Old 05-09-2004, 01:10 AM   #8161
utieh's Avatar
Team Bomber-G Style
The price is around 4000 Yens
utieh is offline   Reply With Quote
Old 05-09-2004, 01:32 AM   #8162
Tek Nickal's Avatar
Around $36. In case some people are lazy to go and calcualate.
Tek Nickal is offline   Reply With Quote
Old 05-09-2004, 01:34 AM   #8163
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
DOMOisCOOL is offline   Reply With Quote
Old 05-09-2004, 01:41 AM   #8164
utieh's Avatar
what about the quality of the shooter's?
I saw it at $20 in a shop in HK.
Old 05-09-2004, 03:13 AM   #8165
I used to have a titanium drive hollow drive shaft a machinist made for me for the tc3. It was very light and strong. All it was made of was a hollow titanium shaft and 2 of the tc3 dogbones cut down.. the composite ones and they were pinned in.
shortygy is offline   Reply With Quote
Old 05-09-2004, 08:21 AM   #8166
yodace's Avatar
anybody have problems with the stock bearings?
yodace is offline   Reply With Quote
Old 05-09-2004, 08:31 AM   #8167
Lowner_V1S's Avatar
Send a message via Yahoo to Lowner_V1S
hey ive got a yokomo sd but the US version (no 1 way) i just wanna know if i can modify the standard?! make it a one way? can you guys help me out with this? thanx
Lowner_V1S is offline   Reply With Quote
Old 05-09-2004, 08:37 AM   #8168
Default Re: Home made Fixed Spool
Originally posted by marzin
Hi,
I missed the DIY Fixed Spool....could someone post/explain it again, cos
I would like to make a Fixed Spool.
Thanks a Million!!
Btw Thanks to all who advised on the rear bearing binding, its better now.
Anyone ??
I tried finding but its too long
marzin is offline   Reply With Quote
Old 05-09-2004, 08:43 AM   #8169
Yes, going through front bearings alot. Have tried cheap to expensive bearings and they all go south pretty quickly. The ceramics last the longest, but I save them for big races. You can get a good deal from RCboys they have a website for cheap teflon bearings. If I remember correctly, you can get 10 each for around $1.30 each. They are not currently listed on their website, 6x10s but you can e-mail them and they will send them out. Cheap enough to use and toss without worrying about it too much. www.RCBoyz.com
pops is offline   Reply With Quote
Old 05-09-2004, 08:53 AM   #8170
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
Pops- when the bearings are going out what are the warning signs or how are you testing them to see if they need replaced.
Jeff
Jeff Werner is offline   Reply With Quote
Old 05-09-2004, 08:58 AM   #8171
Jeff
If it is real bad you will feel it when you rotate the wheel. But you really need to remove the bearings and clean them. When they are out and clean from any oil you can tell how gritty they are, and if they need to be replaced.
Old 05-09-2004, 10:10 AM   #8172
Matt Howard's Avatar
Default Re: Re: Home made Fixed Spool
Anyone ??
Losi sells spool pads that are sandpaper discs, I think they cost $1.50. Take apart your diff and clean all the diff lube off of the gear and diff rings. Put the spool pads on top of your diff rings with the sandpaper side out, leave all the diff balls out of the diff but keep the thrust bearings and spring in and screw everything down tight. You now have a spool. I've been running mine like this for over a month now with barely any wear.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 05-09-2004, 10:11 AM   #8173
There is no way to modify a diff to be a oneway, they are 100% different
RCTech #361
Old 05-09-2004, 10:26 AM   #8174
Matt and Pops...wanted to talk droop. What are your thoughts on initial starting spots for front and rear droop on the CGM? What changes are you looking at obtaining when running less droop (Higher number on guage)?
I am still trying to dial in my Yok...one run it is spooky fast then it gets unstable at times and am trying to get all the info I can...
Jeff
Old 05-09-2004, 11:17 AM   #8175
lem2's Avatar
Default Re: question
Originally posted by lem2
Hi!
will the team suzuki aluminum knuckles for the MR4TC-SP fit the SD? are they the same?
Thanks! Lem
anyone?
lem2 is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
