Old 05-07-2004, 09:30 PM   #8146
there are lots of setups on my site check them out they are all labeled so you can see what ashphalt setup u want.
http://www.yokomo.tk
shortygy is offline   Reply With Quote
Old 05-08-2004, 12:52 AM   #8147
pops is offline   Reply With Quote
Old 05-08-2004, 01:01 AM   #8148
Originally posted by Jeff Werner
Pops: have you guys switched over to the new wide bumper? Can you still run the bodied that were used while running the small bumper?
Also would you have a baseline outdoor asphalt setup that you guys are running now? Will be attending the Nats in July and am excited to get the CGM outdoors!
Jeff
No, Alex is running a Buds bumper. Matt Howard is running the new wide bumper and I think he had to trim the bumper to fit under the body. Matt Howard has a set-up for a spool, and Alex is running something very close. I tried to post it here but couldn't make it work.
Old 05-08-2004, 01:48 AM   #8149
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Originally posted by pops
I think the best new part out for the SD is the new lightweight kingpins. Because of their design the steering hubs align perfectly. There is no binding of the C hubs and steering hubs at all when you install these. Have been using them for about a month and the kingpins are not coming loose. Have bent a couple of the Suzuki knuckles and went to the graphite knuckles instead.
Cool. And just in time because I lost one of my kingpins
DOMOisCOOL is offline   Reply With Quote
Old 05-08-2004, 07:16 AM   #8150
asimo's Avatar
Thumbs up
I want to highly recomend the new Ti hinge pin retainer screws. These are self tapping, and go in twice as easy and twice as fast as the old 2.6 screws. You need two packs ZC-BH265T for all 4 arms. Great product, anybody else try them?
pops: I also agree with you that the new Yokomo kingpins are awesome! It used to take me quite a bit of time to get the plastic washers into place and be easy with tightening the kingpin to avoid binding.
With the new kingpins, SNAP and tighten! though I think i've treaded the steering blocks because the screws keep getting lose.
Great product!!!!
asimo is offline   Reply With Quote
Old 05-08-2004, 07:30 AM   #8151
Matt Howard's Avatar
Jeff
I've been using the new wide front bumper for a couple weeks now. You have to trim it to make it fit under the bodies but it really protects the front end. They give you a bigger foam piece as well that also is oversized, I just stuck with the stock foam piece since I didn't feel like shaving it down.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 05-08-2004, 08:01 AM   #8152
lem2's Avatar
Default question
Hi!
will the team suzuki aluminum knuckles for the MR4TC-SP fit the SD? are they the same?
Thanks! Lem
lem2 is offline   Reply With Quote
Old 05-08-2004, 08:35 AM   #8153
asimo's Avatar
Someone before asked about the 'Team Bomber' carbon drive shafts.
Here is a pic...
Top one is the standard kit shaft. 14g
2nd is the Yokomo Carbon shaft. 7g
Bottom is the Team Bomber shaft. 8g
The Yokomo carbon shaft as you know tends to twist. The Team Bomber shaft is thicker, better built and a lot stronger.
Was recommended by a Yokomo driver! shsshhh..
Old 05-08-2004, 09:05 AM   #8154
Registered User
ritchie's Avatar
back to the sway bar talk for a minute please, whats this about the upper and lower sway bar, i only know of where the directions said to put the sway bar. please help
ritchie is offline   Reply With Quote
Old 05-08-2004, 09:34 AM   #8155
chappi's Avatar
Trader Rating: 17 (95%+)
Default What gear ration U use for 19T motor
Yo, anyone running a 19T motor on their SD ?
tell me what spur and what pinion U guys using.
chappi is offline   Reply With Quote
Old 05-08-2004, 06:35 PM   #8156
Default Re: What gear ration U use for 19T motor
I use a 74 spur and a 26 pinion final drive 6.70. that's with a chameolon 2 on a med size track
teamgreen is offline   Reply With Quote
Old 05-08-2004, 06:46 PM   #8157
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
I'm running 100 spur w/35 pinion with 58mm foam tires.
Long straights but it seems to run very quick.
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 05-08-2004, 06:51 PM   #8158
The upper sway bar kit from the old belt drive car will also fit on the SD
RCTech #361
Old 05-08-2004, 07:33 PM   #8159
dawgmeat's Avatar
Default Team bomber
Nice pic of the shafts, Do they have website?
dawgmeat is offline   Reply With Quote
Old 05-08-2004, 10:22 PM   #8160
Tek Nickal's Avatar
What'll be the pricing on the bomber shafts?
Tek Nickal is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
