Old 05-04-2004, 07:25 AM   #8116
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
With the CGM you put a shim under the Front End Rear Hinge Pin mount correct to get anti dive correct? That is a great idea on the tires...I know that do that with foams on carpet...cool.
Would you run stiffer springs or swaybars?
Great to get info like this!
Jeff
Jeff Werner is offline   Reply With Quote
Old 05-04-2004, 09:52 AM   #8117
Trader Rating: 35 (100%+)
Default Re: Re: Finally happened...
Originally posted by Lonestar
[B]Howdy
here's a pic of my front shock tower... the extra outer hole is actually the body post holder, you can trim this one off too.
a dremel does the job just fine. Just wear a mask (breathing carbon fiber dust is not so good for your lungs).
Later,
Paul
PS: Sorry, blurry pic...
Paul
Thanks Paul. Even blurry, it give me an idea of what I need to do.
Geppetto is offline   Reply With Quote
Old 05-04-2004, 01:21 PM   #8118
Matt Howard's Avatar
Jeff
Yeah, just put a shim under rear suspension mount in the front, this will also give you more onpower steering. You might want to go a little stiffer with the springs but don't go too stiff
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 05-04-2004, 02:02 PM   #8119
yodace's Avatar
R/C Tech Charter Subscriber
Any tips on setting Droop would be great?
Do u set droop by looking at the bottom of the hub or a arm?
yodace is offline   Reply With Quote
Old 05-04-2004, 03:48 PM   #8120
sosidge's Avatar
Personally I set rear droop from the bottom of the hub, and front droop from the outside edge of the hub.
Old 05-04-2004, 04:54 PM   #8121
yodace's Avatar
Would anybody know if the CG conversion kit is composite or graphite?
Old 05-04-2004, 05:22 PM   #8122
It's graphite
RCTech #361
Old 05-05-2004, 02:40 AM   #8123
johnbull's Avatar
Hi friends. Greetings from Malta.
JEFF W. MATT H. We had serious traction roll problems when we first put our cars on the track at the 98 Worlds.
Amazing what people were doing to counter it. We were running Schumacher SSTs at the time.
Basically you need to get as little front grip as possible, and you need to bring the C of G (centre of gravity) as far down as possible and the RC (roll centre) as close to the C of G as possible. Stiff springs and stiff roll bars should help too.
Some guys were even running positive camber on the front wheels.
I wouldn't like to be in that situation again.
On a different tack Masami's and Chris Ts Yokes seemed absolutely dialled last weekend. It augers well for the Worlds.
Regards
Joe from sunny Malta.
Regards
johnbull is offline   Reply With Quote
Old 05-05-2004, 09:47 AM   #8124
What is the effect of having a bigger air-vent hole in the real tyre rims? I noticed some top driving been doing that.
Must the front rims have the same bigger air-vent hole too?? i.e., racing in the summer???
MIKA is offline   Reply With Quote
Old 05-06-2004, 01:15 AM   #8125
forty6's Avatar
forty6 is offline   Reply With Quote
Old 05-06-2004, 06:53 AM   #8126
bigger vent holes will keep the tire slightly cooler
RCTech #361
Old 05-06-2004, 10:16 AM   #8127
Default Emergency Help!
Hi,
I have a binding problem a the back differential!
The SDs drive ttrain was very smooth until I screw in the cover (tight enough, not too tight) for the back differential hub.
I had check the bearings are ok becos when i lossen the back cover the drive train was smooth again.
WAt should I do ?
Need urgent help !! THanks!!
marzin is offline   Reply With Quote
Old 05-06-2004, 10:25 AM   #8128
If the drive gear and rear shaft are not seated correctly, all the way forward, then the diff will not sit correctly and the cover will bind on the diff gear. Make sure you push that rear shaft all the way forward.
pops is offline   Reply With Quote
Old 05-06-2004, 10:36 AM   #8129
Hi Pops,
Will try yr suggestions now... meanwhile any more advice?
I will need as many as I can
Old 05-06-2004, 10:58 AM   #8130
lem2's Avatar
Default and also. . . .
in addition
use a mallet/hammer to taqp the drive gear into the input shaft, to sit it correctly. Also check the shimming, and placement of the SPUR GEAR hub/holder.
Hope all is well. Peace and Happy Racing!
lem2 is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
