me to check the front droop setting using the back of the front a-arm... Any help would me good... The car handles good...I was just checking settings.
Your shocks shouldn't be limiting droop. The droop adjustments should only be performed through the btr screws in the arms... you should have longer shocks. If everything is properly set-up. measuring droop with or without shocks should make no difference... the good thing about unhooking shocks is that you can check for suspension freeness.
Later,
Paul
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
