Old 05-06-2004, 11:08 AM   #8131
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
I agree with Pops on this. When I made my first SSG I had the same issue. Just take out that rear diff and make sure the rear drive gears is seated all the way. It is easy to miss it the first time.
Jeff
Jeff Werner is offline   Reply With Quote
Old 05-06-2004, 05:29 PM   #8132
Tek Nickal's Avatar
If you neglect to put thread lock on the screw that holds the gear to the input shaft, it can easily move and strip your gears.
Tek Nickal is offline   Reply With Quote
Old 05-06-2004, 10:54 PM   #8133
chappi's Avatar
Trader Rating: 17 (95%+)
Got a quick question
can the RAYSPEED conversion Kit fit on the new SD CGM chassis?
chappi is offline   Reply With Quote
Old 05-06-2004, 11:35 PM   #8134
Tek Nickal's Avatar
So you mean if you have the CGM chassis, you want to convert it to a Rayspeed? Yeah, I'd work.
Old 05-07-2004, 12:57 AM   #8135
chappi's Avatar
yes, thats what i mean...
thinking of getting the CGM chassis...
then buy the RAYSPEED conversion kit so that I can change the chassis to carbon.
hence I have both the tub chassis and a carbon chassis..
Is that work? AzNDAGster
Or has anyone has try this out in there SD CGM?
Old 05-07-2004, 05:38 AM   #8136
asimo's Avatar
Hey guys!
Swaybar question I want to clear up.
lower (short) vs Upper (long).
What's the difference in characteristics of the cars handling.
I remember someone telling me running the upper ones (long) gives the car more initial turn in. But I'm not 100% sure. Could be wrong.
Just wondering if someone could help me out! Or Could tell me everything I need to know about sway bars for the SD!
Thanks!
asimo is offline   Reply With Quote
Old 05-07-2004, 07:18 AM   #8137
Matt Howard's Avatar
Yes, it will work if you really want to do it. The CGM is IMO a better car than the rayspeed car. The RS car is a double deck car and it can take a tweek in a crash, the CGM will not.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 05-07-2004, 07:19 AM   #8138
sosidge's Avatar
You'll need a few more parts than just the Rayspeed conversion.
You'll need different wishbone mounts, some of the CGM ones are different.
You'll need some extra hardware for the steering assembly - like steering posts and screws, and maybe another servo saver assembly - the CGM steering assembly is different.
Maybe a few other parts, not sure as I have not tried the conversion myself (why would you want to?)
Old 05-07-2004, 07:20 AM   #8139
Originally posted by asimo
Hey guys!
Thanks!
I've been playing around the past couple weeks with both the lower and upper front sway bar. I really don't know why but I prefer the upper sway bar, I just like the feel of it better. I don't think either has more turn in or whatever, they just feel different.
RCTech #361
Old 05-07-2004, 08:19 AM   #8140
asimo's Avatar
Matt: I've only started to drive consistantly and want to learn more about car tunning. Want to know the design purpose between the 2 different sway bars.
Old 05-07-2004, 10:32 AM   #8141
Default Home made Fixed Spool
Hi,
I missed the DIY Fixed Spool....could someone post it again, cos
I would like to make a Fixed Spool.
Thanks a Million!!
Btw Thanks to all who advised on the rear bearing binding, its better now.
marzin is offline   Reply With Quote
Old 05-07-2004, 03:42 PM   #8142
JimmyMac's Avatar
For the sway bars, the upper sway bar as more leverage on the arm because it mounts out farther on the arm. The lower sway bar mounts closer to center.
I don't remember if this part was correct, but I thought the upper swaybar was made for highspeed tracks where as the lower was for more technical tracks.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 05-07-2004, 08:03 PM   #8143
I want to highly recomend the new Ti hinge pin retainer screws. These are self tapping, and go in twice as easy and twice as fast as the old 2.6 screws. You need two packs ZC-BH265T for all 4 arms. Great product, anybody else try them?
pops is offline   Reply With Quote
Old 05-07-2004, 08:14 PM   #8144
I think the best new part out for the SD is the new lightweight kingpins. Because of their design the steering hubs align perfectly. There is no binding of the C hubs and steering hubs at all when you install these. Have been using them for about a month and the kingpins are not coming loose. Have bent a couple of the Suzuki knuckles and went to the graphite knuckles instead.
Old 05-07-2004, 08:33 PM   #8145
Pops: have you guys switched over to the new wide bumper? Can you still run the bodied that were used while running the small bumper?
Also would you have a baseline outdoor asphalt setup that you guys are running now? Will be attending the Nats in July and am excited to get the CGM outdoors!
Jeff
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
