Old 04-25-2004, 09:41 PM   #8011
Matt Howard's Avatar
Originally posted by AzNDRAGster
If you put an 8 gram weight on one hand, and a 8 gram weight on the other, it will feel different depending on what hand you use more, what hand you use more means that that side of the brain works more, giving you an unaccurate measurment. Just an thought.
That's why I switched them after weighing them in each hand and then divided the difference LOL, trust me, it's lighter than the tobee shaft
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 04-25-2004, 10:06 PM   #8012
hahahaha, ohh wells if matt says its lighter it must be ...
shortygy is offline   Reply With Quote
Old 04-25-2004, 11:55 PM   #8013
Tek Nickal's Avatar
If Matt says for you to jump off a bridge, would you do it?
Tek Nickal is offline   Reply With Quote
Old 04-26-2004, 05:15 AM   #8014
Horatio's Avatar
I'm sure someone will weigh them soon enough. I know that the human brain can perceive even very slight differences in weight, so I doubt Matt is wrong. However, there is still no substitue for a set of scales!!
Horatio is offline   Reply With Quote
Old 04-26-2004, 06:10 AM   #8015
Trader Rating: 35 (100%+)
Default Fukuyama graphite center shaft
That's good news!!!
I've been using the Yokomo graphite shaft for the past 2 race dates (stock class). I've read about the shaft splintering, so I decided to paint on 2 coats of thin CA. I then used a super fine grit sanding block to smooth out the surface of the shaft. I figured since the shaft is graphite, it must have an open fiber structure. Anyway, my hope is that the CA would fill the gaps between the fibers and make the graphite stronger. So far there are no signs of stress on the shaft (knock on wood).
Geppetto is offline   Reply With Quote
Old 04-26-2004, 09:55 AM   #8016
lem2's Avatar
Default Re: Fukuyama graphite center shaft
Originally posted by Geppetto
That's good news!!!
Good Idea!!!!!! THANKS!!!
lem2 is offline   Reply With Quote
Old 04-26-2004, 10:15 AM   #8017
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
Well finally got to run my CGM outdoors on a large high bite paved track...and WOW! With my Peak Vantage 10x2 and Promatch Batts the Yok was a rocket. Will have to post a setup soon to see how it compares to what Matt and the guys are running in Cali. Was able to run times that would have almost TQ'ed the last major event that they ran at the track. Gotta love first time out and being up to speed!
Jeff
Jeff Werner is online now   Reply With Quote
Old 04-26-2004, 12:00 PM   #8018
Lonestar's Avatar
That's good news!!!
er... how much more does it weight? now it's CA'ed?
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 04-26-2004, 12:05 PM   #8019
Default Light Weight Chassis
Anyone tried the SD CGM light weight chassis ?? Does it worth the money ??
Anthony Yuen is offline   Reply With Quote
Old 04-26-2004, 12:52 PM   #8020
Default Re: Re: Fukuyama graphite center shaft
Paul
I only added 2 thin coats of the lightest CA I could find. Then I sanded the shaft to remove the dried excess glue on the surface of the shaft. I honestly don't know the weight, but I'm sure that the weight is still less than the stock shaft.
Old 04-26-2004, 03:30 PM   #8021
Horatio's Avatar
Talking Re: Re: Fukuyama graphite center shaft
Paul
Old 04-26-2004, 09:22 PM   #8022
Here's a pic of the Fukuyama center shaft for the SD
RCTech #361
Old 04-26-2004, 09:51 PM   #8023
Tek Nickal's Avatar
That looks cool. Can't wait.
Old 04-26-2004, 10:31 PM   #8024
Registered User
Looks like Shooter Graphite Main Shaft. Are they the same?
http://precisionrc.com/product/shooter/sd.htm#ms
Aku-Man is offline   Reply With Quote
Old 04-26-2004, 11:37 PM   #8025
Tek Nickal's Avatar
Looks very similar.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
