Old 05-02-2004, 08:11 PM   #8101
Send a message via ICQ to Jason-Pro Send a message via AIM to Jason-Pro
probably getting back into racing soon... and a friends got a yok ride (thinks hes got a small sponsorship with them) well i think im going to run the yok....
whats the dream yok upgrades for carpet and outdoor ?
Jason-Pro is offline   Reply With Quote
Old 05-03-2004, 09:25 AM   #8102
yodace's Avatar
R/C Tech Charter Subscriber
Is the chassis in the converison kit the light weight chassis? Or is there two CG chassis?
yodace is offline   Reply With Quote
Old 05-03-2004, 09:39 AM   #8103
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
It is the non light weight CGM in the conversion. I know the lightweight version is not a huge savings so I think you would be fine running the conversion kit...I am.
Jeff
Jeff Werner is offline   Reply With Quote
Old 05-03-2004, 10:00 AM   #8104
ATLAS COPCO's Avatar
Can any body shine a bit of light on something ,Anti squat i know how to obtain this but what i want to know is what size shim = how many degrees of anti squat . It is an SD by the way
Thank for your help guys
ATLAS COPCO is offline   Reply With Quote
Old 05-03-2004, 11:41 AM   #8105
Trader Rating: 35 (100%+)
Default Finally happened...
Saturday my race day was shortened when my front shock tower broke during practice. What's worse is that race was the first in a new Point Series.
I've read some of the past posts where some of you have been running a rear shock tower on the front, and other have been running the Rayspeed shock towers.
Questions:
If I use the stock rear shock tower on the front I assume that it must be trimmed? Where to I trim?
If I use the Rayspeed towers, can I still use my standard shock shafts, or do I need to change the shocks or springs in some way?
Last, anyone know of a Hobby Store that has these items in stock, and can ship before this Saturday?
I almost forgot, I also need a replacment hinge pin!!!
Geppetto is offline   Reply With Quote
Old 05-03-2004, 12:35 PM   #8106
Matt Howard's Avatar
The shim with a notch in it is equal to 1 deg when it's added under a suspension mount. the shim without a notch is equal to 1mm
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 05-03-2004, 12:55 PM   #8107
Sleighty's Avatar
Default CGM?
i know this is probobly a stupid question but can you just buy a cgm chassis and it will fit onto the standard sd, witout having to buy the full conversion?
A1-RC.com
Team Scream
Xray
Sleighty is offline   Reply With Quote
Old 05-03-2004, 07:18 PM   #8108
lem2's Avatar
Default Re: CGM?
yes go to Raibowten
but you still have to buy 2 additional parts which are the diff braces for the front and rear, dunno if the steering linkage will work from the standard SD to CGM.
lem2 is offline   Reply With Quote
Old 05-03-2004, 08:09 PM   #8109
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Default Re: Finally happened...
Questions:
Speedtech should have what you need in stock. He can send it out 2 day air or 3 day select so you can have the stuff before Saturday.
ST Racing Concepts (STRC)
Old 05-03-2004, 08:27 PM   #8110
Default Re: Re: CGM?
Originally posted by lem2
yes go to Raibowten
Actually, there are more bits that you will need:
1. CGM Motor mount
2. Front and Rear Suspension blocks
3. Servo/Antenna mount
I think just buying the minimum parts will equal the price of a full conversion kit. There's no short cuts.
Headbanger is offline   Reply With Quote
Old 05-03-2004, 08:35 PM   #8111
Tek Nickal's Avatar
Probally even more expensive, just get the conversion kit.
Tek Nickal is offline   Reply With Quote
Old 05-03-2004, 10:21 PM   #8112
lem2's Avatar
Default Re: Re: Re: CGM?
1. CGM Motor mount
I stand corrected! hehehehe buy the whole conversion kit-- will be cheaper!
Old 05-04-2004, 06:01 AM   #8113
Lonestar's Avatar
Howdy
here's a pic of my front shock tower... the extra outer hole is actually the body post holder, you can trim this one off too.
a dremel does the job just fine. Just wear a mask (breathing carbon fiber dust is not so good for your lungs).
Later,
Paul
PS: Sorry, blurry pic...
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 05-04-2004, 07:15 AM   #8114
Will be interesting to see what Tosolini and Masami ran at the worlds warm up in terms of setup. I know I could use a good Pre Mount 27 Take Off setup...lol
Also I wanted to see what this threads thoughts on what set up changes would a person look at doing for a new track that is Concrete large (160 ft straight) indoor and from reports Ihave been getting enough traction that cars are traction rolling in many of the high speed areas. I am going from running outdoors on asphalt. any tips on trying to prevent traction roll would be cool.
Jeff
Old 05-04-2004, 07:20 AM   #8115
Jeff, try running some antidive in the front of the car, that will take away some initial turn-in and should stop any traction rolling. You can also put some glue on the sidewalls of the tire so when the car starts to tip it will hit the glue and stop
RCTech #361
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
