Old 05-10-2004, 10:59 AM   #8206
johnbull's Avatar
Hi friends. Greetings from Malta.
GLIDE. The hubs I use are ZM 415 SH. They are the same as the normal MR4 hubs but take larger bearings.
POPS. Right. They are 12mm bearings.
Two things you will need to alter.
Firstly you get more ackerman with these hubs as the steering arm angle is different, but that's a plus point. You therefore need to shorten the turnbuckles - no problem.
Secondly you will have to put a 3 to 4 mm spacer between the ball and the hub arm. This is to line the steering buckle up so that you get as littlebump steer as possible. If you just assemble it without a spacer you will notice immediately what I mean.
GEPPETTO. I run droop at 5 in front and 3 at the rear. It's what all the fast guys in Europe seem to be setting the droop at. It works Ok on mine.
Here's a pic of the car with Fastrax alloy C hubs. Note that I have also mounted the outer top turnbuckle on the top of the kingpin.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 05-10-2004, 12:28 PM   #8207
yodace's Avatar
R/C Tech Charter Subscriber
Originally posted by Jeff Werner
The bearing conversion would be great to see it. I did convert my CGM's steering to the Ball Stud/Long Link like what was pictured on Masami's car from the Preworlds. I used ball studs and turnbuckle for the link between the two steering arms. I like the less slop that this conversion has.
Jeff
Were can I find pictures of what your talking about?
yodace is offline   Reply With Quote
Old 05-10-2004, 12:36 PM   #8208
Registered User
Masami's CGM
Aku-Man is offline   Reply With Quote
Old 05-10-2004, 12:38 PM   #8209
yodace's Avatar
The link doesn't work?
Old 05-10-2004, 12:39 PM   #8210
Registered User
Default Masami's CGM
Here
Old 05-10-2004, 12:42 PM   #8211
yodace's Avatar
Have you done the steering mod to your Yok yet? If so how what does it change the car?
Old 05-10-2004, 01:08 PM   #8212
Trader Rating: 35 (100%+)
Default Tosolini's SD Setup
I realize Chris has a thread, however, sometimes it takes a while to have questions answered, and other times the question may not get answered.
Anyway...
In the comments section of his (11/30/03) setup sheet it says: "USED 4MM PLASTIC SHIMS ON SHOCKS SHAFTS AS BUMPSTOPS" Do you think that he is referring to internal shock limiters? I'm guessing they are internal since his ride height is "4.5mm".
Also...
When the SD setup sheet shows Lower Suspension Arm Position, then gives a number like 2.0mm, does this referr to a spacer of that width inserted in front and behind the arm?
Some of these questions may seem elementary to some of you but, for me it's been 2 years since I raced touring cars, and my last car didn't have all of these adjustments.
Geppetto is offline   Reply With Quote
Old 05-10-2004, 02:20 PM   #8213
Trader Rating: 21 (100%+)
The bumpstop spacers go on the outside of the shock. They are used to keep the car from rollong over to far.
The number listed for the lower suspension arm is the thickness of spacer at that end of the arm. It goes between the arm and the suspension block.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 05-10-2004, 02:40 PM   #8214
Default Re: Masami's CGM
Originally posted by Aku-Man
Here
Got any more pictures of the car, or web site to view them?
pops is offline   Reply With Quote
Old 05-10-2004, 03:30 PM   #8215
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
That is a cool pic! Thanks for posting that. Pops- the pic I have seen of Masami's car was the one put on the PreWorld Host Website. They have a pic of the car from the side view.
Will get link up.....
Jeff
Jeff Werner is offline   Reply With Quote
Old 05-10-2004, 05:32 PM   #8216
yodace's Avatar
Post
DROOP
I use AE shocks with AE shock ends.I run on asphalt. What is a good droop setting...
I had a friend set the droop, he said he set it at 6 and 5...
But when I went to check the front droop it looks like he set it at 8...
Do u set the droop with the shocks on or off...
He also told me to check the front droop setting using the back of the front a-arm...
Any help would me good...
The car handles good...I was just checking settings.
Old 05-10-2004, 06:45 PM   #8217
K I have a problem on my recently used yok i bought off of my friend. it seems as if the shocks themselves are not long enough or something because the arms dont bottom out. the droop screws don't even touch! what is up? well im oging to go check it out now, i just want to hear your feedback. oh and what is the stock oil weight? thanks!
ATDI is offline   Reply With Quote
Old 05-10-2004, 06:49 PM   #8218
yodace's Avatar
I used the stock 40w all the way around my car...
I had the same problem were the the front/rear -arms weren't level.
So we threaded the shock ends (front/rear) out a little to get the droop set at 6f....5r
Old 05-10-2004, 07:39 PM   #8219
Your shock length is too short. Start with a length of at least 62.5mm in front and 60mm in rear. Yoke oil of 450 is a good starting point.
Old 05-10-2004, 08:02 PM   #8220
yodace's Avatar
pops,
How do u measure the shocks?
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
